davorin
Force 800x600 [solved]
Sat Jun 01, 2013 12:17 pm
Good afternoon (o;
I try to bring some light on a 800x600 display with a HDMI2RGB converter...
As from the Wiki the settings in config.txt should be:
hdmi_force_hotplug=1
hdmi_group=2
hdmi_mode=9
Rebooting then and do a "/opt/vc/bin/tvservice -s" shows still:
state 0x120016 [DVI  RGB lim 16:9], 1280x720 @ 60Hz, progressive
Is this the correct behavior?
dom
Re: Force 800x600
Sat Jun 01, 2013 12:51 pm
davorin wrote:Good afternoon (o;
hdmi_group=2
hdmi_mode=9
Yes, if your monitor's edid reports that 800x600 is not a valid mode. Try also adding:
hdmi_ignore_edid=0xa5000080
davorin
Re: Force 800x600
Sat Jun 01, 2013 2:05 pm
Yes, that line definitively helped:
The rest was some crappy FPC50 connector (o;
Now for the final design of the HDMI2RGB converter (o;
davorin
Re: Force 800x600 [solved]
Tue Jul 23, 2013 10:54 am
Just have here a Chinese 8" HDMI screen with touchscreen, which totally ignores above lines...
Any other ideas to force it to 800x600?
It always defaults to 1280x720@60Hz
dom
Tue Jul 23, 2013 11:16 am
davorin wrote:Just have here a Chinese 8" HDMI screen with touchscreen, which totally ignores above lines...
The display can't force the pi to output 1280x720. It sounds like there's a problem with config.txt file.
What does:
vcgencmd get_config int
tvservice -s
report?
davorin
Tue Jul 23, 2013 3:49 pm
vcgencmd get_config int:
arm_freq=800
hdmi_mode=9
hdmi_group=2
temp_limit=85
force_pwm_open=1
tvservice -s:
state 0x120016 [DVI CEA (4) RGB lim 16:9], 1280x720 @ 60Hz, progressive
Sorry for late response...was testing another HDMI touchscreen monitor with 800x480 meanwhile ;-)
