Page 14 of 24
Re: WiFi Issues ? Start here !
Posted: Wed Dec 30, 2015 4:25 pm
by ElScorcho
MrEngman wrote: Odd. Looks like the wifi is not being recognised by the driver. Did you reboot after loading the driver. If not reboot and check command lsmod again to see if the driver is loaded.
If the lsmod command still does not show the driver, mt7610u_sta, try command
modinfo /lib/modules/4.1.13-v7+/kernel/drivers/net/wireless/mt7610u_sta.ko
and see if there is a line
alias:          usb:v2357p0105d*dc*dsc*dp*ic*isc*ip*in*
in the output. If not it is possible the driver you downloaded was an old version that did not include your wifi usb ID. You will need to download the file again and install the driver again. I have checked the driver in Dropbox and it does contain your wifi USB ID so I would expect it to work.
MrEngman
Hi there. I'm having a similar issue, but I think the driver on Dropbox has not been updated to contain my USB ID. Here's my info:
Running lsusb produces the following:
Bus 001 Device 004: ID 2357:0105
Running uname -a produces the following:
Linux glit 4.1.7+ #817 PREEMPT Sat Sep 19 15:25:36 BST 2015 armv6l GNU/Linux
So I grabbed the "mt7601-4.1.7-817.tar.gz" file from Dropbox.
However, when I run modinfo mt7601Usta.ko, I get the following:
filename:       /root/mt7601Usta.ko
version:        3.0.0.3
description:    RT2870 Wireless Lan Linux Driver
author:         Paul Lin <paul_lin@ralinktech.com>
license:        GPL
srcversion:     48ED4141152B42AC7CB3C5E
alias:          usb:v7392p7710d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2A5Fp1000d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2955p1003d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2955p1001d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2955p0001d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2717p4106d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2001p3D04d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v148Fp760Dd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v148Fp760Cd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v148Fp760Bd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v148Fp760Ad*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v148Fp7601d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v148Fp6370d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v13D3p3434d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v13D3p3431d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0E8Dp760Bd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0E8Dp760Ad*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0B05p17D3d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v148Fp7650d*dc*dsc*dp*ic*isc*ip*in*
depends:
vermagic:       4.1.7+ preempt mod_unload modversions ARMv6
parm:           mac:rt28xx: wireless mac addr (charp)
Should USB ID 2357:0105 be included in this driver?
Thanks!
Posted: Wed Dec 30, 2015 5:43 pm
by MrEngman
I think you need the mt7610 driver. That is the driver I compile that includes your wifi's USB ID.
filename:       /home/pi/mt7610u_sta.ko
version:        3.0.0.2
license:        GPL
srcversion:     27B387AACC98D1C42FBA76D
alias:          usb:v0E8Dp7650d*dc*dsc*dp*icFFisc02ipFFin*
alias:          usb:v0E8Dp7630d*dc*dsc*dp*icFFisc02ipFFin*
alias:          usb:v13B1p003Ed*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v148Fp761Ad*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0E8Dp7610d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v148Fp7610d*dc*dsc*dp*ic*isc*ip*in*
depends:
Try this
wget https://dl.dropboxusercontent.com/u/80256631/mt7610-4.1.7-817.tar.gz
tar xzf mt7610-4.1.7-817.tar.gz
./install.sh
MrEngman
Posted: Wed Dec 30, 2015 5:57 pm
by ElScorcho
MrEngman wrote:I think you need the mt7610 driver. That is the driver I compile that includes your wifi's USB ID.
MrEngman
Oof. You're correct. Thank you!
Posted: Wed Dec 30, 2015 6:11 pm
by ElScorcho
version:        3.0.0.2
license:        GPL
depends:
Try this
wget https://dl.d[code]
./install.sh[/code]
MrEngman
Although it still isn't loading for me.
After running the install script I still don't see it in ifconfig, and the module doesn't appear to be loaded in lsusb.
root@glit:~# lsusb
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp. LAN9500 Ethernet 10/100 Adapter / SMSC9512/9514 Hub
Posted: Wed Dec 30, 2015 6:21 pm
by MrEngman
After installing the driver you need to reboot your Pi.
To see if the driver is loaded you need to use command lsmod which lists the modules loaded, not lsusb which lists the USB devices connected to the Pi.
MrEngman
Posted: Wed Dec 30, 2015 6:23 pm
by ElScorcho
MrEngman wrote:After installing the driver you need to reboot your Pi.
