after reboot,pi resize filemanager auto
Posted: Sat May 04, 2013 9:34 am
by smshiera
type startx then enter graphical interface,
open " file manager ",
I can resize this program's window smaller or bigger,
but after reboot,
pi set it back auto to a almost full screen size ,
what can i do to let it remember filemanager's setting?
Re: after reboot,pi resize file-manager auto
Posted: Sat May 04, 2013 4:32 pm
by Jim JKla
Which image are you using. ;)
Posted: Sat May 04, 2013 5:11 pm
by smshiera
Jim JKla wrote:Which image are you using. ;)
2013-02-09-wheezy-raspbian,
this happened about 1 week ago,i dont want reinstall it bucause i have installed some program .
Posted: Sun May 05, 2013 7:08 am
by Jim JKla
ok you probably need to look at editing the settings in
/boot/config.txt
this file is in the section you can access from your pc this is the part of the SD card you can edit from your PC with the SD card in a reader.
There's a load of stuff both here in the forum and in the wiki on editing the config.txt one thing to note use wordpad to edit from windows as Notepad fails to wrap the text. ;)
Posted: Sun May 05, 2013 10:11 am
by smshiera
Jim JKla wrote:ok you probably need to look at editing the settings in
/boot/config.txt
no no no ...,sorry for my broken english.
my led is 1920x1080, it displays correctly.no problem.
what i mean is type "startx" then enter graphical interface,
open " file manager ",resize this program's window
Re: after reboot,pi resize filemanager auto
Posted: Sun May 05, 2013 11:05 am
by Jim JKla
OK
I will look but I suspect someone will be back with an answer here before I get back. :)
Posted: Mon May 06, 2013 11:47 am
by smshiera
can i remove filemanager and reinstall it?
Posted: Mon May 06, 2013 9:45 pm
by smshiera
i have tried to remove and install this filemanager(pcmanfm),
but the problem is still not resolved..
which folder is that pcmanfm save its settings?
Posted: Fri May 10, 2013 11:22 pm
by smshiera
I have tried many ways,but this problem is still not solved
