XBMC crashing
Posted: Sun Mar 17, 2013 8:09 pm
XBMC's been working fine. I don't think it's been upgraded recently.
Earlier today I SSH'd in to the Pi and it quickly locked up, power cable was taken out and pushed back in.
Now XBMC crashes every five minutes or so and locks up if you try and play a video.
Any ideas? Thanks in advance.
/home/xbmc/xbmc_crashlog-20130317_183735.log:
/home/xbmc/.xbmc/temp/xbmc.log:
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Sun Mar 17 18:37:36 UTC 2013
XBMC Options:
Arch: armv6l
Kernel: Linux 3.6.11+ #371 PREEMPT Thu Feb 7 16:31:35 GMT 2013
Release:
Distributor ID: Debian
Description: Debian GNU/Linux 7.0 (wheezy)
Release: 7.0
Codename: wheezy
############## END SYSTEM INFO ##############
############### STACK TRACE #################
############# END STACK TRACE ###############
################# LOG FILE ##################
<U+FEFF>18:37:08 T:3036958720 NOTICE: -----------------------------------------------------------------------
18:37:09 T:3036958720 NOTICE: Starting XBMC (12.0 Git:Unknown), Platform: Linux (Debian GNU/Linux 7.0 (wheezy), 3.6.11+ armv6l). Built on Jan 30 2013
18:37:09 T:3036958720 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
18:37:09 T:3036958720 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
18:37:09 T:3036958720 NOTICE: special://masterprofile/ is mapped to: /home/xbmc/.xbmc/userdata
18:37:09 T:3036958720 NOTICE: special://home/ is mapped to: /home/xbmc/.xbmc
18:37:09 T:3036958720 NOTICE: special://temp/ is mapped to: /home/xbmc/.xbmc/temp
18:37:09 T:3036958720 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
18:37:09 T:3036958720 NOTICE: Local hostname: wales
18:37:09 T:3036958720 NOTICE: Log File is located: /home/xbmc/.xbmc/temp/xbmc.log
18:37:09 T:3036958720 NOTICE: -----------------------------------------------------------------------
18:37:09 T:3036958720 NOTICE: load settings...
18:37:09 T:3036958720 NOTICE: special://profile/ is mapped to: special://masterprofile/
18:37:09 T:3036958720 NOTICE: loading special://masterprofile/guisettings.xml
18:37:09 T:3036958720 NOTICE: Getting hardware information now...
18:37:09 T:3036958720 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
18:37:09 T:3036958720 NOTICE: Loaded playercorefactory configuration
18:37:09 T:3036958720 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
18:37:09 T:3036958720 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
18:37:09 T:3036958720 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
18:37:09 T:3036958720 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<advancedsettings>
<video>
<defaultplayer>omxplayer</defaultplayer>
<defaultdvdplayer>omxplayer</defaultdvdplayer>
</video>
<audio>
<streamsilence>false</streamsilence>
</audio>
<gui>
<algorithmdirtyregions>3</algorithmdirtyregions>
<nofliptimeout>0</nofliptimeout>
</gui>
<thumbsize>512</thumbsize>
<fanartheight>720</fanartheight>
<useddsfanart>true</useddsfanart>
<splash>false</splash>
<bginfoloadermaxthreads>2</bginfoloadermaxthreads>
<lookandfeel>
<enablerssfeeds>false</enablerssfeeds>
</lookandfeel>
<cputempcommand>sed -e 's/\([0-9]*\)[0-9]\{3\}.*/\1 C/' /sys/class/thermal/thermal_zone0/temp</cputempcommand>
<gputempcommand>/opt/vc/bin/vcgencmd measure_temp | sed "s,temp=\([0-9]*\)\.[0-9]'C,\1 C,"</gputempcommand>
</advancedsettings>
18:37:09 T:3036958720 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
18:37:09 T:3036958720 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<network>
<cachemembuffersize>30242880</cachemembuffersize>
</network>
<fanartheight>560</fanartheight>
<thumbsize>256</thumbsize>
<gui>
</gui>
</advancedsettings>
18:37:09 T:3036958720 NOTICE: Default DVD Player: omxplayer
18:37:09 T:3036958720 NOTICE: Default Video Player: omxplayer
18:37:09 T:3036958720 NOTICE: Default Audio Player: omxplayer
18:37:09 T:3036958720 NOTICE: Disabled debug logging due to GUI setting. Level 0.
