dom
Re: USB FIQ testing....
Thu May 23, 2013 4:42 pm
piglet wrote:Ahh - I wonder whether I need to redo that then.
I'll re-fiq-rpi-update and test for the error before I box up the bits and send to you over the weekend. No point in wasting your time if your changes have simply been lost on my pi by an apt-get update&upgrade. I may well have done one.
You can check for the fiq_split being enabled in dmesg log:
[    1.768790] dwc_otg: FIQ enabled
[    1.768802] dwc_otg: NAK holdoff enabled
[    1.768809] dwc_otg: FIQ split fix enabled
kalehrl
Thu May 23, 2013 6:06 pm
dom wrote:
kalehrl wrote:It seems it is not possible to update software and retain this kernel.
When I run sudo apt-get update && sudo apt-get upgrade, I get librasperrypi and other firmware packages which replace the latest kernel.
Yes.
sudo rm /boot/.firmware_revision && sudo BRANCH=fiq_split rpi-update
will force it back onto that kernel.
What I meant was, is it possible to upgrade all packages except the kernel because I would like to stay on fiq_split kernel while regularly upgrading all other packages?
piglet
Thu May 23, 2013 7:25 pm
dom wrote:You can check for the fiq_split being enabled in dmesg log:...
Thanks. I checked. It wasn't. Re-fiq-rpi-updated.
All is well. Keyboard works perfectly again. However many times I type in "the quick brown fox jumps over the lazy dog".
I didn't think that apt-get upgrade would overwrite Gordon's code. :oops:
Will it get merged into the main trunk soon?
gsh
Fri May 24, 2013 7:47 pm
So today I spent quite a bit of time working on the FIQ implementation to see if I could fix the long standing dequeuing issue...
It looks like the problem is being caused when a qh gets dequeued whilst it is sat in the non_periodic_assigned list. The actual case looks like the IRQ is coming in and causing the qh to be removed from the queue whilst the kernel thread is calling into the dequeue function...
Or something... I've still got a long way to go, but I'm fairly sure it's to do with getting an interrupt at an inopportune moment...
More debug necessary!
Gordon
Gordon Hollingworth PhD
jbeale
Fri May 24, 2013 9:03 pm
Thanks for the update. I think there will be a long line of people waiting to heap praises upon you, if you can manage to fix it!
sandygmaharaj
Mon May 27, 2013 1:49 pm
Hi All
I am trying to get pjsip working on Raspberry pi. I want to get one way video from Rpi to any other sip client and two-way audio communication. My initial setup included usb wifi nano module. Logitech C310 connected on 2nd USB port. Call could easily get through but there was no exchange of audio/video. I took tcpdump and could see that Rpi was overwhelmed with audio packets being sent from the other SIP client. I upgraded my firmware to FIQ_split branch, removed USB wifi and instead plugged wired LAN but unfortunately there is still no improvement. Rpi still seem to be overwhelmed with the audio packets (Although, I still can not hear anything from audio output from Rpi). Could anybody help in debugging this further? I think this issue might be related to this thread.
TIA
agentsmithitaly
Mon May 27, 2013 6:12 pm
Hi to all,
I had the "sticky" keys issue with a brand new Microsoft Wireless Desktop 800, and this fix completely solved the issue on latest Raspbian. So far I didn't encounter any stability problems even when overclocked with Turbo profile.
Now I have to find if it's possible to apply this fix to Raspbmc...
gsh
Tue May 28, 2013 7:29 pm
Found a fix today for the dequeuing issue...
This should be interesting for anyone having trouble with the USB dropping out and ending up with errors from the smsc9512 ethernet
Also people who're opening / closing USB serial dongles...
Will check in tomorrow...
Gordon
sbp
Wed May 29, 2013 4:24 am
Hi Gordon thank you for this.
Your previous change solved many of the problems that we had with external USB dacs.
Currently, some still experience pops and clicks occasionally with some of the USB dacs, do you think that the latest change could help with these issues?
piCorePlayer webpage: https://sites.google.com/site/picoreplayer/home
gsh
Wed May 29, 2013 8:11 am
sbp wrote: Your previous change solved many of the problems that we had with external USB dacs.
