ubergeek72
Re: USB FIQ testing....
Sat May 11, 2013 7:35 pm
Pi on kernel 3.8.12+ #438 PREEMPT dated Wed. May 8
Keyboard in upper USB port
Mouse in lower USB port. Pi powered by 12w Apple Ipad charger.
Speed: 700mhz
Environment: LXDE without lxpanel and with Cairo-Dock - typing in an xterm
Results: keyboard hesitates, sticks.
Same result for Keyboard in lower port, mouse in upper port.
Keyboard in lower port only:
same result.
Keyboard in upper port only:
same result
Mouse in keyboard hub port
same result.
Connect keyboard via powered hub (not presently powering the pi)
same result
Mouse in powered hub port
same result.
Mouse action exhibits similar pauses in all configurations.
Network latency considerably variable - ping times from my desktop machine to the pi (which share a switch with nothing else on it) vary from .5ms to 170ms
Disconnecting wired network does not alter pi keyboard response issues.
Disconnecting all USB devices (except power) does not alter ping time variability.
rpi-update proceeds very slowly. Flash performance may be off as well, though I'm used to running at 950mhz so it's hard to tell.
Since unplugging all the USB devices from the pi does not seem to change the behavior, I wonder if it's not some other driver from the 3.8.12 kernel interrupting the hell out of the whole system, or an interaction between the modified USB driver and some other driver that hasn't been tested with it.
lsmod on 3.8.12 kernel prior to rebooting with rolled-back firmware/kernel follows:
Module Size Used by
bnep 10928 2
rfcomm 33295 0
bluetooth 213381 10 bnep,rfcomm
rfkill 18899 2 bluetooth
binfmt_misc 6955 1
i2c_dev 5623 0
i2c_bcm2708 3657 0
ipv6 275425 26
snd_bcm2835 16149 2
snd_pcm 80288 2 snd_bcm2835
snd_page_alloc 5148 1 snd_pcm
snd_seq 53336 0
snd_seq_device 6437 1 snd_seq
snd_timer 20001 2 snd_pcm,snd_seq
snd 58466 8 snd_bcm2835,snd_timer,snd_pcm,snd_seq,snd_seq_device
leds_gpio 1985 0
led_class 3680 1 leds_gpio
On falling back to current production firmware/kernel, network ping times are stable between .60 and .999ms
Keyboard function appears normal
Mouse function appears normal, even during X.org/LXDE/Cairo-dock startup, which are CPU intensive. With the 3.8.12 kernel, mouse movement became extremely sporadic during that activity at boot.
lsmods output on default 3.6.11 kernel:
Module Size Used by
bnep 10574 2
rfcomm 33168 0
bluetooth 193568 10 bnep,rfcomm
rfkill 18202 2 bluetooth
binfmt_misc 6960 1
i2c_dev 5620 0
i2c_bcm2708 3759 0
ipv6 278186 26
snd_bcm2835 16304 2
snd_pcm 77560 2 snd_bcm2835
snd_page_alloc 5145 1 snd_pcm
snd_seq 53329 0
snd_seq_device 6438 1 snd_seq
snd_timer 19998 2 snd_pcm,snd_seq
snd 58447 8 snd_bcm2835,snd_timer,snd_pcm,snd_seq,snd_seq_device
evdev 9426 6
hid_apple 5209 0
leds_gpio 2235 0
led_class 3562 1 leds_gpio
Hope this is useful.
-JRS
ubergeek72
Sat May 11, 2013 7:39 pm
my lsusb -v output under the 3.6 kernel:
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 0 No Subclass
bInterfaceProtocol 0 None
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.11
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 47
Report Descriptors:
** UNAVAILABLE **
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0001 1x 1 bytes
bInterval 10
jbeale
one WiFi works better with FIQ, one doesn't
Sat May 11, 2013 10:49 pm
Just wanted to report that one USB-Wifi adapter I have works better with the new FIQ testing code, and one does not work at all. This is with a Model A with 4-port hub, having a keyboard and two FTDI USB-Serial devices also. The below setup using the Ralink RT5370 works better than it ever did before (no error packets and higher throughput).
