WNA1000M WiFi Adapter Not Working
Posted: Tue May 14, 2013 4:23 pm
by pyeager
Believe me, I have searched the forums here, and tried a lot of stuff!
apt-get update and apt-get upgrade did improve things a bit, as now it appears that a driver is being loaded, I see this in dmesg:
[   18.489644] usbcore: registered new interface driver rtl8192cu
lsusb says:
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Bus 001 Device 004: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 001 Device 005: ID 0846:9041 NetGear, Inc. WNA1000M 802.11bgn [Realtek RTL8188CUS]
Bus 001 Device 006: ID 413c:2003 Dell Computer Corp. Keyboard
Bus 001 Device 007: ID 045e:0023 Microsoft Corp. Trackball Optical
lsmod says:
Module                  Size  Used by
8192cu                490305  0
snd_bcm2835            16304  0
snd_pcm                77560  1 snd_bcm2835
snd_seq                53329  0
snd_timer              19998  2 snd_pcm,snd_seq
snd_seq_device          6438  1 snd_seq
snd                    58447  5 snd_bcm2835,snd_timer,snd_pcm,snd_seq,snd_seq_device
snd_page_alloc          5145  1 snd_pcm
leds_gpio               2235  0
evdev                   9426  4
led_class               3562  1 leds_gpio
I downloaded and ran the install-rtl8188cus-latest.sh script, and got the following:
Press any key to continue...
An RTL8188CUS driver module is installed and loaded.
You have 1 wifi adapter configured.
wlan0 is configured but is not installed.
The Pi has an internet connection.
Any files needed for the installation/upgrade will be downloaded from the
Internet unless they have already been copied to the SD card /boot directory.
Unrecognised software version: Linux raspberrypi 3.6.11+ #446 PREEMPT Fri May 10 20:17:25 BST 2013 armv6l GNU/Linux
Downloading the latest script.
The script you're using is the latest version.
Aborting the rtl8188cus installation script.
It looks like "wlan0 is configured but not installed" might be a clue, but I have no idea how to address that.
Any help would be greatly appreciated!
Re: WNA1000M WiFi Adapter Not Working
Posted: Tue May 14, 2013 4:36 pm
by pluggy
The wifi configuration on the standard Raspdian desktop should work. You don't need any script to install a driver for it.
Posted: Tue May 14, 2013 4:43 pm
by pyeager
Apparently, something I did prior to attempting to get wifi working had hosed things.
I tried again with a fresh OS image, and things worked much better. The wifi dongle was recognized at boot time, and wlan0 appeared in the WiFi Config applet.
Posted: Tue May 14, 2013 8:59 pm
by pyeager
So... it worked with a clean OS image, but apt-get update and apt-get dist-upgrade broke it.
No wifi interface available, no module loaded.
Posted: Tue May 14, 2013 9:03 pm
by pyeager
I don't. I have been a Linux user for years, and a user of various *nix before that. Like when it was impressive that you could send an email and get a response the same day.
Raspbian is the most challenging I have encountered.
Posted: Fri May 24, 2013 2:41 am
by msareen
I used details at http://wiki.debian.org/WiFi/HowToUse#Command_Line point 3, and making wifi work on pi is not pi specific problem, it is really a linux configuration problem (or task)
I never installed any driver in my default whizzy image and it worked like charm.
#lsusb
showed
Bus 001 Device 004: ID 0846:9041 NetGear, Inc. WNA1000M 802.11bgn [Realtek RTL8188CUS]
Most probably
I used netgear WNA1000M adapter and now it is working great.
Scan for available networks and get network details:
$ su
# iwlist scan
If you lan card is working it will show the available network
Now edit /etc/network/interfaces
it should already have entries like
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
now login to gui and use wifi manager to put in setting (using gui will really make your life easy)
what it do is internally update wpa_supplicant.conf (to make your life easy)
after this your wifi should work. (if blue light on your wifi is blinking most probably it is working)
Posted: Fri May 24, 2013 4:50 pm
by pyeager
I'm sure it did.
The problem was indeed RPi specific. A version of the kernel was released which included a version of the driver that did not recognize the WNA-1000M. As long as you weren't using such a kernel, it would indeed just be a matter of linux configuration for the adapter.
Posted: Fri May 24, 2013 4:52 pm
by pyeager
