Simultaneous HDMI and Analog Video
Posted: Sun Apr 21, 2013 5:29 pm
by MarkDaniels
First, is it possible to obtain simultaneous output from both the HDMI and analog ports (same image?)
Second, can I have a separate desktop on each? Or extend the desktop onto the second monitor.
If either (or both) are possible, how would I achieve this?
Thanks.
Re: Simultaneous HDMI and Analog Video
Posted: Sun Apr 21, 2013 5:36 pm
by obcd
To my knowledge, it isn't possible to use both video outputs at the same time..
Posted: Sun Apr 21, 2013 6:50 pm
by rpdom
No. You can use HDMI or composite/RCA, not both at once.
Posted: Mon Apr 22, 2013 9:54 am
by MarkDaniels
Is this a hardware or firmware issue, then with no workaround?
If so, it looks like using a second Raspberry Pi with remote desktop and SSH into it to achieve pretty much the same result as I wanted.
Posted: Mon Apr 22, 2013 10:02 am
by RaTTuS
it is hardware - only one of the outputs is available.
if you want to run 2 screens you can have a Tau .... I mean 2 Pi.
Posted: Mon Apr 22, 2013 10:45 am
by MarkDaniels
Thanks, Rattus.
I'll have a Raspberry Tau, then! :P