[email protected] ~ $ uname -a
Linux rp3 3.8.12+ #438 PREEMPT Wed May 8 22:31:10 BST 2013 armv6l GNU/Linux
[email protected] ~ $ lsusb
Bus 001 Device 002: ID 1a40:0101 Terminus Technology Inc. 4-Port HUB
Bus 001 Device 003: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 004: ID 413c:2005 Dell Computer Corp. RT7D50 Keyboard
Bus 001 Device 008: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
Bus 001 Device 006: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
[email protected] ~ $ ifconfig wlan0
wlan0     Link encap:Ethernet  HWaddr 00:0f:53:87:08:2a
          inet addr:192.168.10.146  Bcast:192.168.10.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:29230 errors:0 dropped:0 overruns:0 frame:0
          TX packets:9533 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:38505457 (36.7 MiB)  TX bytes:5628269 (5.3 MiB)
lsusb -v output with Ralink:
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0 Unused
  bDeviceProtocol         1 Single TT
  bMaxPacketSize0        64
  idVendor           0x1a40 Terminus Technology Inc.
  idProduct          0x0101 4-Port HUB
  bcdDevice            1.11
  iManufacturer           0
  iProduct                1
  iSerial                 0
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceSubClass      0 Unused
      bInterfaceProtocol      0 Full speed (or root) hub
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  idVendor           0x1d6b Linux Foundation
  idProduct          0x0002 2.0 root hub
  bcdDevice            3.08
  iManufacturer           3
  iProduct                2
  iSerial                 1
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval              12
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x0403 Future Technology Devices International, Ltd
  idProduct          0x6001 FT232 USB-Serial (UART) IC
  bcdDevice            6.00
  iManufacturer           1
  iProduct                2
  iSerial                 3
    bLength                 9
    bDescriptorType         2
    wTotalLength           32
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower               90mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass       255 Vendor Specific Class
      bInterfaceSubClass    255 Vendor Specific Subclass
      bInterfaceProtocol    255 Vendor Specific Protocol
      iInterface              2
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x413c Dell Computer Corp.
  idProduct          0x2005 RT7D50 Keyboard
  bcdDevice            1.04
  iManufacturer           1
  iProduct                2
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           34
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceSubClass      1 Boot Interface Subclass
      bInterfaceProtocol      1 Keyboard
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bNumDescriptors         1
          wDescriptorLength      65
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0008  1x 8 bytes
        bInterval              10
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x148f Ralink Technology, Corp.
  idProduct          0x5370 RT5370 Wireless Adapter
  bcdDevice            1.01
  iManufacturer           1
  iProduct                2
  iSerial                 3
    bLength                 9
    bDescriptorType         2
    wTotalLength           67
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              450mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           7
      iInterface              5
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x01  EP 1 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x03  EP 3 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x04  EP 4 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x05  EP 5 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x06  EP 6 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  bcdDevice            6.00
  iManufacturer           1
  iProduct                2
  iSerial                 3
    bLength                 9
    bDescriptorType         2
    wTotalLength           32
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower               90mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              2
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
lsusb -v with Realtek RTL8188CUS (does not want to connect. It did work with older firmware, although ifconfig reported about as many error packets as received packets.)
