sorry for the bad pictures, could not get rid of the reflection!
Thank you for your time!
Thank you, I'll take a look at the cardDirkS wrote:I think it would be much better if you put the text here instead of on pastebin.
I find it very hard to read, for several reasons. The images do not show up automatically on the forum, but TBH I don't think they add anything relevant anyway.
From the bit I read I gather that you use a pre-loaded SD card. Fact is that these quite often are loaded with ancient versions of Raspbian.
I would download a current version and try again.
If you check your card in a PC you should see a disk with around 10 files on it. If it has a file called 'loader.bin' than you definitely have a card with an elderly version of Raspbian.
Gr.
Dirk.
I think the date on the files such as start.elf and bootcode.bin would be more instructive.prooney7 wrote:Thank you, I'll take a look at the cardDirkS wrote:I think it would be much better if you put the text here instead of on pastebin.
Gr.
Dirk.