To see if the driver is loaded you need to use command lsmod which list the modules loaded, not lsusb which shows the USB devices connected to the Pi.
MrEngman
I did a reboot immediately after the install script. Apologies for leaving that out.
root@glit:~# lsmod
Module                  Size  Used by
mt7610u_sta           886017  0
bcm2835_gpiomem         3703  0
uio_pdrv_genirq         3690  0
uio                    10002  1 uio_pdrv_genirq
snd_bcm2835            22317  0
snd_pcm                92581  1 snd_bcm2835
snd_timer              23454  1 snd_pcm
snd                    68161  3 snd_bcm2835,snd_timer,snd_pcm
ipv6                  360374  22
Posted: Wed Dec 30, 2015 6:44 pm
by ElScorcho
MrEngman
root@glit:~# lsmod
Module                  Size  Used by
snd_bcm2835            22317  0
ipv6                  360374  22
I had forgotten to install the firmware. All set. Thanks for the help!
Posted: Wed Dec 30, 2015 6:53 pm
by MrEngman
ElScorcho wrote: I had forgotten to install the firmware. All set. Thanks for the help!
Which you did using which command? As far as I remember I've never had to install any firmware for this driver.
MrEngman
Posted: Wed Dec 30, 2015 6:59 pm
by ElScorcho
MrEngman
apt-get install firmware-ralink firmware-realtek
I wasn't sure which to install, so I grabbed both. I suspect I had to install firmware because I'm running Minibian.
Posted: Thu Dec 31, 2015 5:07 pm
by GiulioFlore
Re checking the presence of the module, I have a wlu-1663 dongle and when i checked the module with lsmod there was no reference to any item as displayed in your. In short, pi can see the dongle but has no sw to handle it. How can I make it work?
Posted: Thu Dec 31, 2015 8:03 pm
by MrEngman
GiulioFlore wrote:Re checking the presence of the module, I have a wlu-1663 dongle and when i checked the module with lsmod there was no reference to any item as displayed in your. In short, pi can see the dongle but has no sw to handle it. How can I make it work?
Post the output of command lsusb so we can see the wifi ID and we should be able to find which driver it uses.
Also post the output of command uname -a so we can see the kernel version you are using.
MrEngman
Posted: Thu Dec 31, 2015 11:56 pm
by Perplexed
I have the identical problem as Powerjam
Posted: Fri Jan 01, 2016 5:51 am
by DirkS
Perplexed wrote:I have the identical problem as Powerjam
Too lazy to find where that is posted...
Create a new topic and give us some information to work with:
* which dongle do you use
* what it does and does not do (in other words: what's the problem)
* output of the commands
lsusb
uname -a
Posted: Sat Jan 02, 2016 6:56 am
by nilerun
This is a WELL WRITTEN article.
I need to change the wifi settings. When I run /etc/network/interfaces it says Permission denied.
What do I do next?
Nile
Posted: Sun Jan 03, 2016 4:21 am
by nilerun
I entered all the things you said to enter, but when I got to the end nothing happened. Isn't it supposed to be saved somehow? (I still can't get connected to the internet)
Niole
Posted: Sun Jan 03, 2016 5:45 am
by DirkS
nilerun wrote:I entered all the things you said to enter, but when I got to the end nothing happened. Isn't it supposed to be saved somehow? (I still can't get connected to the internet)
Niole
This topic has about 350 posts by now...
Which of these are you referring to? What changes do you need to make?
What changes did you make to your files (details, please).
WiFi driver not working
Posted: Sun Jan 03, 2016 9:53 am
by krisujanis
Hello!
I'm first time poster, but hopefully this is correct place to ask this question.
Situation: I have a Raspberry Pi A model (no LAN port) and want to connect WiFi module from Eusso. However, I have tried to install the drivers (https://www.dropbox.com/s/wypvz4vymjkkc ... x.zip?dl=1) and found out that by default they are made for Kernel 2.4 or 2.6. So I decided that it is not possible to install it, because Kernel 2.4 or 2.6 seems like never been working on raspberri. I have installed latest Raspbian with kernel 4.smth. But! There are this fix folder in Linux.zip file (dropbox link). I am not expert or intermediate not in Linux, nor the Raspberry.
Solution: Could anyone please help or tutor something? I would be really thankful, because connecting to internet would be huge step. ;)
And here is picture of adapter. It was working excellent on windows 7,8 and even 10:
Re: WiFi driver not working
Posted: Sun Jan 03, 2016 11:40 am
by MrEngman
krisujanis wrote:Hello!