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice            1.11
  iManufacturer           0
  iProduct                1
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice            3.08
  iManufacturer           3
  iProduct                2
  iSerial                 1
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  bcdDevice            6.00
  iManufacturer           1
  iProduct                2
  iSerial                 3
    bLength                 9
    bDescriptorType         2
    wTotalLength           32
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower               90mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              2
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  bcdDevice            1.04
  iManufacturer           1
  iProduct                2
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           34
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bNumDescriptors         1
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              10
Bus 001 Device 007: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x0bda Realtek Semiconductor Corp.
  idProduct          0x8176 RTL8188CUS 802.11n WLAN Adapter
  bcdDevice            2.00
  iManufacturer           1
  iProduct                2
  iSerial                 3
    bLength                 9
    bDescriptorType         2
    wTotalLength           46
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              500mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           4
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x84  EP 4 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               1
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  bcdDevice            6.00
  iManufacturer           1
  iProduct                2
  iSerial                 3
    bLength                 9
    bDescriptorType         2
    wTotalLength           32
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower               90mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              2
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
gsh
Sun May 12, 2013 7:30 am
That's interesting you've got a 4 port hub with a single TT. Normally there is a TT per port...
I've never seen one of those and it does explain why its bad... If you can test without that hub or with a different one that would be good...
Gordon
Gordon Hollingworth PhD
jbeale
Mon May 13, 2013 2:41 am
Well, how about that. Using a different hub, now the previously non-working wifi ( RTL8188CUS ) is working!
[email protected] ~/usb-log $ uname -a
[email protected] ~/usb-log $ lsusb -v
Bus 001 Device 002: ID 04b4:6560 Cypress Semiconductor Corp. CY7C65640 USB-2.0 "TetraHub"
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceProtocol         2 TT per port
  bMaxPacketSize0        64
  idVendor           0x04b4 Cypress Semiconductor Corp.
  idProduct          0x6560 CY7C65640 USB-2.0 "TetraHub"
  bcdDevice            0.08
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceProtocol      1 Single TT
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      bInterfaceProtocol      2 TT per port
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice            3.08
  iManufacturer           3
  iProduct                2
  iSerial                 1
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Bus 001 Device 003: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  bcdDevice            2.00
  iManufacturer           1
  iProduct                2
  iSerial                 3
    bLength                 9
    bDescriptorType         2
    wTotalLength           46
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              500mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           4
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               1
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  bcdDevice            1.04
  iManufacturer           1
  iProduct                2
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           34
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bNumDescriptors         1
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              10
Bus 001 Device 005: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  bcdDevice            6.00
  iManufacturer           1
  iProduct                2
  iSerial                 3
    bLength                 9
    bDescriptorType         2
    wTotalLength           32
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower               90mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              2
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  bcdDevice            6.00
  iManufacturer           1
  iProduct                2
  iSerial                 3
    bLength                 9
    bDescriptorType         2
    wTotalLength           32
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower               90mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              2
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
still has about as many "dropped" RX packets as received, just as with earlier firmware, but at least it is working.
[email protected] ~/usb-log $ ifconfig wlan0
wlan0     Link encap:Ethernet  HWaddr 00:0f:13:32:0b:5d
          RX packets:4118 errors:0 dropped:4529 overruns:0 frame:0
          TX packets:4810 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:635132 (620.2 KiB)  TX bytes:5364592 (5.1 MiB)
gsh
Mon May 13, 2013 5:10 am
OK, it definitely looks like it's the TT per port / Single TT that is causing this (and that does make sense)
Will look at this as a matter of urgency
Gordon
gsh
Mon May 13, 2013 5:24 am
ubergeek72 wrote:my lsusb -v output under the 3.6 kernel:
Can you do a sudo lsusb -v and enter as a code section (otherwise it's difficult to view). Please include all content,
Gordon
jbeale
Mon May 13, 2013 5:28 am
Thanks gsh for having a look at it! If it helps any, the problem USB hub (single TT per hub) I used was a Rosewill RHB-220, for example as sold here: http://www.amazon.com/Rosewill-4-Port-U ... B004BV6SCI
It is very small and cheap, I guess now I know why.
fbutler
Mon May 13, 2013 8:49 am
Defiant wrote:The stk1160 Device is sending a 720x480 in UYVY with 30fps, so I guess it is around 20MB/s.
To make it worth: In my Application I plan to send the data h264 compressed to two clients.
I just tried to write the stream to a tmpfs mount point: Same problem.
