uname -a
Linux raspberrypi 3.6.11+ #403 PREEMPT Tue Apr 2 22:48:13 BST 2013 armv6l GNU/Linux
apt-get clean
apt-get update
Hit http://archive.raspberrypi.org wheezy Release.gpg
Hit http://mirrordirector.raspbian.org wheezy Release.gpg
Hit http://archive.raspberrypi.org wheezy/main armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/main armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/contrib armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/non-free armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/rpi armhf Packages
Ign http://archive.raspberrypi.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/rpi Translation-en_GB
Reading package lists... Error!
E: Problem parsing dependency Depends
E: Error occurred while processing libedit2 (NewVersion2)
E: Problem with MergeList /var/lib/dpkg/status
E: The package lists or status file could not be parsed or opened.
rpi-update
*** Raspberry Pi firmware updater by Hexxeh, enhanced by AndrewS
*** Performing self-update
--2013-05-02 22:02:30-- https://github.com/Hexxeh/rpi-update/raw/master/rpi-update
Resolving github.com (github.com)... 204.232.175.90
Connecting to github.com (github.com)|204.232.175.90|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://raw.github.com/Hexxeh/rpi-update/master/rpi-update [following]
--2013-05-02 22:02:36-- https://raw.github.com/Hexxeh/rpi-update/master/rpi-update
Resolving raw.github.com (raw.github.com)... 199.27.76.133
Connecting to raw.github.com (raw.github.com)|199.27.76.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 6308 (6.2K) [text/plain]
Saving to: `/usr/bin/rpi-update.tmp'
100%[======================================>] 6,308 --.-K/s in 0.002s
2013-05-02 22:02:41 (3.64 MB/s) - `/usr/bin/rpi-update.tmp' saved [6308/6308]
*** Relaunching after update
*** ARM/GPU split is now defined in /boot/config.txt using the gpu_mem option!
*** We're running for the first time
*** Setting up firmware (this may take a few minutes)
/usr/bin/rpi-update: line 118: 2781 Segmentation fault git clone "${FW_REPO}" "${FW_REPOLOCAL}" --depth=1 --branch ${BRANCH}
!!! Failed to download new firmware files
How could I get the updates working again?
