Requested information below, thanks for helping out!MrEngman wrote:It would appear that either there is no driver for it in the OS you are using, or the driver is included but does not include the USB ID for your wifi to activate it.revrsethecurse04 wrote:I purchased the following WiFi Dongle:
http://www.amazon.com/Adapter-NET-DYN%C ... ds=net-dyn
The dongle shows up when the command lsusb is entered as Ralink Technology, Corp.
When ifconfig -a is entered wlan0 does not appear.
When sudo ifup wlan0 is entered it indicates that interface wlan0 already configured.
When sudo iwlist wlan0 scan is entered it notes that wlan0 Interface doesn't support scanning.
The device does not show up as when wpa_gui is run.
Please advise how to move forward with this dongle.
Thanks,
Matt
Please post the output of commands uname -a and lsusb so I can check the OS you are using and determine which driver it uses.
MrEngman
uname-a:
Linux raspberrypi 3.18.11-v7+ #781 SMP PREEMPT Tue Apr 21 18:07:59 BST 2015 armv7l GNU/Linux
lsusb:
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 005: ID 0c40:8000
Bus 001 Device 004: ID 148f:7601 Ralink Technology, Corp.
