billybangleballs
rpi-update (SOLVED)
Fri Apr 26, 2013 1:57 pm
Today I ran
sudo apt-get update
sudo apt-get upgrade
sudo rpi-update
All went well and then it said
 *** Running ldconfig
 *** Storing current firmware revision
 *** Syncing changes to disk
 *** If no errors appeared, your firmware was successfully updated
 *** A reboot is needed to activate the new firmware
[email protected] ~ $ sudo reboot
Broadcast message from [email protected] (pts/0) (Fri Apr 26 13:02:45 2013):
The system is going down for reboot NOW!
And it shutdown
It didn't reboot.
I have a Red PWR LED on
and a Green ACT LED that flashes 3 times, pauses and repeats.
I checked the psu and it has a good healthy 5 volts.
I have 13 files in my boot partition.
drwxr-xr-x 2 user root   16384 1970-01-01 02:00 .
drwxr-xr-x 5 root root    4096 2013-04-26 16:54 ..
-rwxr-xr-x 1 user root   17764 2013-04-26 12:56 bootcode.bin
-rwxr-xr-x 1 user root     250 2012-11-20 23:12 cmdline.txt
-rwxr-xr-x 1 user root    1318 2012-11-24 07:26 config.txt
-rwxr-xr-x 1 user root      41 2013-04-26 12:57 .firmware_revision
-rwxr-xr-x 1 user root    2264 2013-04-26 12:56 fixup_cd.dat
-rwxr-xr-x 1 user root    5900 2013-04-26 12:56 fixup.dat
-rwxr-xr-x 1 user root    8830 2013-04-26 12:56 fixup_x.dat
-rwxr-xr-x 1 user root     137 2012-09-18 13:40 issue.txt
-rwxr-xr-x 1 user root 9609944 2013-04-26 12:56 kernel_emergency.img
-rwxr-xr-x 1 user root 2803504 2013-04-26 12:56 kernel.img
-rwxr-xr-x 1 user root  569976 2013-04-26 12:56 start_cd.elf
-rwxr-xr-x 1 user root 2697652 2013-04-26 12:56 start.elf
-rwxr-xr-x 1 user root 3661380 2013-04-26 12:56 start_x.elf
And now I'm stumped.
Any ideas?
gkreidl
Re: rpi-update
Fri Apr 26, 2013 2:13 pm
Your boot partition is corrupted. This seems to happen, if you update from a certain version.
Different solutions have been given in the forum. Simplest one is to do a repair on a linux system. Search the forum for more information.
Minimal Kiosk Browser (kweb)
MrEngman
Re: rpi-update
Fri Apr 26, 2013 2:29 pm
There were problems with a couple of updates in March which could cause problems with later updates but it's now fixed. I found it easy to fix using my Windows laptop. More details about the problem and how to fix it here. and a bit more here.
MrEngman
billybangleballs
Re: rpi-update
Fri Apr 26, 2013 2:54 pm
Thanks Guys, I just copied the 13 files out of the boot partition to a folder on the hdd, deleted the 13 files off the sd card and then copied them back.
Unsure how this affected a cure but cure it it did.
