Hi All,
My rpi stoped booting recently with no obvious reson. I have a headless setup so my options are rather limited. As I understand the main indicator of problems is the OK LED on board, so right after I power the board it lights up for about a second and then goes off, a few seconds later OK LED start blinking with absolutely no patters (as hdd led might blink on read and write) and then after couple of seconds it stops and never on again.
I also tried to check the logs on SD card. I deleted all the logs with created in 1969 and tried to boot, no new logs were created, so I assume it never get to the point of acctualy booting the os.
does that mean I have some sort of hardware failure or is it anything else? As I said I have a headless setup and no hdmi display to check what's going on there.
thank you