18:37:09 T:3036958720 NOTICE: Log level changed to 0
18:37:09 T:3036958720 NOTICE: Loading media sources from special://masterprofile/sources.xml
18:37:10 T:3036958720 ERROR: Error: Requested setting (audiooutput.guisoundmode) was not found. It must be case-sensitive
18:37:11 T:3036958720 NOTICE: Running database version Addons15
18:37:13 T:3036958720 NOTICE: Register - new cec device registered on rpi->RPI: Raspberry Pi CEC Adapter (2708:1001)
18:37:13 T:3026183184 NOTICE: Thread CEC Adapter start, auto delete: false
18:37:13 T:3017794576 NOTICE: Thread XBMC Peripherals start, auto delete: false
18:37:13 T:3036958720 NOTICE: Raspberry PI firmware version: Feb 7 2013 16:46:17
Copyright (c) 2012 Broadcom
version 367974 (release)
18:37:13 T:3036958720 NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
18:37:13 T:3036958720 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz
18:37:13 T:3036958720 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 60.000000 Hz
18:37:13 T:3036958720 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
18:37:13 T:3036958720 NOTICE: Found resolution 640 x 720 for display 0 with 640 x 720 @ 60.000000 Hz
18:37:13 T:3036958720 NOTICE: Found resolution 1280 x 360 for display 0 with 1280 x 360 @ 60.000000 Hz
18:37:13 T:3036958720 NOTICE: Found resolution 1280 x 720 for display 0 with 1920 x 1080 @ 60.000000 Hz
18:37:13 T:3036958720 NOTICE: Found resolution 640 x 720 for display 0 with 960 x 1080 @ 60.000000 Hz
18:37:13 T:3036958720 NOTICE: Found resolution 1280 x 360 for display 0 with 1920 x 540 @ 60.000000 Hz
18:37:13 T:3036958720 NOTICE: Found resolution 720 x 576 for display 0 with 720 x 576 @ 50.000000 Hz
18:37:13 T:3036958720 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
18:37:13 T:3036958720 NOTICE: Found resolution 640 x 720 for display 0 with 640 x 720 @ 50.000000 Hz
18:37:13 T:3036958720 NOTICE: Found resolution 1280 x 360 for display 0 with 1280 x 360 @ 50.000000 Hz
18:37:13 T:3036958720 NOTICE: Found resolution 1280 x 720 for display 0 with 1920 x 1080 @ 50.000000 Hz
18:37:13 T:3036958720 NOTICE: Found resolution 640 x 720 for display 0 with 960 x 1080 @ 50.000000 Hz
18:37:13 T:3036958720 NOTICE: Found resolution 1280 x 360 for display 0 with 1920 x 540 @ 50.000000 Hz
18:37:13 T:3036958720 NOTICE: Found resolution 1280 x 720 for display 0 with 1920 x 1080 @ 24.000000 Hz
18:37:13 T:3036958720 NOTICE: Found resolution 640 x 720 for display 0 with 960 x 1080 @ 24.000000 Hz
18:37:13 T:3036958720 NOTICE: Found resolution 1280 x 360 for display 0 with 1920 x 540 @ 24.000000 Hz
18:37:13 T:3036958720 NOTICE: Found resolution 1280 x 720 for display 0 with 1920 x 1080 @ 30.000000 Hz
18:37:13 T:3036958720 NOTICE: Found resolution 1280 x 360 for display 0 with 1920 x 540 @ 30.000000 Hz
18:37:13 T:3036958720 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 60.000000 Hz
18:37:13 T:3036958720 NOTICE: Found resolution 960 x 720 for display 0 with 1024 x 768 @ 60.000000 Hz
18:37:13 T:3036958720 NOTICE: Found resolution 900 x 720 for display 0 with 1280 x 1024 @ 60.000000 Hz
18:37:13 T:3036958720 NOTICE: Found (1280x720@60.000000) at 21, setting to RES_DESKTOP at 16
18:37:13 T:3036958720 NOTICE: Checking resolution 16
18:37:13 T:3036958720 NOTICE: GL_VENDOR = Broadcom
18:37:13 T:3036958720 NOTICE: GL_RENDERER = VideoCore IV HW
18:37:13 T:3036958720 NOTICE: GL_VERSION = OpenGL ES 2.0
18:37:13 T:3036958720 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
18:37:13 T:3036958720 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
18:37:16 T:3026183184 ERROR: CecLogMessage - failed to release the previous LA
18:37:20 T:3026183184 ERROR: CecLogMessage - could not open a connection (try 1)
18:37:22 T:2956981264 NOTICE: Thread CEC Adapter Update Thread start, auto delete: false
