jimmybobby
"stress" command not found.
Sun Jun 09, 2013 6:58 am
Hi everyone, I was attempting to use this code, from the command line, via ssh.
stress --cpu 1 -t 300 ; ./vcgencmd measure_temp | cut -d "=" -f2 | cut -d "'" -f1
Found here: http://wiki.stocksy.co.uk/wiki/Raspberr ... re_sensors
Then I get the error "command not found" - is there a way that I can get this command, without losing all my web-server work?
Many thanks in advance.
It's fair to say I like obsolete/old technology. :)
A Level Comp Sci Student
ghans
Re: "stress" command not found.
Sun Jun 09, 2013 7:18 am
sudo apt-get update
sudo apt-get install stress
should fix it.
ghans
macuestc
Sun Jun 09, 2013 7:27 am
1:apt-get update ,this command will update the package list on your pi and make an update,and you may choose not to update the system.
2:apt-cache search stress ,this command will search the package list on your pi and find some packages which related to the string "stress"
3:select one package you get at step 2,given that it's name is "xxx"
4:apt-get install xxx
done,hope that it will help you