No this change would not effect that, this specifically is about opening / closing the USB devices which causes the URBs submitted to the driver to be dequeued. Each time this happens there is a finite probability that the channel that is in use gets lost... Once you get down to 0 channels left then the USB will stop working completely.
Gordon
gsh
Wed May 29, 2013 8:14 am
Also, could you tell me what DACs you are experiencing the problem with and how to reproduce the issue (need a full and clear description of every step you use to reproduce the problem, including versions of software, everything you have running etc. The best way to do this is to start again with a new Raspbian release, update to the fiq_split branch and then run your test)
Gordon
gsh
Wed May 29, 2013 2:20 pm
For those interested,
I have now checked in a new fix for the dequeuing issue this will effect things like the usb serial devices where people are opening / closing the device over and over...
It may also have explained some issues with wifi devices running particular scripts that open / close the USB device occasionally.
Specifically there was an error seen like the following which will get output when this bug is triggered...
smsc95xx 1-1.1:1.0: eth0: Failed to write register index 0x00000014
So if you see this then it may be caused by this dequeuing bug...
To update use:
Gordon
dom
Wed May 29, 2013 2:36 pm
gsh wrote: To update use:
But not yet... just building...
...okay, updated now. Please test.
kalehrl
Wed May 29, 2013 6:05 pm
I don't see any recent commits here:
https://github.com/Hexxeh/rpi-firmware/ ... /fiq_split
Since migrating to this kernel, I get:
May 29 20:00:17 raspberrypi kernel: [   39.484014] mmc0: final write to SD card still running
May 29 20:00:27 raspberrypi kernel: [   49.450376] mmc0: Timeout waiting for hardware interrupt - cmd12.
May 29 20:00:27 raspberrypi kernel: [   49.451538] mmcblk0: error -110 sending stop command, original cmd response 0x900, card status 0x900
at the end of kern.log after booting.
dom
Wed May 29, 2013 6:42 pm
kalehrl wrote:I don't see any recent commits here:
Ah yes, not pushed - try now.
ddv2005
Wed May 29, 2013 8:12 pm
dom wrote:...okay, updated now. Please test.
open_playback: Open playback device 'plughw:CARD=Set,DEV=0'
open_playback: set format SND_PCM_FORMAT_S16_LE
open_playback: set channels: 1
open_playback: set clock rate: 16000
open_playback: clock rate set to: 16000
open_playback: set period size: 320
open_playback: period size set to: 320
open_playback: buffer size set to: 2240
open_playback: playback_latency set to: 140 ms
Message from [email protected] at May 29 20:11:06 ...
 kernel:[  281.335164] Internal error: Oops - BUG: 0 [#1] PREEMPT ARM
 kernel:[  281.429026] Process auddemo (pid: 1598, stack limit = 0xdc8461b0)
 kernel:[  281.437738] Stack: (0xdc847cd0 to 0xdc848000)
 kernel:[  281.444663] 7cc0:                                     dc847ccc 00008020 00000000 dc846000
 kernel:[  281.457965] 7ce0: 00000000 00000001 a0000013 dd800240 00008020 dd95b880 ddbff7a0 00000001
 kernel:[  281.471283] 7d00: dc9e80e0 c00c2568 00000000 00000001 00000006 00000098 00000001 c02c555c
 kernel:[  281.484607] 7d20: 00000000 c00166f4 dc847d34 00000001 dd95b880 dc9e80e8 dd967800 c02c5db4
 kernel:[  281.497986] 7d40: c09f2100 c0016764 dc847d6c ffffffff 00000000 00001000 ddbff7b8 00000000
 kernel:[  281.511563] 7d60: 00000000 000000a2 dc967920 dc9e80e0 dd95b880 dc9e80e8 00000000 c0554008
 kernel:[  281.525225] 7d80: dc9e80e0 00000020 be94d5fc c029fcdc dc9e86e0 c0017088 00000247 00000000
