M33P wrote:UUID should prevent any sort of duplicate mounting of filesystems.
Can you post a complete dmesg output (and lsusb) over the timespan that incorporates a re-mount event?
If a USB device is reset (it can happen at random sometimes on the Pi, usually power related) then it will be re-enumerated and may be remounted but with broken state (i.e. where another drive is already mounted).
Hi M33P,
I reproduced the problem and looks you are right. There are many I/O errors then USB disconnect. When the device reconnects, it's recognized as a new device.
That's what I can see through my non-expert eyes. If you can help me find the exact causes and suggest a solution, it will be greatly appreciated!
Thanks,
Feischi
dmesg:
[ 1578.533655] sd 0:0:0:0: [sda] Unhandled error code
[ 1578.533683] sd 0:0:0:0: [sda]
[ 1578.533693] Result: hostbyte=0x07 driverbyte=0x00
[ 1578.533704] sd 0:0:0:0: [sda] CDB:
[ 1578.533711] cdb[0]=0x2a: 2a 00 07 b6 d0 d0 00 00 f0 00
[ 1578.533743] end_request: I/O error, dev sda, sector 129421520
[ 1578.533758] Buffer I/O error on device sda1, logical block 16177434
[ 1578.533766] lost page write due to I/O error on sda1
[ 1578.533802] Buffer I/O error on device sda1, logical block 16177435
[ 1578.533811] lost page write due to I/O error on sda1
[ 1578.533826] Buffer I/O error on device sda1, logical block 16177436
[ 1578.533834] lost page write due to I/O error on sda1
[ 1578.533847] Buffer I/O error on device sda1, logical block 16177437
[ 1578.533854] lost page write due to I/O error on sda1
[ 1578.533866] Buffer I/O error on device sda1, logical block 16177438
[ 1578.533874] lost page write due to I/O error on sda1
[ 1578.533886] Buffer I/O error on device sda1, logical block 16177439
[ 1578.533894] lost page write due to I/O error on sda1
[ 1578.533906] Buffer I/O error on device sda1, logical block 16177440
[ 1578.533914] lost page write due to I/O error on sda1
[ 1578.533927] Buffer I/O error on device sda1, logical block 16177441
[ 1578.533934] lost page write due to I/O error on sda1
[ 1578.533946] Buffer I/O error on device sda1, logical block 16177442
[ 1578.533954] lost page write due to I/O error on sda1
[ 1578.533966] Buffer I/O error on device sda1, logical block 16177443
[ 1578.533974] lost page write due to I/O error on sda1
[ 1578.633579] sd 0:0:0:0: [sda] Unhandled error code
[ 1578.633606] sd 0:0:0:0: [sda]
[ 1578.633616] Result: hostbyte=0x07 driverbyte=0x00
[ 1578.633626] sd 0:0:0:0: [sda] CDB:
[ 1578.633633] cdb[0]=0x2a: 2a 00 07 b6 d1 c0 00 00 40 00
[ 1578.633664] end_request: I/O error, dev sda, sector 129421760
[ 1578.653824] usb 1-1.3.4: USB disconnect, device number 6
[ 1578.673633] sd 0:0:0:0: [sda] Unhandled error code
[ 1578.673661] sd 0:0:0:0: [sda]
[ 1578.673672] Result: hostbyte=0x01 driverbyte=0x00
[ 1578.673683] sd 0:0:0:0: [sda] CDB:
[ 1578.673691] cdb[0]=0x2a: 2a 00 07 b6 d6 00 00 00 f0 00
[ 1578.673723] end_request: I/O error, dev sda, sector 129422848
[ 1578.681224] sd 0:0:0:0: [sda] Unhandled error code
[ 1578.681254] sd 0:0:0:0: [sda]
[ 1578.681264] Result: hostbyte=0x01 driverbyte=0x00
