jnivard
set up video stream
Tue Apr 09, 2013 1:01 pm
I try to follow instruction to start a video stream. But it seems that the library I install is not available
who had a answere?
sudo aptitude install libv4l-0
John
robinjoo1
Re: set up video stream
Tue Apr 09, 2013 1:22 pm
try apt-get update and then apt-get upgrade and finnally apt-get dist-upgrade
jnivard
Tue Apr 09, 2013 1:50 pm
That is not helping could not find any package whose name match libv41-0
etc
robinjoo1
Tue Apr 09, 2013 2:48 pm
what are your repostitories?
Tue Apr 09, 2013 3:05 pm
What are you trying to do with those libraries?
jnivard
Tue Apr 09, 2013 3:36 pm
I use the standard immage of raspberry PI and I am not shure what you mean with repostitories. I do not know how I can find out what the standard repostitories are
My goal is to add vision to my robot and I need I video stream and read it into python3. The plan is :
1-With a cheap web camera that connects to USB video streaming can be done in just a few easy steps, with a Raspberry PI . The simplicity of the solution comes from the streaming technology used effectively. Everything happens over HTTP , so you can watch the Webcam on any device that surfs the web see http://www.talktech.info/2013/01/21/pie ... ng-webcam/
2-Read the frames intp Python and analyse them
It is not new and I do not understand the problem I encounter now
John
jnivard
Tue Apr 09, 2013 4:01 pm
The rep is :
deb http://mirrirdirector.raspbian.org/raspbian/ wheezy main contrib non-free rpi
Thanks for yoyr attention
John
sundew
Sun Jun 30, 2013 10:20 am
make sure you use lower case 'L' for 'l'.
libv4l-0
fnibble
Tue Jan 14, 2014 11:14 pm
Can anybody please update the rep position for libv41 because I cant find it at stated
http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free rpi
this tree does not seem to exist. I have the same videodev.h problem. Thanks
fnibble
Wed Jan 15, 2014 3:53 pm
Here is what works to get videodev.h into raspberry pi raspbian for webcam
Posted by Piotrus
http://stackoverflow.com/questions/1569 ... videodev-h
sudo apt-get install libv4l-dev
maybe you will need also:
cd /usr/include/linux
sudo ln -s ../libv4l1-videodev.h videodev.h
run as root without sudo in commands it loads a copy of videodev.h into /usr/include/linux
Whether that then runs ok I do not know yet.