Just to confirm that I'm seeing the same results as Defiant with a STK1160, and two em28xx based video Composite/S-Video capture devices. I'm capturing in UYVY on the STK11160 and YUYV on the emx28xx devices at 704x576 and 25fps. As the frames are being captured I'm converting them to YUV420P using swsscale, and encoding them to H264 before writing them to a file. CPU usage during the capture/conversion process averages around 60% and USB bandwidth consumption is about 20.6 Mbps.
With the em28xx devices I've been able test with lower capture resolutions. The frame corruption is less, but still present at 640x480 at 25fps, but is not present at 320x240 at 25fps.
Let me know if you want any more info or any particular tests performed, and thanks for your work on the USB issues so far.
jbeale
Tue May 14, 2013 3:01 am
I should follow up that although my RTL8188CUS wifi works and continues to stay connected, it is not perfect. It seems to drop every other packet (?) and triggers the collision-avoidance exponential backoff algorithm* so that any sizable transfer starts off very quickly and then gets slower... and slower..... and slower. Note this is not a new problem with the FIQ testing kernel, I think this wifi devicie was always dropping packets, it's just that before it was always slow, and now at least it starts off fast, and then becomes slow.
*I think, assuming the wifi device works like how I vaguely recall that shared media ethernet works.
          RX packets:32351 errors:0 dropped:33736 overruns:0 frame:0
          TX packets:10689 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:8418314 (8.0 MiB)  TX bytes:9709457 (9.2 MiB)
gsh
Tue May 14, 2013 5:25 am
I did at one time check this device and decided that it wasn't actually dropping packets, basically I flood pinged my box and captured a minute's worth of USB transactions (using my $20k USB analyser!) then output to a file and wrote some software to search through the file for the packets to see if they were actually being retransmitted or dropped (depends on the design of the hardware!) Turns out that they were all there even though the software said it was dropping half of them.
So I would guess at worst case the issue is that they are being dropped in the network stack (because the user code is too slow to handle the packets) either that or the driver is not right and signalling a dropped packet when it isn't
Gordon
cyrano
Tue May 14, 2013 1:05 pm
There's definitely something weird with the RTL8188CUS chipset. I had to send back a number of Acer portables using this chipset because they all exhibited exactly 50% dropped packets under Win7. The manufacturer had no idea why. And it seemed they weren't gonna spend any time on it since they had had no other complaints.
piglet
Tue May 14, 2013 9:25 pm
piglet wrote:
piglet wrote:Thanks Gordon. I'll hopefully give this a go tonight with a problematic Dell SK-8135 which has had the repeating keys problem each time I've tried it.
Nice one. Thank you. Initial testing on the keyboard looks very good. I've not seen any repeating or missing keys, and am using the keyboard for this posting. Here's the initial test:
Sorry - it's back as bad as ever with that keyboard tonight. Sticky keys and missing keys.
gsh
Wed May 15, 2013 5:32 am
Please post sudo lsusb -v
Mikerasp
Thu May 16, 2013 7:11 am
I have been trying to get a bluetooth usb dongle to work over the past week ... i am also having the "sticky key effect".
Please read this https://github.com/raspberrypi/linux/issues/299 thread carefully.
Is there a way to test gsh's fix in raspbmc? (raspbmc doesn't support the "rpi-update" command ...
thx,
M.
gsh
Fri May 17, 2013 8:47 am
You could try loading up a Raspbian image and doing an rpi-update then using the kernel and modules from that image on RaspBMC...
Either that or try the Raspbian image, it'll tell you whether the problem will be fixed
Gordon
piglet
Fri May 17, 2013 6:02 pm
gsh wrote:Please post sudo lsusb -v
Sure - here you go. Hmmm - it's not skipping or sticking right now.
