mabox
problem installing xbian
Sun Apr 28, 2013 4:03 pm
problem install xbian.png (31.83 KiB) Viewed 5262 times
hi ,
i got some trouble installing xbian .
X bian installer is frozen on "downloading(o%) press esc to cancel".
The sd card is compatible , ive check it on elinux page ( transcend 16go class 10).
am using mac os x and i have the official version http://sourceforge.net/projects/xbian/f ... p/download
Please help me !
drgeoff
Re: problem installing xbian
Sun Apr 28, 2013 4:26 pm
That download file (around 7 Mbyte) is only an installer. Its needs to download the actual OS (in the region of 1 to 2 Gbyte?) when you run the installer. Is your Mac on-line when you are doing this? If yes, then I'd guess there is a problem at the remote server.
mabox
Sun Apr 28, 2013 4:35 pm
hey thanks for reply
so you think the only thing i can do is waiting ?
maibe something is wrong in my mac os system ? From preference system ? Or ...?
edit : the sd card is formated in fat 32 format .
By the way sorry if my speech is wierd cause a french and dont talk so well in english
drgeoff
Sun Apr 28, 2013 4:46 pm
I'm not a Mac user so don't know what if anything in your Mac's OS or settings would cause this. I assume your card reader is OK - can you write and read files on SDHC cards with it?
You don't have to use that installer. You can download an image from the links under 'Manual installation' at the bottom of http://xbian.org/download/. Then write that to the SD card using instructions at http://elinux.org/RPi_Easy_SD_Card_Setup.
mabox
Sun Apr 28, 2013 6:34 pm
ok i got this message from the pi installer on the wiki page :
==> This is not the first run... Skipping donation dialog.
Image /Users/myname/Desktop/XBian1.0Alpha5.img selected...
Selecting Device:
Unmounting Device...
hdiutil: unmount: "AppSettings.plist" failed to unmount due to error 49153.
hdiutil: unmount failed - Ressource occupée
mabox
Sun Apr 28, 2013 6:58 pm
when i try to unmount the volume of sd card in terminal :
"umount: unmount(/Volumes/PI): Operation not permitted"
mabox
Sun Apr 28, 2013 7:14 pm
hey sorry for the last post .
I tried again and seems to be working with piwriter ...