There may already be a driver for your wifi included in the raspbian image. With the wifi adapter connected to your Pi post the output of commands
uname -a
lsusb
ifconfig
just to check if it is.
MrEngman
Posted: Sun Jan 03, 2016 5:12 pm
by krisujanis
hi!
I ran the commands and made a screenshot of what I got. I am using self powered 4-way hub. ;)
Posted: Sun Jan 03, 2016 5:56 pm
by MrEngman
There is a driver for your wifi included in the raspbian kernel image (/lib/modules/4.1.13+/kernel/drivers/net/wireless/zd1211rw/zd1211rw.ko), unless you have overwritten or removed it when trying to install the driver you got with your wifi.
If the wifi driver is installed I would expect the ifconfig command to show details for wlan0, the standard name used for the wifi even if it has not been configured. Have you edited file /etc/network/interfaces as this could stop wlan0 appearing in the output of ifconfig? If you have edited the file you will need to restore it to it's original state.
As you are running the GUI you should be able to get the wifi working by selecting the network icon (two overlapping computer screens) at the top right of the screen next to the speaker icon. The icon changes to a wifi signal when the wifi is working.
Left clicking the icon should show a list of networks you wifi can detect. See here for more details on setting up the wifi.
MrEngman
Posted: Tue Jan 05, 2016 1:10 pm
by Abhiraj Tiwari
Thanks alot for your time and answer,
Posted: Thu Jan 07, 2016 8:32 am
by Lochy27
Hi, I'm having wifi problems I went through the tutorial and my raspberry Pi is picking up the USB dongle when I ran lsusb and the modules for the device (ralink rt5370) are installed I'm using the wi-Pi adapter from element 14 the blue light used to come on and flash at boot but now it has stopped and i have no internet connection it's not picking up my network. I have tried for about a week or so now to get this working and have gone through several tutorials trying to get it working. Also the Ethernet was not working but I went through a tutorial which involved me turning off all the DHCP clients to get it working (I think this may be the cause of my problems the wifi wasn't working before I fixed the Ethernet but it still flashed/lit up) and I have Internet access through that but for the project I'm doing (Hexapod for robocup juniour) I need a wireless connection for ad-hoc (VPN/SSH) any help is very much appreciated as I am relatively new to raspberry Pi
Posted: Thu Jan 07, 2016 11:27 am
by MrEngman
Lochy27 wrote:Hi, I'm having wifi problems I went through the tutorial and my raspberry Pi is picking up the USB dongle when I ran lsusb and the modules for the device (ralink rt5370) are installed I'm using the wi-Pi adapter from element 14 the blue light used to come on and flash at boot but now it has stopped and i have no internet connection it's not picking up my network. I have tried for about a week or so now to get this working and have gone through several tutorials trying to get it working. Also the Ethernet was not working but I went through a tutorial which involved me turning off all the DHCP clients to get it working (I think this may be the cause of my problems the wifi wasn't working before I fixed the Ethernet but it still flashed/lit up) and I have Internet access through that but for the project I'm doing (Hexapod for robocup juniour) I need a wireless connection for ad-hoc (VPN/SSH) any help is very much appreciated as I am relatively new to raspberry Pi
If the tutorial you are referring to is the first post then I' not surprised your networking is not working. It was originally written almost 3 years ago and the network set up has been changed considerably since then. It makes no reference to the current latest network set up where editing the /etc/network/interfaces file to configure your wifi or ethernet is a bad idea.
Exactly how you need to set up your wifi may depend on the version of the kernel you are using. For the latest kernels, using raspbian, I set mine up like this. File /etc/network/interfaces is the defaults as it appears in the original raspbian image and should not be edited
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet manual
and file /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
network={
        ssid="your-network-name"
        psk="your-network-password"
This is how I have most of my Pi's configured and that is using a variety of different wifi adapters using different drivers, some of which I compile myself. I also connect to all my Pi's using SSH and have no problems doing that.
If you have been removing dhcp clients then that certainly will not help as dhcp is used to get the IP addresses for your network connections and I would suggest you start with a new SD card.
MrEngman
Posted: Thu Jan 07, 2016 1:48 pm
by Lochy27
Thanks engman your help is really appreciated I ended up transferring my files off the pi and creating a new image, thanks again
Posted: Mon Jan 11, 2016 6:57 pm
by Bosse_B
I found this thread when searching for help...
But it is soo long that I don't know where to start.
EDIT: Actually I started with the very first post but ALL of the tests show everything is OK and yet the darned WiFi will still not connect!