 kernel:[  281.538922] 7da0: cccccccd dc878000 dc9e8130 000000f0 00000006 794e3e01 00008400 dc878000
 kernel:[  281.552821] 7dc0: 00000000 dc878000 00002958 0000296c dc9e80e0 0000298c be94d5fc bf0a2164
 kernel:[  281.566896] 7de0: 00000003 dc87a95c dda815a0 dda5a610 dc80c400 00000001 dc878000 00002990
 kernel:[  281.581193] 7e00: dc846000 00002988 be94d5fc bf0a8250 00000000 ddab85c8 dda5a610 dc80c400
 kernel:[  281.595691] 7e20: 00000000 bf0a9ad8 0000bb80 dda815a0 00000000 00000000 00000000 00000000
 kernel:[  281.610277] 7e40: 00000000 00000000 00000000 00000000 000003c0 00000000 00000000 dda53400
 kernel:[  281.624994] 7e60: dda53400 00000002 00000000 ddab85c8 dc846000 b6ece000 be94d5fc bf0622f8
 kernel:[  281.639846] 7e80: bf06b064 bf061c14 dda534d4 dda53400 bf06b064 00000002 00000002 bf061ff8
 kernel:[  281.654699] 7ea0: 00000000 dda53400 dda5abd8 bf0633ec ddb685b0 c021d400 dc846000 dc949498
 kernel:[  281.669552] 7ec0: ddbb14a8 ddab86a4 ddbb14ac c00b1764 ddb079a0 00004140 dda53400 00000004
 kernel:[  281.684399] 7ee0: b6ece000 ddab85c8 dc846000 b6ece000 be94d5fc bf063ed8 ddbb14a8 00000000
 kernel:[  281.699232] 7f00: ddb294e0 00000000 00000000 00000000 00000001 00004140 ddb294e0 00000004
 kernel:[  281.714069] 7f20: b6ece000 c00d6cd4 00000001 80000013 00000000 ddb079d8 b6ca4000 00000001
 kernel:[  281.728899] 7f40: ddb294e0 00000003 00000000 00007000 00000020 c00a6308 040400fb 00000000
 kernel:[  281.743735] 7f60: 00000001 00000003 00004140 00000004 00000000 b6ece000 ddb294e0 dc846000
 kernel:[  281.758572] 7f80: 00000000 c00d725c 50b17b15 00000000 0006dee0 00171040 be94d370 00000036
 kernel:[  281.773420] 7fa0: c000dc28 c000da80 0006dee0 00171040 00000004 00004140 b6ece000 b6e600fc
 kernel:[  281.788271] 7fc0: 0006dee0 00171040 be94d370 00000036 0017296c 0000dd80 00172908 be94d5fc
 kernel:[  281.803117] 7fe0: 0000dc38 be94d2f8 b6e60118 b6d7653c 20000010 00000004 1dff5821 1dff5c21
 kernel:[  282.080690] Code: e3520000 0affffbb eb0c19f0 eaffffb9 (e7f001f2)
kalehrl
Thu May 30, 2013 1:33 pm
I have much more of these errors than with the previous commit:
May 30 15:17:15 raspberrypi kernel: [ 39.424226] mmc0: final write to SD card still running
May 30 15:17:25 raspberrypi kernel: [ 49.450754] mmc0: Timeout waiting for hardware interrupt - cmd12.
May 30 15:17:25 raspberrypi kernel: [ 49.451916] mmcblk0: error -110 sending stop command, original cmd response 0x900, card status 0x900
Here is today's kern.log snippet:
kern.log_snippet.zip
(14.63 KiB) Downloaded 171 times
PeterO
Mon Jun 03, 2013 11:14 am
gsh wrote:For those interested,
To update use:
Gordon
I tried this yesterday, and it has made a Sound-Blaster X-Fi Surround 5.1 Pro usable :-) Previously it had lots of drop outs and clicks. Now I hope this fix will quickly find its way into raspbmc.
PeterO
Mysterious
Fri Jun 07, 2013 10:33 pm
I tried this yesterday, and it has made a Sound-Blaster X-Fi Surround 5.1 Pro usable Previously it had lots of drop outs and clicks. Now I hope this fix will quickly find its way into raspbmc.
I thought that the "Sound-Blaster X-Fi Surround 5.1 Pro" chipset might be similar to my "Sound-Blaster X-Fi HD" one's. Obviously it isn't... I am still having distortions in my sound.
Anyways I wonder how your card got fixed since most cards are using isochronous data transmission instead of fiq related transmission....
@Gordon
Are you satisfied with the state of the fiq implementation and ready to move on to isochronous concerns?
If so I would like to provide any information I can to fix audio distortions.
