I first thought maybe it was just borked or badly installed after all, but then suddenly the screen flickered, showed me the working raspbian OS, then disappeared again, only to appear for a few seconds (with lots of 'stripes' and visual noise) and then to turn black again...intermittently, varying in seconds to minutes.
Clearly, it was unstable as hell. I thought maybe it was the adapter, so I tried it out with other stuff, but there it seemed to work well. I checked all my connections to make sure it wasn't due to a bad connection somewhere, and tried some other things - all to no avail.
In the end, I thought maybe an update would maybe help (though it was clearly a hardware problem, but heck, one gets desperate after hours of fruitless searching). *THE MOMENT* I put the ethernet-cable (a regular cat5) into its socket however, my screen got a stable, crispy clear image. Mind you, without updating anything, just by putting it in. And everything worked just fine (and was showing).
I removed it...it went black with now and then a flickering, again. I put it in: clean, stable image again. Thus, it clearly has to do with the hardware, but I can't imagine what, because surely, the ethernet-cable has nothing to do with the hdmi video-output. Or at least, it shouldn't have. but I guess some kind of interference (which, in this case, makes it better?) is there, otherwise it's inexplicable. Maybe some small current-loop or whatever is passing through (or inhibiting) to my ethernet when connecting, and has an influence on the hdmi-socket/port? Some sort of hardware bug seems a reasonable assumption, since I hardly think it was a feature that hdmi only works correctly when the ethernet-cable is plugged in(?).
Anyone had this experience too? Any other suggestions why this occurs?
