Installing Screen failed
Posted: Sun Mar 03, 2013 1:08 pm
by HyperGamma
Im quite new to using the linux command line so please excuse me if im a n00b lol.
I am trying to install screen but i get getting an error any advice?
root@raspberrypi:/# apt-get install screen
Reading package lists... Done
Building dependency tree
Suggested packages:
iselect screenie byobu
screen
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 657 kB of archives.
After this operation, 946 kB of additional disk space will be used.
Err http://mirrordirector.raspbian.org/raspbian/ wheezy/main screen armhf 4.1.0~20120320gitdb59704-5
404 Not Found
Failed to fetch http://mirrordirector.raspbian.org/rasp ... _armhf.deb 404 Not Found
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Im an using this image:
http://moebiuslinux.sourceforge.net/
Re: Installing Screen failed
Posted: Sun Mar 03, 2013 1:36 pm
by SirLagz
run apt-get update first, and then run apt-get install screen and see how you go.
Posted: Sun Mar 03, 2013 1:49 pm
by rpdom
Your package list/index is out of date. That version of screen has been replaced with a new one, so you won't be able to find the file.
General rule of thumb with Raspbian - always run apt-get update before running apt-get install or apt-get upgrade.
apt-get update will fetch the latest index files if there have been any changes since last time you ran it.
Posted: Sun Mar 03, 2013 2:06 pm
by HyperGamma
Awesome guys!
Thanks all fixed!
Great tips!
Posted: Tue Mar 05, 2013 3:00 am
by Stephen||Carter
Thanks for this, just solved my problem also.