Just let us know what kind of logs and information you need.
Regards
Mysterious
p.s.: The driver has been improved a lot, thanks so far and good luck for the other issues.
M33P
Sun Jun 09, 2013 8:56 am
Full-speed devices using Isochronous endpoints will still need to use split transactions (which work a bit wierdly with a hub's transaction translator - a 1023 byte packet gets split up into packets of <188 bytes) so the more precise scheduling achievable with the fiq is likely to improve the reliability of data transmission.
Can you post a lsusb -v for your device and sample dmesg output from when you plug the device in within
 tags?
Mysterious
Sun Jun 09, 2013 10:59 pm
here you are:
lsusb -v
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0 Unused
  bDeviceProtocol         2 TT per port
  bMaxPacketSize0        64
  idVendor           0x0424 Standard Microsystems Corp.
  idProduct          0x9512
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceSubClass      0 Unused
      bInterfaceProtocol      1 Single TT
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0001  1x 1 bytes
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      bInterfaceProtocol      2 TT per port
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             3
  wHubCharacteristic 0x000d
    Per-port power switching
    Compound device
    Per-port overcurrent protection
    TT think time 8 FS bits
  bPwrOn2PwrGood       50 * 2 milli seconds
  bHubContrCurrent      1 milli Ampere
  DeviceRemovable    0x02
  PortPwrCtrlMask    0xff
 Hub Port Status:
   Port 1: 0000.0503 highspeed power enable connect
   Port 2: 0000.0303 lowspeed power enable connect
   Port 3: 0000.0103 power enable connect
Device Qualifier (for other device speed):
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceProtocol         0 Full speed (or root) hub
  bMaxPacketSize0        64
Device Status:     0x0001
  Self Powered
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceProtocol         1 Single TT
  bMaxPacketSize0        64
  idVendor           0x1d6b Linux Foundation
  idProduct          0x0002 2.0 root hub
  bcdDevice            3.08
  iManufacturer           3 Linux 3.8.13+ dwc_otg_hcd
  iProduct                2 DWC OTG Controller
  iSerial                 1 bcm2708_usb
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceProtocol      0 Full speed (or root) hub
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
  wHubCharacteristic 0x0008
    Ganged power switching
  bPwrOn2PwrGood        1 * 2 milli seconds
  bHubContrCurrent      0 milli Ampere
  DeviceRemovable    0x00
 Hub Port Status:
  Self Powered
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          255 Vendor Specific Class
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  idProduct          0xec00
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           39
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           3
      bInterfaceClass       255 Vendor Specific Class
      bInterfaceProtocol    255
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0010  1x 16 bytes
        bInterval               4
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  Self Powered
Bus 001 Device 004: ID 0e8f:0022 GreenAsia Inc.
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x0e8f GreenAsia Inc.
  idProduct          0x0022
  bcdDevice            2.10
  iManufacturer           1 GASIA
  iProduct                2
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           59
    bNumInterfaces          2
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         3 Human Interface Device
      bInterfaceSubClass      1 Boot Interface Subclass
      bInterfaceProtocol      1 Keyboard
      iInterface              0
        HID Device Descriptor:
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bCountryCode            0 Not supported
          bNumDescriptors         1
          bDescriptorType        34 Report
          wDescriptorLength      62
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0008  1x 8 bytes
        bInterval              10
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceSubClass      0 No Subclass
      bInterfaceProtocol      0 None
      iInterface              1 GASIA
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bNumDescriptors         1
          wDescriptorLength      71
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0003  1x 3 bytes
        bInterval              10
Device Status:     0x0000
  (Bus Powered)
Mysterious
Sun Jun 09, 2013 11:00 pm
Bus 001 Device 006: ID 041e:30d7 Creative Technology, Ltd
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x041e Creative Technology, Ltd
  idProduct          0x30d7
  bcdDevice            1.00
  iManufacturer           1 Creative Technology
  iProduct                2 USB Sound Blaster HD
  iSerial                 3 000009tF
    bLength                 9
    bDescriptorType         2
    wTotalLength         1281
    bNumInterfaces          6
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              500mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         1 Audio
      bInterfaceSubClass      1 Control Device
      iInterface              0
      AudioControl Interface Descriptor:
        bLength                12
        bDescriptorType        36
        bDescriptorSubtype      1 (HEADER)
        bcdADC               1.00
        wTotalLength          139
        bInCollection           4
        baInterfaceNr( 0)       1
        baInterfaceNr( 1)       2
        baInterfaceNr( 2)       3
        baInterfaceNr( 3)       4
        bLength                12
        bDescriptorType        36
        bDescriptorSubtype      2 (INPUT_TERMINAL)
        bTerminalID             1
        wTerminalType      0x0101 USB Streaming
        bAssocTerminal          0
        bNrChannels             2
        wChannelConfig     0x0003
          Left Front (L)
          Right Front (R)
        iChannelNames           0
        iTerminal               0