############### END LOG FILE ################
############ END XBMC CRASH LOG #############Code: Select all
<U+FEFF>20:06:19 T:3036491776 NOTICE: -----------------------------------------------------------------------
20:06:20 T:3036491776 NOTICE: Starting XBMC (12.0 Git:Unknown), Platform: Linux (Debian GNU/Linux 7.0 (wheezy), 3.6.11+ armv6l). Built on Jan 30 2013
20:06:20 T:3036491776 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
20:06:20 T:3036491776 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
20:06:20 T:3036491776 NOTICE: special://masterprofile/ is mapped to: /home/xbmc/.xbmc/userdata
20:06:20 T:3036491776 NOTICE: special://home/ is mapped to: /home/xbmc/.xbmc
20:06:20 T:3036491776 NOTICE: special://temp/ is mapped to: /home/xbmc/.xbmc/temp
20:06:20 T:3036491776 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
20:06:20 T:3036491776 NOTICE: Local hostname: wales
20:06:20 T:3036491776 NOTICE: Log File is located: /home/xbmc/.xbmc/temp/xbmc.log
20:06:20 T:3036491776 NOTICE: -----------------------------------------------------------------------
20:06:20 T:3036491776 NOTICE: load settings...
20:06:20 T:3036491776 NOTICE: special://profile/ is mapped to: special://masterprofile/
20:06:20 T:3036491776 NOTICE: loading special://masterprofile/guisettings.xml
20:06:20 T:3036491776 NOTICE: Getting hardware information now...
20:06:20 T:3036491776 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
20:06:20 T:3036491776 NOTICE: Loaded playercorefactory configuration
20:06:20 T:3036491776 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
20:06:20 T:3036491776 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
20:06:20 T:3036491776 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
20:06:20 T:3036491776 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<advancedsettings>
<video>
</video>
<audio>
</audio>
<gui>
</gui>
<lookandfeel>
<lookandfeel>
</lookandfeel>
</advancedsettings>
20:06:20 T:3036491776 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
20:06:20 T:3036491776 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<network>
</network>
<gui>
</gui>
</advancedsettings>
20:06:20 T:3036491776 NOTICE: Default DVD Player: omxplayer
20:06:20 T:3036491776 NOTICE: Default Video Player: omxplayer
20:06:20 T:3036491776 NOTICE: Default Audio Player: omxplayer
20:06:20 T:3036491776 NOTICE: Disabled debug logging due to GUI setting. Level 0.
20:06:20 T:3036491776 NOTICE: Log level changed to 0
20:06:20 T:3036491776 NOTICE: Loading media sources from special://masterprofile/sources.xml
20:06:20 T:3036491776 ERROR: Error: Requested setting (audiooutput.guisoundmode) was not found. It must be case-sensitive
20:06:20 T:3036491776 NOTICE: Running database version Addons15
20:06:21 T:3036491776 NOTICE: Register - new cec device registered on rpi->RPI: Raspberry Pi CEC Adapter (2708:1001)
20:06:21 T:3025716240 NOTICE: Thread CEC Adapter start, auto delete: false
20:06:21 T:3017327632 NOTICE: Thread XBMC Peripherals start, auto delete: false
20:06:22 T:3036491776 NOTICE: Raspberry PI firmware version: Mar 7 2013 19:37:36
version 375458 (release)
20:06:22 T:3036491776 NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
20:06:22 T:3036491776 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz
20:06:22 T:3036491776 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 60.000000 Hz
20:06:22 T:3036491776 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
20:06:22 T:3036491776 NOTICE: Found resolution 640 x 720 for display 0 with 640 x 720 @ 60.000000 Hz
20:06:22 T:3036491776 NOTICE: Found resolution 1280 x 360 for display 0 with 1280 x 360 @ 60.000000 Hz
20:06:22 T:3036491776 NOTICE: Found resolution 1280 x 720 for display 0 with 1920 x 1080 @ 60.000000 Hz