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  idVendor           0x0424 Standard Microsystems Corp.
  idProduct          0x9512
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             3
  wHubCharacteristic 0x000d
    Per-port power switching
    Compound device
    Per-port overcurrent protection
    TT think time 8 FS bits
  bPwrOn2PwrGood       50 * 2 milli seconds
  bHubContrCurrent      1 milli Ampere
  DeviceRemovable    0x02
  PortPwrCtrlMask    0xff
 Hub Port Status:
   Port 1: 0000.0503 highspeed power enable connect
   Port 2: 0000.0100 power
   Port 3: 0000.0503 highspeed power enable connect
Device Qualifier (for other device speed):
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceProtocol         0 Full speed (or root) hub
  bMaxPacketSize0        64
Device Status:     0x0001
  Self Powered
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice            3.06
  iManufacturer           3 Linux 3.6.11+ dwc_otg_hcd
  iProduct                2 DWC OTG Controller
  iSerial                 1 bcm2708_usb
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
  wHubCharacteristic 0x0008
    Ganged power switching
  bPwrOn2PwrGood        1 * 2 milli seconds
  bHubContrCurrent      0 milli Ampere
  DeviceRemovable    0x00
 Hub Port Status:
  Self Powered
Bus 001 Device 007: ID 046d:c016 Logitech, Inc. Optical Wheel Mouse
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x046d Logitech, Inc.
  idProduct          0xc016 Optical Wheel Mouse
  bcdDevice            3.40
  iManufacturer           1 Logitech
  iProduct                2 Optical USB Mouse
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           34
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceProtocol      2 Mouse
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bNumDescriptors         1
          wDescriptorLength      52
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              10
Device Status:     0x0000
  (Bus Powered)
Bus 001 Device 009: ID 413c:2010 Dell Computer Corp. Keyboard
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idProduct          0x2010 Keyboard
  bcdDevice            2.00
  iManufacturer           1 Dell
  iProduct                3 Dell USB Keyboard
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           59
    bNumInterfaces          2
    iConfiguration          3 Dell USB Keyboard
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower               50mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              3 Dell USB Keyboard
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bNumDescriptors         1
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              10
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           1
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bNumDescriptors         1
          wDescriptorLength     142
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval             255
  (Bus Powered)
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          255 Vendor Specific Class
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  idProduct          0xec00
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           39
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           3
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0010  1x 16 bytes
        bInterval               4
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  Self Powered
Bus 001 Device 004: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  idVendor           0x05e3 Genesys Logic, Inc.
  idProduct          0x0610 4-port hub
  bcdDevice           77.32
  iManufacturer           0
  iProduct                1 USB2.0 Hub
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             4
  wHubCharacteristic 0x00e0
    Ganged overcurrent protection
    TT think time 32 FS bits
    Port indicators
  bHubContrCurrent    100 milli Ampere
 Hub Port Status:
   Port 2: 0000.0103 power enable connect
   Port 3: 0000.0100 power
   Port 4: 0000.0100 power
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  Self Powered
Bus 001 Device 005: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice           77.32
  iManufacturer           0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             4
    Port indicators
 Hub Port Status:
   Port 1: 0000.0100 power
   Port 3: 0000.0303 lowspeed power enable connect
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  Self Powered
Bus 001 Device 008: ID 413c:1003 Dell Computer Corp. Keyboard Hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            9 Hub
  bMaxPacketSize0         8
  idProduct          0x1003 Keyboard Hub
  bcdDevice            2.00
  iProduct                2 Dell USB Keyboard Hub
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          2 Dell USB Keyboard Hub
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              2 Dell USB Keyboard Hub
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              24
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             3
    Compound device
  bPwrOn2PwrGood       22 * 2 milli seconds
 Hub Port Status:
   Port 1: 0000.0103 power enable connect
  (Bus Powered)
gsh
Fri May 17, 2013 6:18 pm
Interestingly one of the hubs has a single tt interface
I wonder if something made it choose that configuration... You definitely didnt move the connections around at all?
Gordon
piglet
Mon May 20, 2013 8:07 am
Hmmm - I may well have inadvertently used a different USB port on the hub. I'll try each one and see if it makes a difference which I use.