        bLength                10
        bDescriptorType        36
        bDescriptorSubtype      6 (FEATURE_UNIT)
        bUnitID                 2
        bSourceID               1
        bControlSize            1
        bmaControls( 0)      0x01
          Mute Control
        bmaControls( 1)      0x02
          Volume Control
        bmaControls( 2)      0x02
          Volume Control
        iFeature                0
        bLength                 9
        bDescriptorType        36
        bDescriptorSubtype      3 (OUTPUT_TERMINAL)
        bTerminalID             3
        wTerminalType      0x0301 Speaker
        bAssocTerminal          0
        bSourceID               2
        iTerminal               0
        bLength                12
        bDescriptorType        36
        bTerminalID             4
        bAssocTerminal          0
        bNrChannels             2
          Left Front (L)
          Right Front (R)
        iChannelNames           0
        iTerminal               0
        bLength                 9
        bDescriptorType        36
        bTerminalID             6
        wTerminalType      0x0602 Digital Audio Interface
        bAssocTerminal          0
        bSourceID               4
        iTerminal               0
        bLength                12
        bDescriptorType        36
        bTerminalID            10
        wTerminalType      0x0201 Microphone
        bAssocTerminal          0
        bNrChannels             2
          Left Front (L)
          Right Front (R)
        iChannelNames           0
        iTerminal               0
        bLength                12
        bDescriptorType        36
        bTerminalID            12
        wTerminalType      0x0603 Line Connector
        bAssocTerminal          0
        bNrChannels             2
          Left Front (L)
          Right Front (R)
        iChannelNames           0
        iTerminal               0
        bLength                12
        bDescriptorType        36
        bTerminalID            14
        wTerminalType      0x0708 Phonograph
        bAssocTerminal          0
        bNrChannels             2
          Left Front (L)
          Right Front (R)
        iChannelNames           0
        iTerminal               0
        bLength                 9
        bDescriptorType        36
        bDescriptorSubtype      5 (SELECTOR_UNIT)
        bUnitID                16
        bNrInPins               3
        baSource( 0)           10
        baSource( 1)           12
        baSource( 2)           14
        iSelector               0
        bLength                 9
        bDescriptorType        36
        bTerminalID            17
        bAssocTerminal          0
        bSourceID              16
        iTerminal               0
        bLength                12
        bDescriptorType        36
        bTerminalID             7
        wTerminalType      0x0605 SPDIF interface
        bAssocTerminal          0
        bNrChannels             2
          Left Front (L)
          Right Front (R)
        iChannelNames           0
        iTerminal               0
        bLength                 9
        bDescriptorType        36
        bTerminalID             9
        bAssocTerminal          0
        bSourceID               7
        iTerminal               0
        bLength                 9
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0002  1x 2 bytes
        bInterval              10
        bRefresh                0
        bSynchAddress           0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceSubClass      2 Streaming
      iInterface              0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           2
      iInterface              0
      AudioStreaming Interface Descriptor:
        bLength                 7
        bDescriptorType        36
        bDescriptorSubtype      1 (AS_GENERAL)
        bTerminalLink           1
        bDelay                  0 frames
        wFormatTag              1 PCM
        bLength                11
        bDescriptorType        36
        bDescriptorSubtype      2 (FORMAT_TYPE)
        bFormatType             1 (FORMAT_TYPE_I)
        bNrChannels             2
        bSubframeSize           2
        bBitResolution         16
        bSamFreqType            1 Discrete
        tSamFreq[ 0]        48000
        bLength                 9
        bDescriptorType         5
        bEndpointAddress     0x01  EP 1 OUT
        bmAttributes            5
          Transfer Type            Isochronous
          Synch Type               Asynchronous
          Usage Type               Data
        wMaxPacketSize     0x00c4  1x 196 bytes
        bInterval               1
        bRefresh                0
        bSynchAddress           1
        AudioControl Endpoint Descriptor:
          bLength                 7
          bDescriptorType        37
          bDescriptorSubtype      1 (EP_GENERAL)
          bmAttributes         0x00
          bLockDelayUnits         0 Undefined
          wLockDelay              0 Undefined
        bLength                 9
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               1
        bRefresh                5
        bSynchAddress           0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       2
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bTerminalLink           1
        bDelay                  0 frames
        wFormatTag              1 PCM
        bLength                11
        bDescriptorType        36
        bNrChannels             2
        bSubframeSize           3
        bBitResolution         24
        tSamFreq[ 0]        48000
        bLength                 9
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0126  1x 294 bytes
        bInterval               1
        bRefresh                0
        bSynchAddress           1
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x00
        bLength                 9
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               1
