Smoot187
Wifi works but is not seen?
Tue Apr 09, 2013 9:26 pm
I have done a search and am almost sure this has not been asked before, especially since it is sort of an obscure problem, but one I have had with both of my Pi's so far. Model B, standard Raspbian install.
I can connect an ethernet cable, browse the web (on the pi), VNC, ssh, etc.
I have connected the wifi dongle (standard TP-link one that comes in a bundle) and scan, connect to my wireless network ok.
I can turn the pi off, restart it and it will automatically connect to the wireless network (after auto logging in and booting to the desktop) which is great.. IF I wanted to use the pi as a working machine, but I would like it to be headless, or at least independant enough that I can move it away from my office (downstairs, outside etc)
the problem is that when connected via wifi, I cannot ssh in, or ping, VNC or anything. It is like it does not exist, my IP scanner does not even pick it up - therefore making it pretty useless :(
Is this something that someone has came across before?
(I also had the exact same problem with a previous Pi running xbmc - I thought it could be my router, but there is nothing random in the config that would warrant this behaviour)
Many thanks!
pjc123
Re: Wifi works but is not seen?
Wed Apr 10, 2013 11:50 am
OK. Two things to check.
1) First make sure that you have the following lines in your /etc/network/interfaces file for whatever wireless interface you are using (wlan0, wlan1, etc.). Then reboot to try it out.
auto wlan0
allow-hotplug wlan0
wireless-power off
2) Otherwise, I have a post which may be the same problem.
http://www.raspberrypi.org/phpBB3/viewt ... 5&p=316193
Now I wasn't able to find the cause, but I was able to fix the symptom. I run a script that checks every 15 seconds that an ip has been issued, and if not, resets the wireless interface. I have got it to the point that my headless pi boots with an ip 100% of the time now. I never tried to run it just once at boot because I don't know if it would catch a "no ip" condition in just one shot, but certainly you could extend the check to every minute or so, if a longer wait is acceptable. I just left it that way because of so many posts indicating that their connection was lost randomly.
I found a script to do this, but it did not work for a couple of reasons, which I fixed:
1) I needed to add the full path to the ifconfig, ifdown and ifup commands.
2) The ifconfig method that was used just did not work, so I changed it to a ping check.
Here is that thread:
http://www.raspberrypi.org/phpBB3/viewt ... 26&t=16054
Now, my TP-Link is probably a different model than yours because I doubt they would pack it in a bundle, but maybe it has the same chipset and that may be the common denominator. What model do you have?
My Raspberry Pi Project Page:
https://www.flaminghellmet.com/launch/