I assume with all the data in the conf and supplicant files it should really just connect by itself, but it does not.
And there is no SSID list when I click the network symbol in the GUI either...
Here is my problem:
Raspbian Jessie (Nov 2015) on a RPi2B
Edimax EW-7811Un USB WiFi dongle
When I insert the Edomax into the USB WiFi will never show up in the network icon (upper right corner).
But when I run this command to list the SSID:s in a terminal I can see all of the available networks:
pi@rpi2-jessie2:~/Projects/fpc/GPIOtest $ sudo iwlist wlan0 scan
wlan0     Scan completed :
          Cell 01 - Address: B8:A3:86:5E:44:C5
                    ESSID:"bossehemma"
                    Protocol:IEEE 802.11bg
                    Mode:Master
                    Frequency:2.412 GHz (Channel 1)
                    Encryption key:on
                    Bit Rates:54 Mb/s
                    IE: Unknown: DD7C0050F204104A00011010440001021057000101103B0001031047001000000000000010000000B8A3865E44C510210006442D4C696E6B1023000D442D4C696E6B20526F75746572102400074449522D363535104200046E6F6E651054000800060050F2040001101100074449522D363535100800020080103C000103
                    Quality=96/100  Signal level=96/100
          Cell 02 - Address: 00:16:A6:10:30:90
                    ESSID:"bossehemma"
                    Mode:Master
                    Frequency:2.462 GHz (Channel 11)
                    Encryption key:on
                    Bit Rates:54 Mb/s
                    Quality=89/100  Signal level=47/100
          Cell 03 - Address: 08:11:96:6F:63:4D
                    ESSID:"auriga-ap"
                    Protocol:IEEE 802.11gn
                    Mode:Master
                    Encryption key:on
                    Bit Rates:130 Mb/s
                    Extra:rsn_ie=30140100000fac040100000fac040100000fac020000
                    IE: IEEE 802.11i/WPA2 Version 1
                        Group Cipher : CCMP
                        Pairwise Ciphers (1) : CCMP
                        Authentication Suites (1) : PSK
                    Quality=96/100  Signal level=100/100
          Cell 04 - Address: 54:A0:50:79:02:B8
                    ESSID:"Karlbom"
                    Protocol:IEEE 802.11bgn
                    Mode:Master
                    Encryption key:on
                    Bit Rates:300 Mb/s
                        Group Cipher : CCMP
                    IE: Unknown: DD8F0050F204104A0001101044000102103B00010310470010BC329E001DD811B2860154A0507902B8102100154153555354654B20436F6D707574657220496E632E1023000A57505320526F757465721024000752542D4E3536551042000830303030303030301054000800060050F20400011011000F415355532057505320526F7574657210080002008C103C000101
                    Quality=99/100  Signal level=46/100
"bossehemma" is listed twice because I have a main router and a repeater
"auriga-ap" is a WiFi access point on my laptop (which is the one I want to connect WiFi to)
"Karlbom" is our neighbor's Internet router
So what the heck is stopping Raspbian Jessie from showing it and allowing me to connect?
Do I have to install something extra? The 32GB SD image I work with was created for software development (FreePascal/Lazarus) and only stuff related to that has been installed.
I thought WiFi support is there "out of the box" but it seems to not be so.
Any ideas, links, tutorials?
EDIT:
My supplicant file looks like this:
update_config=1
network={
        ssid="auriga-ap"
        psk="Volente2121"
        key_mgmt=WPA-PSK
network={
        ssid="bossehemma"
        key_mgmt=NONE
        wep_key0="FF23ED193A"
The data in this file was put there in an earlier attempt when the SSID list actually showed up in the GUI and I tried to connect.
But now it is impossible to get the list in the GUI.
Finally I ran the suggested command to get a list of the available networks and it shows this:
pi@rpi2-jessie2:~/Projects/fpc/GPIOtest $ sudo wpa_cli scan && sleep 5 && wpa_cli scan_results
Selected interface 'wlan0'
OK
bssid / frequency / signal level / flags / ssid
54:a0:50:79:02:b8       2412    46      [WPA2-PSK-CCMP][WPS][ESS]       Karlbom
b8:a3:86:5e:44:c5       2412    90      [WPS][WEP][ESS] bossehemma
00:16:a6:10:30:90       2462    48      [WEP][ESS]      bossehemma
08:11:96:6f:63:4d       2462    100     [WPA2-PSK-CCMP][ESS]    auriga-ap
As I stated I want to connect to auriga-ap...