        bRefresh                5
        bSynchAddress           0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       3
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bTerminalLink           1
        bDelay                  0 frames
        wFormatTag              1 PCM
        bLength                11
        bDescriptorType        36
        bNrChannels             2
        bSubframeSize           2
        bBitResolution         16
        tSamFreq[ 0]        96000
        bLength                 9
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0184  1x 388 bytes
        bInterval               1
        bRefresh                0
        bSynchAddress           1
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x00
        bLength                 9
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               1
        bRefresh                5
        bSynchAddress           0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       4
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bTerminalLink           1
        bDelay                  0 frames
        wFormatTag              1 PCM
        bLength                11
        bDescriptorType        36
        bNrChannels             2
        bSubframeSize           3
        bBitResolution         24
        tSamFreq[ 0]        96000
        bLength                 9
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0246  1x 582 bytes
        bInterval               1
        bRefresh                0
        bSynchAddress           1
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x00
        bLength                 9
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               1
        bRefresh                5
        bSynchAddress           0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       1
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bTerminalLink           4
        bDelay                  0 frames
        wFormatTag              1 PCM
        bLength                11
        bDescriptorType        36
        bNrChannels             2
        bSubframeSize           2
        bBitResolution         16
        tSamFreq[ 0]        44100
        bLength                 9
        bDescriptorType         5
        bEndpointAddress     0x04  EP 4 OUT
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x00b4  1x 180 bytes
        bInterval               1
        bRefresh                0
        bSynchAddress           4
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x00
        bLength                 9
        bDescriptorType         5
        bEndpointAddress     0x84  EP 4 IN
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               1
        bRefresh                5
        bSynchAddress           0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       2
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bTerminalLink           4
        bDelay                  0 frames
        wFormatTag              1 PCM
        bLength                11
        bDescriptorType        36
        bNrChannels             2
        bSubframeSize           3
        bBitResolution         24
        tSamFreq[ 0]        44100
        bLength                 9
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x010e  1x 270 bytes
        bInterval               1
        bRefresh                0
        bSynchAddress           4
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x00
        bLength                 9
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               1
        bRefresh                5
        bSynchAddress           0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       3
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bTerminalLink           4
        bDelay                  0 frames
        wFormatTag              1 PCM
        bLength                11
        bDescriptorType        36
        bNrChannels             2
        bSubframeSize           2
        bBitResolution         16
        tSamFreq[ 0]        48000
        bLength                 9
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
        bRefresh                0
        bSynchAddress           4
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x00
        bLength                 9
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               1
        bRefresh                5
        bSynchAddress           0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       4
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bTerminalLink           4
        bDelay                  0 frames
        wFormatTag              1 PCM
        bLength                11
        bDescriptorType        36
        bNrChannels             2
        bSubframeSize           3
        bBitResolution         24
        tSamFreq[ 0]        48000
        bLength                 9
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
        bRefresh                0
        bSynchAddress           4
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x00
        bLength                 9
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               1
        bRefresh                5
        bSynchAddress           0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       5
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bTerminalLink           4
        bDelay                  0 frames
        wFormatTag              1 PCM
        bLength                11
        bDescriptorType        36
        bNrChannels             2
        bSubframeSize           2
        bBitResolution         16
        tSamFreq[ 0]        96000
        bLength                 9
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
        bRefresh                0
        bSynchAddress           4
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x00
        bLength                 9
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               1
