Thetechnoman
Pi boots to flashing _ screen (Fixed)
Sun May 26, 2013 8:32 pm
OS: Raspbian
I recently updated my pi and I then restarted and all of the usual boot code appeared, but after that had disappeared the screen just had a flashing _ in the corner. I reflashed the SD Card and the same happened.
Any help would be much appreciated.
Thetechnoman
Thetechnoman
Re: Pi boots to flashing _ screen
Mon May 27, 2013 2:42 pm
I have tried reflashing the card again and the same thing has happened.
I can access raspi-config but it won't let me startx.
SirClayton
Tue May 28, 2013 12:36 pm
Have you tried a different OS?
Like Debian for instance?
Pi and Google...
Thetechnoman
Tue May 28, 2013 5:28 pm
I have found the source of the problem. The SD card i was using was somehow causing the corruption of startx. I have install it on a different sd card and it works perfectly.
Thetechnoman