Mikerasp
Mon May 20, 2013 3:24 pm
On a fresh raspbian wheezy install, the following commands results in perfectly normal bluetooth behaviour :-)
sudo BRANCH=fiq_split rpi-update
I'm glad you guys are on the right track to solve this annoying problem for good. 8-)
Could someone put me on the right track for implementing this in RaspBMC/Xbian please?
thx,
M.
M33P
Mon May 20, 2013 4:04 pm
piglet wrote:Hmmm - I may well have inadvertently used a different USB port on the hub. I'll try each one and see if it makes a difference which I use.
That lsusb output smells suspiciously like you have a daisy-chained "7-port" hub configuration where we have:
upstream <== Hub1	===> Downstream 1
	 				 	===> Downstream 2
	 				 	===> Downstream 3
	 	 				===> Hub 2	===> Downstream 4
											===> Downstream 5
											===> Downstream 6
											===> Downstream 7
There have been reports that such hubs play fine with a Pi on the first 3 ports but the last 4 are "dodgy". It would be interesting to see if your "hub" exhibited this behaviour.
The clue to watch for in a lsusb -v output is this bit:
 Hub Port Status:
While there's no guarantee that the ports on hub 1 / hub 2 correspond to any sort of external order, this will give you indication as to which hub it's plugged into. With no devices plugged in it should then be obvious you've got a cascaded hub.
piglet
Mon May 20, 2013 9:45 pm
gsh wrote:Interestingly one of the hubs has a single tt interface
Gordon
Hi Gordon,
I tried each of the ports I could have had the keyboard in: 4, 3, 2, 1. 4, 3, and 2 were fine. When I tried this one (the first from left to right on the D-Link hub) it took me many attempts to type the command in it was so bad at sticky keys. I'm not convinced this was the problem port before. Thankfully multiple v's weren't a problem:
 [email protected] ~ $ sudo lsusb -vvvvvvvvvvvvvvvv
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  idProduct          0x9512
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             3
    Compound device
 Hub Port Status:
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  Self Powered
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice            3.06
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
 Hub Port Status:
  Self Powered
Bus 001 Device 014: ID 413c:1003 Dell Computer Corp. Keyboard Hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            9 Hub
  bMaxPacketSize0         8
  bcdDevice            2.00
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              24
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             3
    Compound device
 Hub Port Status:
  (Bus Powered)
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  bcdDevice            3.40
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           34
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bNumDescriptors         1
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              10
  (Bus Powered)
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  idProduct          0xec00
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           39
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           3
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               4
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  Self Powered
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice           77.32
  iManufacturer           0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             4
    Port indicators
 Hub Port Status:
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  Self Powered
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice           77.32
  iManufacturer           0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             4
    Port indicators
 Hub Port Status:
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  Self Powered
Bus 001 Device 015: ID 413c:2010 Dell Computer Corp. Keyboard
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  bcdDevice            2.00
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           59
    bNumInterfaces          2
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower               50mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bNumDescriptors         1
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              10
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           1
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bNumDescriptors         1
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval             255
  (Bus Powered)
Edit: I can send you the whole setup - psu, hub, pi and mouse if you like.
kalehrl
Thu May 23, 2013 12:56 pm
It seems it is not possible to update software and retain this kernel.
When I run sudo apt-get update && sudo apt-get upgrade, I get librasperrypi and other firmware packages which replace the latest kernel.
dom
Thu May 23, 2013 1:38 pm
kalehrl wrote:It seems it is not possible to update software and retain this kernel.
Yes.
sudo rm /boot/.firmware_revision && sudo BRANCH=fiq_split rpi-update
will force it back onto that kernel.
piglet
Thu May 23, 2013 2:00 pm
Ahh - I wonder whether I need to redo that then.
I'll re-fiq-rpi-update and test for the error before I box up the bits and send to you over the weekend. No point in wasting your time if your changes have simply been lost on my pi by an apt-get update&upgrade. I may well have done one.