        bRefresh                5
        bSynchAddress           0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       6
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bTerminalLink           4
        bDelay                  0 frames
        wFormatTag              1 PCM
        bLength                11
        bDescriptorType        36
        bNrChannels             2
        bSubframeSize           3
        bBitResolution         24
        tSamFreq[ 0]        96000
        bLength                 9
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
        bRefresh                0
        bSynchAddress           4
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x00
        bLength                 9
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               1
        bRefresh                5
        bSynchAddress           0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       7
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bTerminalLink           4
        bDelay                  0 frames
        wFormatTag           8193 IEC1937_AC-3
        bLength                11
        bDescriptorType        36
        bFormatType             3 (FORMAT_TYPE_III)
        bNrChannels             2
        bSubframeSize           2
        bBitResolution         16
        tSamFreq[ 0]        44100
        bLength                 9
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
        bRefresh                0
        bSynchAddress           4
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x00
        bLength                 9
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               1
        bRefresh                5
        bSynchAddress           0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       8
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bTerminalLink           4
        bDelay                  0 frames
        bLength                11
        bDescriptorType        36
        bNrChannels             2
        bSubframeSize           2
        bBitResolution         16
        tSamFreq[ 0]        48000
        bLength                 9
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
        bRefresh                0
        bSynchAddress           4
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x00
        bLength                 9
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               1
        bRefresh                5
        bSynchAddress           0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bTerminalLink          17
        bDelay                  0 frames
        wFormatTag              1 PCM
        bLength                11
        bDescriptorType        36
        bNrChannels             2
        bSubframeSize           2
        bBitResolution         16
        tSamFreq[ 0]        48000
        bLength                 9
        bDescriptorType         5
        bmAttributes           37
          Usage Type               Implicit feedback Data
        bInterval               1
        bRefresh                0
        bSynchAddress           0
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x00
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       2
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bTerminalLink          17
        bDelay                  0 frames
        wFormatTag              1 PCM
        bLength                11
        bDescriptorType        36
        bNrChannels             2
        bSubframeSize           3
        bBitResolution         24
        tSamFreq[ 0]        48000
        bLength                 9
        bDescriptorType         5
        bmAttributes           37
        bInterval               1
        bRefresh                0
        bSynchAddress           0
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x00
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       3
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bTerminalLink          17
        bDelay                  0 frames
        wFormatTag              1 PCM
        bLength                11
        bDescriptorType        36
        bNrChannels             2
        bSubframeSize           2
        bBitResolution         16
        tSamFreq[ 0]        96000
        bLength                 9
        bDescriptorType         5
        bmAttributes           37
        bInterval               1
        bRefresh                0
        bSynchAddress           0
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x00
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       4
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bTerminalLink          17
        bDelay                  0 frames
        wFormatTag              1 PCM
        bLength                11
        bDescriptorType        36
        bNrChannels             2
        bSubframeSize           3
        bBitResolution         24
        tSamFreq[ 0]        96000
        bLength                 9
        bDescriptorType         5
        bmAttributes           37
        bInterval               1
        bRefresh                0
        bSynchAddress           0
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x00
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bTerminalLink           9
        bDelay                  0 frames
        wFormatTag              1 PCM
        bLength                11
        bDescriptorType        36
        bNrChannels             2
        bSubframeSize           2
        bBitResolution         16
        tSamFreq[ 0]        44100
        bLength                 9
        bDescriptorType         5
        bEndpointAddress     0x85  EP 5 IN
        bmAttributes           37
        bInterval               1
        bRefresh                0
        bSynchAddress           0
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x00
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       2
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bTerminalLink           9
