Wifi USB Issue
Posted: Mon May 27, 2013 2:04 pm
by Dan9550
I am having a strange issue where after maybe about 5 minutes of using wifi (about 5-6meg a sec worth of traffic). The wifi cuts out and will work if i replug the usb only for a moment then again will just cut out. Its a very annoying problem.
Anyone know how i can fix this?
I am using:
Raspberry Pi (512MB RAM)
Powered USB Hub
TP-Link TL-WN821N
Re: Wifi USB Issue
Posted: Tue May 28, 2013 4:10 pm
by homer77
Please give us the output of lsusb for your device. I make a guess that it works with the annoying realtek 8192cu driver. You could check if the module is loaded with
# lsmod | grep 8192cu
If it is, maybe this post will enlight you http://www.raspberrypi.org/phpBB3/viewt ... 19#p353919
Suffering the same issue,
Homer
Re: Wifi USB Issue
Posted: Wed May 29, 2013 6:33 am
by Dan9550
So i ran lsmod, there was no 8192cu.
ath9k_htc, ath9k_common, ath9k_hw, ath were there i assuming these are the wifi drivers.
Re: Wifi USB Issue
Posted: Wed May 29, 2013 7:08 am
by DaveDriesen
Yes -- those are drivers for Atheros wireless adapters.
Anything useful in dmesg or /var/log/ ?
Dave Driesen
Linux dev and oldskool elite
Re: Wifi USB Issue
Posted: Wed May 29, 2013 7:18 am
by Dan9550
So tried turning power saving off as mentioned in another thread this didn't help, i am combing through dmesg now found this a lot
[   81.334868] usb 1-1.3.4: device descriptor read/64, error -71
[   81.524764] usb 1-1.3.4: device descriptor read/64, error -71
[   81.714912] usb 1-1.3.4: new high-speed USB device number 28 using dwc_otg
[   82.134674] usb 1-1.3.4: device not accepting address 28, error -71
[   82.214871] usb 1-1.3.4: new high-speed USB device number 29 using dwc_otg
[   82.634697] usb 1-1.3.4: device not accepting address 29, error -71
Here is a screenshot of some of the wifi usb doing whatever its doing haha
Didn't see much else that looked to interesting.
Re: Wifi USB Issue
Posted: Wed May 29, 2013 7:34 pm
by gsh
Would be interested to see if the fiq_split branch makes any difference to this...
sudo BRANCH=fiq_split rpi-update
Gordon
Re: Wifi USB Issue
Posted: Fri May 31, 2013 8:53 am
by Dan9550
will try it out.
Re: Wifi USB Issue
Posted: Fri May 31, 2013 9:08 am
by Dan9550
Seems to be working alright, i don't seem to have wifi drivers or something though. The pi detects my usb but there is no wlan0
