Hello everyone!
What is happening is that I'm using my Pi to install Retropie and play a little, and at the third or forth reboot the Pi doesn't boot... It only shows a red light and the television says no signal... Then I format the SD cart, put it an wheezy image and everything works fine till the next time it doesn't boot again...
I've already read about this issue but always with different aspects about the trouble...
I've always shutdown Pi using "sudo halt"...
I wanted to know if there is a way to Fix this SD card and if there is way to prevent this from happening...
I'm using latest wheezy image, a LEXAR SDHC 8gb SD card and 5V 1200 mA charger...Pi is connected with HDMI...
Thank you for your time
Gonçalo