        bDelay                  0 frames
        wFormatTag              1 PCM
        bLength                11
        bDescriptorType        36
        bNrChannels             2
        bSubframeSize           3
        bBitResolution         24
        tSamFreq[ 0]        44100
        bLength                 9
        bDescriptorType         5
        bmAttributes           37
        bInterval               1
        bRefresh                0
        bSynchAddress           0
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x00
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       3
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bTerminalLink           9
        bDelay                  0 frames
        wFormatTag              1 PCM
        bLength                11
        bDescriptorType        36
        bNrChannels             2
        bSubframeSize           2
        bBitResolution         16
        tSamFreq[ 0]        48000
        bLength                 9
        bDescriptorType         5
        bmAttributes           37
        bInterval               1
        bRefresh                0
        bSynchAddress           0
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x00
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       4
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bTerminalLink           9
        bDelay                  0 frames
        wFormatTag              1 PCM
        bLength                11
        bDescriptorType        36
        bNrChannels             2
        bSubframeSize           3
        bBitResolution         24
        tSamFreq[ 0]        48000
        bLength                 9
        bDescriptorType         5
        bmAttributes           37
        bInterval               1
        bRefresh                0
        bSynchAddress           0
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x00
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       5
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bTerminalLink           9
        bDelay                  0 frames
        wFormatTag              1 PCM
        bLength                11
        bDescriptorType        36
        bNrChannels             2
        bSubframeSize           2
        bBitResolution         16
        tSamFreq[ 0]        96000
        bLength                 9
        bDescriptorType         5
        bmAttributes           37
        bInterval               1
        bRefresh                0
        bSynchAddress           0
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x00
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       6
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bTerminalLink           9
        bDelay                  0 frames
        wFormatTag              1 PCM
        bLength                11
        bDescriptorType        36
        bNrChannels             2
        bSubframeSize           3
        bBitResolution         24
        tSamFreq[ 0]        96000
        bLength                 9
        bDescriptorType         5
        bmAttributes           37
        bInterval               1
        bRefresh                0
        bSynchAddress           0
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x00
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        5
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.11
          bNumDescriptors         1
          wDescriptorLength      33
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x86  EP 6 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               1
  (Bus Powered)
dmesg:
[  683.609915] usb 1-1.3: USB disconnect, device number 5
[  686.151271] usb 1-1.3: new full-speed USB device number 6 using dwc_otg
[  686.262969] usb 1-1.3: New USB device found, idVendor=041e, idProduct=30d7
[  686.263005] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  686.263022] usb 1-1.3: Product: USB Sound Blaster HD
[  686.263036] usb 1-1.3: Manufacturer: Creative Technology
[  686.263049] usb 1-1.3: SerialNumber: 000009tF
[  686.321301] input: Creative Technology USB Sound Blaster HD as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.5/input/input3
[  686.322835] hid-generic 0003:041E:30D7.0004: input,hidraw2: USB HID v1.11 Device [Creative Technology USB Sound Blaster HD] on usb-bcm2708_usb-1.3/input5
dmesg (while playing music/sound):
[  671.070880] delay: estimated 0, actual 144
[  671.093888] delay: estimated 0, actual 145
[  671.117891] delay: estimated 0, actual 145
[  671.140270] delay: estimated 0, actual 145
[  671.162895] delay: estimated 0, actual 144
[  671.185910] delay: estimated 0, actual 144
I played music on both kernels 3.6.11+ and 3.8.13+(fiq_split):
3.6.11+: Was very distorted but I was able to understand the music.
3.8.13+(fiq_split): Was a bit less distorted while the music is now in slow motion.
gwlevans
Mon Jun 10, 2013 1:50 pm
Try adding:
options snd-usb-audio index=0 nrpacks=1
to alsa-base.conf.
This cleared up the dmesg logs for me.
Gareth
M33P
Mon Jun 10, 2013 7:48 pm
@Mysterious
That sound card appears to have quite an esoteric set of endpoints - the main problem is that they will have multiple packets per frame going in/out. This will result in drops in the default kernel (split transactions get dropped or missed scheduling which ends up having broken/garbled audio) and due to the current scheduling constraints in the fiq_split kernel it would probably have similar effects.
More basic sound cards typically have a single endpoint that gets data thrown at it, with synchronisation of internal clocks occurring from SOF packets or similar.
Mysterious
Mon Jun 10, 2013 9:54 pm
@gwlevans
I tried this in several kernel versions before. Although the message disappeared in some tests, distortions never did so.
Thanks anyways.
@P33M
There are lots of connectors mic,phono,optical, indeed. I guess that making this device work will take a lot of time. Let me know if I can provide any support.
Thanks for clearing up the problem.
