New PI ontly red led and green for on blip
Posted: Mon Feb 18, 2013 7:27 pm
by squonky
just got my pi today after waiting weeks .
Bought a pre writen ks sd ard to get started
Plugged everything in and i only get a red led solid
The green led blips on once.
I have downloaded wheezy and bjrned and new sd card and this does the same
I never get anhthing one the screen at all
Aany suggestikns or do i just send it back!
S.
Re: New PI ontly red led and green for on blip
Posted: Tue Feb 19, 2013 1:35 am
by Mobius
What are you connected to for your video output? The two video outputs (HDMI and composite) are mutually exclusive and it will default to composite if an HDMI device is not detected. If you have any sort of adpater from the Pi HDMI to your monitor, then it may not detect the monitor so it won't show video. I have also found that even if you are going directly into an HDMI port on a TV or monitor that the TV or monitor must be powered on before the Pi.
Posted: Tue Feb 19, 2013 6:29 am
by squonky
it was using the HMDI directly ro a tv the tv was on and the tv switches between no device connected to no signal when i power up and vice versa whan i power down.
So there appears to be something on the output.
Ill try the composite as well next chance i get.
Should the green light not be on more than a single little blip?
Posted: Tue Feb 19, 2013 10:33 am
by drgeoff
squonky wrote: Should the green light not be on more than a single little blip?
Yes.
Because you say that you downloaded and burned a new card, I assume you have a computer and a card reader. Use those to see what files the PC can see on the SD card.
Posted: Tue Feb 19, 2013 2:01 pm
by squonky
Hi i have just burnt a rasbmc image to the sd this works and has installed
But Wheezy and the original sd i got from rs do nothing
I used the same sd card as i used for wheezy
Not sure what to do now
Posted: Tue Feb 19, 2013 2:20 pm
by drgeoff
squonky wrote:Hi i have just burnt a rasbmc image to the sd this works and has installed
There were reports of RS sending out some cards which had been pre-flashed with a really old OS and firmware which didn't work on the newer 512 Mbyte RPis. If you still have that card with the OS on it, what dates do you see when you put the card in your PC?
Which Wheezy did you flash yourself? And are you sure you did it properly? The Raspbmc installer uses a different method so just because you got that one right doesn't mean that your burning of Wheezy was done properly.
Posted: Tue Feb 19, 2013 6:29 pm
by squonky
the date is the 28 oct a bit anoying if that is it
I downloaded the network version from the pi website and downloaded the image burner from thier link
what version and where do you think is best
Posted: Tue Feb 19, 2013 8:45 pm
by drgeoff
squonky wrote:the date is the 28 oct a bit anoying if that is it
I don't know the "cut-off" date but I would have thought that 28 Oct would be late enough to work on 512 Mbyte RPis. So I'm puzzled that it does not work.
I don't understand "I downloaded the network version from the pi website and downloaded the image burner from thier link". I don't see a "network version" of anything at http://www.raspberrypi.org/downloads.
The recommended version is Raspian wheezy 2013-02-09 as mentioned and linked to on http://www.raspberrypi.org/downloads.
Posted: Thu Feb 21, 2013 4:33 am
by squonky
i re downloaded ot an managed to get it working
Guess i was basically ripped off buying a prepared os.
Not a good start for a noob!
