No boot with some images
Posted: Thu Apr 04, 2013 8:46 am
Dear fellows,
This is the experience I would like to share with you, after 2 weeks of Raspberry Pi testing, with hue entusiasm - and frustration as well.
To make the story short: writing images with Raspbian Wheezy and OpenElec were successfull operations, while it failed constantly with Bodhi Linux.
- The issue does not come from the writer: it failed always on Bodhi, never on Raspbian or OpenElec.
- The issue does not come from the SD cards: I use a set of 3, all failed with Bodhi, all succeeded with Raspbian and OpenElec.
- The issue does not come from the method: I used Win32 Image Writer on Windows 7 and DD command line under Linux. Both methods always succeeded with Raspbian and OpenElec, and always failed with Bodhi.
The conclusion is quite clear: the issue must come from the IMG file from Bodhi. But strangely, nobody seems to complain about this, according to a search through dedicated forums... The downloaded file was not corrupted (MD5 check), though, and the writing process always ended up with a success notification from Image Writer and DD.
I realized that the VFAT partition witten on the SDE card was flagged only as LBA - not BOOT. Changing this with GParted had no effect.
Is it possible that the issue could come from the files used for the creation of VFAT partition (kernel.img, start.elf, etc.)? Maybe that Bodhi was correct by the time of the creation of the image found for Raspberry Pi on their website, but that it's not compatible anymore with the Raspberry Pi bought 2 weeks ago (change in the firmware, something like that)?
Comparing the 3 VFAT partitions of the 3 systems written on SD cards shows that kernel.img is the only similar file (same size exactly). All others are different.
Does anybody encounter identical issues when testing several systems, and have an idea for a solution?
Thanks for your feedback