20:06:22 T:3036491776 NOTICE: Found resolution 640 x 720 for display 0 with 960 x 1080 @ 60.000000 Hz
20:06:22 T:3036491776 NOTICE: Found resolution 1280 x 360 for display 0 with 1920 x 540 @ 60.000000 Hz
20:06:22 T:3036491776 NOTICE: Found resolution 720 x 576 for display 0 with 720 x 576 @ 50.000000 Hz
20:06:22 T:3036491776 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
20:06:22 T:3036491776 NOTICE: Found resolution 640 x 720 for display 0 with 640 x 720 @ 50.000000 Hz
20:06:22 T:3036491776 NOTICE: Found resolution 1280 x 360 for display 0 with 1280 x 360 @ 50.000000 Hz
20:06:22 T:3036491776 NOTICE: Found resolution 1280 x 720 for display 0 with 1920 x 1080 @ 50.000000 Hz
20:06:22 T:3036491776 NOTICE: Found resolution 640 x 720 for display 0 with 960 x 1080 @ 50.000000 Hz
20:06:22 T:3036491776 NOTICE: Found resolution 1280 x 360 for display 0 with 1920 x 540 @ 50.000000 Hz
20:06:22 T:3036491776 NOTICE: Found resolution 1280 x 720 for display 0 with 1920 x 1080 @ 24.000000 Hz
20:06:22 T:3036491776 NOTICE: Found resolution 640 x 720 for display 0 with 960 x 1080 @ 24.000000 Hz
20:06:22 T:3036491776 NOTICE: Found resolution 1280 x 360 for display 0 with 1920 x 540 @ 24.000000 Hz
20:06:22 T:3036491776 NOTICE: Found resolution 1280 x 720 for display 0 with 1920 x 1080 @ 30.000000 Hz
20:06:22 T:3036491776 NOTICE: Found resolution 1280 x 360 for display 0 with 1920 x 540 @ 30.000000 Hz
20:06:22 T:3036491776 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 60.000000 Hz
20:06:22 T:3036491776 NOTICE: Found resolution 960 x 720 for display 0 with 1024 x 768 @ 60.000000 Hz
20:06:22 T:3036491776 NOTICE: Found resolution 900 x 720 for display 0 with 1280 x 1024 @ 60.000000 Hz
20:06:22 T:3036491776 NOTICE: Found (1280x720@60.000000) at 21, setting to RES_DESKTOP at 16
20:06:22 T:3036491776 NOTICE: Checking resolution 16
20:06:22 T:3036491776 NOTICE: GL_VENDOR = Broadcom
20:06:22 T:3036491776 NOTICE: GL_RENDERER = VideoCore IV HW
20:06:22 T:3036491776 NOTICE: GL_VERSION = OpenGL ES 2.0
20:06:22 T:3036491776 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
20:06:22 T:3036491776 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
20:06:24 T:3036491776 NOTICE: Running database version Addons15
20:06:24 T:3036491776 NOTICE: Running database version ViewModes4
20:06:24 T:3036491776 NOTICE: Running database version Textures13
20:06:26 T:3025716240 ERROR: CecLogMessage - failed to release the previous LA
20:06:26 T:3025716240 ERROR: CecLogMessage - could not open a connection (try 1)
20:06:26 T:3036491776 NOTICE: Running database version MyMusic32
20:06:26 T:3036491776 NOTICE: Running database version MyVideos75
20:06:26 T:3036491776 NOTICE: Running database version TV22
20:06:26 T:3036491776 NOTICE: Running database version Epg7
20:06:26 T:3036491776 NOTICE: start dvd mediatype detection
20:06:26 T:3036491776 NOTICE: initializing playlistplayer
20:06:26 T:3036491776 NOTICE: DONE initializing playlistplayer
20:06:26 T:2966037520 NOTICE: Thread CDetectDVDMedia start, auto delete: false
20:06:28 T:2952786960 NOTICE: Thread CEC Adapter Update Thread start, auto delete: false
20:06:29 T:3036491776 NOTICE: initialize done
20:06:29 T:3036491776 NOTICE: Running the application...
20:06:30 T:2944398352 NOTICE: Thread Jobworker start, auto delete: true
20:06:31 T:3036491776 NOTICE: ES: Starting event server
20:06:31 T:2936009744 NOTICE: Thread CEventServer start, auto delete: false
20:06:31 T:2936009744 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
20:06:31 T:2936009744 NOTICE: UDP: Listening on port 9777
20:06:31 T:2927621136 NOTICE: Thread CTCPServer start, auto delete: false
20:06:31 T:3036491776 NOTICE: starting zeroconf publishing
20:06:31 T:2910843920 NOTICE: Thread Jobworker start, auto delete: true
