Fri May 17, 2013 10:07 pm
Bebelus wrote:Hello,
I use the rpi image 3.6.11 and I try to connect from a Ubuntu 12.04 Precise Pangolin.
Activating the -vvv option inssh I get the following errors:
debug1: channel 0: new [client-session]
debug3: ssh_session2_open: channel_new: 0
debug2: channel 0: send open
debug1: Requesting
no-more-sessions@openssh.com
debug1: Entering interactive session.
Write failed: Broken pipe
Thx,
Bebelus
Hi Bebelus,
It looks as if we're using similar setups, except that I usually use PuTTy rather than manually ssh'ing from a terminal.
If I do the latter w/o the -vvv option I get:
trevor@BlueElf:~$ ssh -l pi 192.168.23.49
The authenticity of host '192.168.23.49 (192.168.23.49)' can't be established.
ECDSA key fingerprint is 40:6d:f0:d8:fc:d7:34:3f:12:cf:b1:2a:13:c7:f8:dd.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added '192.168.23.49' (ECDSA) to the list of known hosts.
pi@192.168.23.49's password:
Linux raspigrey 3.6.11+ #401 PREEMPT Fri Mar 29 22:59:09 GMT 2013 armv6l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Fri May 17 22:48:20 2013 from 192.168.23.237
Loading bash aliases ...
... done.
and with the -vvv option (first dozen or so lines):
trevor@BlueElf:~$ ssh -l pi 192.168.23.49 -vvv
OpenSSH_5.9p1 Debian-5ubuntu1.1, OpenSSL 1.0.1 14 Mar 2012
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug2: ssh_connect: needpriv 0
debug1: Connecting to 192.168.23.49 [192.168.23.49] port 22.
debug1: Connection established.
debug1: identity file /home/trevor/.ssh/id_rsa type -1
debug1: identity file /home/trevor/.ssh/id_rsa-cert type -1
debug1: identity file /home/trevor/.ssh/id_dsa type -1
debug1: identity file /home/trevor/.ssh/id_dsa-cert type -1
debug1: identity file /home/trevor/.ssh/id_ecdsa type -1
debug1: identity file /home/trevor/.ssh/id_ecdsa-cert type -1
debug1: Remote protocol version 2.0, remote software version OpenSSH_6.0p1 Debian-3
debug1: match: OpenSSH_6.0p1 Debian-3 pat OpenSSH*
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_5.9p1 Debian-5ubuntu1.1
debug2: fd 3 setting O_NONBLOCK
debug3: load_hostkeys: loading entries for host "192.168.23.49" from file "/home/trevor/.ssh/known_hosts"
This suggests that the issue is with ssh on your Ubuntu box rather than the Pi. It might be worth uninstalling OpenSSH etc. and re-installing it and/or updating.
Trev.
