Streaming webcam over RTMP
Posted: Wed Apr 17, 2013 9:48 pm
by mchr3k
I have a Raspberry Pi and a Logitech Webcam Pro 9000 (Business edition). I am currently using (mjpg-streamer) to stream video from my Raspberry Pi.
I would now like to stream video to ustream.tv. Ustream accepts RTMP streams so I am trying to work out how to use ffmpeg/avconv to produce a correctly encoded stream.
I found (this blog post) which appeared to cover exactly my use case. However, when I run ffmpeg/avconv I get an error which I don't understand and which Google isn't shedding much light on:
raspberrypi ~ $ avconv -f video4linux2 -s 320x240 -r 1 -i /dev/video0 -metadata title="title" -f flv rtmp://ustream.video.url/
avconv version 0.8.5-6:0.8.5-1+rpi1, Copyright (c) 2000-2012 the Libav developers
  built on Jan 24 2013 08:41:09 with gcc 4.6.3
[video4linux2 @ 0xf67840] Cannot find a proper format for codec_id 0, pix_fmt -1.
/dev/video0: Input/output error
I also tried using a source codec of mjpeg and got the following error:
raspberrypi ~ $ avconv -an -f mjpeg -s 320x240 -r 1 -i /dev/video0 -metadata title="title" -f flv rtmp://ustream.video.url/
Option video_size not found.
Can anyone help me with either of these errors?
Re: Streaming webcam over RTMP
Posted: Thu Apr 02, 2015 12:12 am
by squirrel534
Did you ever find a solution to this problem? I am trying to investigate streaming to Youtube, and Ustream and finding similar problems
Posted: Fri Feb 08, 2019 3:43 pm
by JGwinner
I'm trying to make a webcam out of motion, and I think 1280x720 is too much.
I tried running ffmpeg manually and ran into the same error. DuckDuckGo hasn't found many answers either.
ffmpeg -s 320x180 -i rtsp://192.168.0.213:8554/unicast testmpeg2.avi
pi@pib:~/motiontest $ ffmpeg -s 320x180 -i rtsp://192.168.0.213:8554/unicast testmpeg2.avi
ffmpeg version 3.2.12-1~deb9u1+rpt1 Copyright (c) 2000-2018 the FFmpeg developers
Did you solve your problem?