[ 1578.681275] sd 0:0:0:0: [sda] CDB:
[ 1578.681282] cdb[0]=0x2a: 2a 00 07 b6 d6 f0 00 00 f0 00
[ 1578.681317] end_request: I/O error, dev sda, sector 129423088
[ 1578.998437] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 1578.998778] sd 0:0:0:0: [sda]
[ 1578.998796] Result: hostbyte=0x01 driverbyte=0x00
[ 1582.613863] usb 1-1.3.4: new high-speed USB device number 29 using dwc_otg
[ 1582.715078] usb 1-1.3.4: New USB device found, idVendor=1058, idProduct=070a
[ 1582.715103] usb 1-1.3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1582.715119] usb 1-1.3.4: Product: My Passport 070A
[ 1582.715130] usb 1-1.3.4: Manufacturer: Western Digital
[ 1582.715141] usb 1-1.3.4: SerialNumber: 575848314133304634313335
[ 1582.718698] usb-storage 1-1.3.4:1.0: Quirks match for vid 1058 pid 070a: 200000
[ 1582.718836] scsi2 : usb-storage 1-1.3.4:1.0
[ 1583.716348] scsi 2:0:0:0: Direct-Access WD My Passport 070A 2018 PQ: 0 ANSI: 4
[ 1583.721456] scsi 2:0:0:1: CD-ROM WD Virtual CD 070A 2018 PQ: 0 ANSI: 4
[ 1583.723789] sd 2:0:0:0: [sdc] 975400960 512-byte logical blocks: (499 GB/465 GiB)
[ 1583.726304] sd 2:0:0:0: [sdc] Write Protect is off
[ 1583.726335] sd 2:0:0:0: [sdc] Mode Sense: 2b 00 10 08
[ 1583.728176] sr0: scsi3-mmc drive: 51x/51x caddy
[ 1583.728870] sr 2:0:0:1: Attached scsi CD-ROM sr0
[ 1583.730434] sd 2:0:0:0: [sdc] No Caching mode page present
[ 1583.730461] sd 2:0:0:0: [sdc] Assuming drive cache: write back
[ 1583.733213] scsi 2:0:0:2: Enclosure WD SES Device 2018 PQ: 0 ANSI: 4
[ 1583.740447] sd 2:0:0:0: [sdc] No Caching mode page present
[ 1583.740477] sd 2:0:0:0: [sdc] Assuming drive cache: write back
[ 1583.784179] sdc: sdc1
[ 1583.791184] sd 2:0:0:0: [sdc] No Caching mode page present
[ 1583.791212] sd 2:0:0:0: [sdc] Assuming drive cache: write back
[ 1583.791227] sd 2:0:0:0: [sdc] Attached SCSI disk
[ 1616.830068] quiet_error: 88 callbacks suppressed
[ 1616.830092] Buffer I/O error on device sda1, logical block 18358089
[ 1616.830827] Buffer I/O error on device sda1, logical block 18358089
[ 1616.833872] Buffer I/O error on device sda1, logical block 18358089
[ 1623.761950] Buffer I/O error on device sda1, logical block 18358089
[ 1623.766250] Buffer I/O error on device sda1, logical block 18358089
[ 1623.775632] Buffer I/O error on device sda1, logical block 18358089
[ 1623.778935] Buffer I/O error on device sda1, logical block 18358089
[ 1626.213849] Buffer I/O error on device sda1, logical block 17065346
[ 1626.219109] Buffer I/O error on device sda1, logical block 17065346
[ 1627.917881] Buffer I/O error on device sda1, logical block 786483
[ 1627.923368] Buffer I/O error on device sda1, logical block 786483
[ 1630.929805] Buffer I/O error on device sda1, logical block 786450
[ 1630.933080] Buffer I/O error on device sda1, logical block 786449
lsusb:
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 004: ID 04cc:1521 ST-Ericsson USB 2.0 Hub
Bus 001 Device 028: ID 03f0:110c Hewlett-Packard
Bus 001 Device 029: ID 1058:070a Western Digital Technologies, Inc. My Passport Essential SE
