JelleS
Re: SD card starting to bend
Fri Aug 01, 2014 12:14 am
I juist ran in to the same problem. Will any microsd adapter solve this (because they are stronger)? That's what I seem to understand from most of the posts here. :?:
redhawk
Fri Aug 01, 2014 9:01 am
JelleS wrote:I juist ran in to the same problem. Will any microsd adapter solve this (because they are stronger)? That's what I seem to understand from most of the posts here. :?:
If you've seen my post then you'll know that no memory card is safe not even Micro SD adapters although the Micro SD card inside would be unaffected.
Richard S.
JelleS
Fri Aug 01, 2014 9:12 am
redhawk wrote: If you've seen my post then you'll know that no memory card is safe not even Micro SD adapters although the Micro SD card inside would be unaffected.
Richard S.
I feared as much... But at least yours lasted for 2 years. Mine is bend after a mere 4-5 months. I think I might try the suggestion of the link explaining how to 'repair' the sd card slot, adding what I hope is sufficient support for preventing the sd cards to bend.
I also took a look at the adafruit adapter (http://www.adafruit.com/products/966), which is thicker and therefore probably stronger which would hopefully make it last longer, but they don't sell it anywhere near here (Belgium) which means I'd have to pay $25 to get a $6 sd card adapter...
AndrewS
Fri Aug 01, 2014 2:43 pm
JelleS wrote:I also took a look at the adafruit adapter (http://www.adafruit.com/products/966), which is thicker and therefore probably stronger which would hopefully make it last longer, but they don't sell it anywhere near here (Belgium) which means I'd have to pay $25 to get a $6 sd card adapter...
Did you have a look at http://www.adafruit.com/distributors ? ;)
JelleS
Fri Aug 01, 2014 2:46 pm
Well I'll be damned. Thanks!
tmxim
Sun Aug 24, 2014 4:47 pm
Hi there,
I know it's no the perfect solution but we needed a quick solution to the bending problem. You only need the stick you use for stiring your vending machine coffe. Here's a picture of what we've done and all bent SD trascend cards started booting up again:
http://imgur.com/EfSFOQY
But remember that it's always better to have the money back because of a faulty product.
Hope this helps!
Regards from Spain.
Piminiuser
Mon Aug 25, 2014 3:06 pm
1 Dollar fix: http://raspberrypihelp.net/tutorials/56 ... ed-sd-card
Switch from SD to micro SD and use this 1 dollar adapter :)
RSvedman
Sun Sep 07, 2014 7:31 pm
I did the credit card + superglue trick which worked perfectly, thanks for that tip. I doubled my card in the middle so it presses evenly on the entire back of the sd card, and used Loctite super attack (3 second cyanoacrylate glue). I just bought a B+ to be the new living room retrogamer throwaround setup, with the micro slot and four usb:s that will be awesome; less risk of card damage and less cable salad due to no more external usb hub needed (combined wireless mouse&kbd, wlan stick and two joysticks fits perfectly in four jacks)
