RPI loose its IP address, not reason given.
Posted: Fri Feb 15, 2013 7:25 am
by rocketero
I have been experimenting this problem and now is getting very annoying as it is doing it very often. While I'm connected remotely to the the RPI using tightvncviewer suddenly it gets frozen and then I get a pop-up window saying there is not connection to the RPI. I then go to the physical RPI and issue the command ifconfig -a and the eth0 doesn't show any IP address. I then issue the command ' sudo ifconfig eth0 192.168.0.20 ' to give it back an IP and it takes it and I then can connect back with tightvncviewer in my PC, but after a little while the IP is drop and again not communication.
This is happening very often and sometimes even after rebooting the RPI it doesn't get any IP address so I have to do it manually with the ' sudo ifconfig .... ' so this doesn't look good.
I pulled the dmesg and I don't really see anything in it that shows a clue of why this is happening.
Any help to troubleshoot this problem would be appreciated!.
I am using the Wheeze from 12-16-2013 and I have it upgraded up to yesterday Feb 14th. yesterday there was an upgrade to the rasberrypi-bootloader as I saw it while it was upgrading. But this problem was happening even before this upgrade so I can not say it was because this upgrad.
the temperature of the core CPU with the command ' vcgencmd measure_temp ' shows as 42 Celsius degrees so I doubt it's because overheating.
this is the output of dmesg:
[    0.000000] Booting Linux on physical CPU 0
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Linux version 3.6.11+ (dc4@dc4-arm-01) (gcc version 4.7.2 20120731 (prerelease) (crosstool-NG linaro-1.13.1+bzr2458 - Linaro GCC 2012.08) ) #371 PREEMPT Thu Feb 7 16:31:35 GMT 2013
[    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[    0.000000] Machine: BCM2708
[    0.000000] cma: CMA: reserved 16 MiB at 0b000000
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] On node 0 totalpages: 49152
[    0.000000] free_area_init_node: node 0, pgdat c053b834, node_mem_map c05e5000
[    0.000000]   Normal zone: 384 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 48768 pages, LIFO batch:15
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 48768
[    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1644 bcm2708_fb.fbheight=1034 bcm2708.boardrev=0x2 bcm2708.serial=0x5a37ca7c smsc95xx.macaddr=B8:27:EB:37:CA:7C sdhci-bcm2708.emmc_clock_freq=100000000 vc_mem.mem_base=0xec00000 vc_mem.mem_size=0x10000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Memory: 192MB = 192MB total
[    0.000000] Memory: 172368k/172368k available, 24240k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xcc800000 - 0xff000000   ( 808 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xcc000000   ( 192 MB)
[    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[    0.000000]       .text : 0xc0008000 - 0xc04e5470   (4982 kB)
[    0.000000]       .init : 0xc04e6000 - 0xc0506f24   ( 132 kB)
[    0.000000]       .data : 0xc0508000 - 0xc053c060   ( 209 kB)
[    0.000000]        .bss : 0xc053c084 - 0xc05e4738   ( 674 kB)
[    0.000000] NR_IRQS:330
[    0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty1] enabled
[    0.001006] Calibrating delay loop... 464.48 BogoMIPS (lpj=2322432)
[    0.060062] pid_max: default: 32768 minimum: 301
[    0.060407] Mount-cache hash table entries: 512
[    0.061163] Initializing cgroup subsys cpuacct
[    0.061218] Initializing cgroup subsys devices
[    0.061251] Initializing cgroup subsys freezer
[    0.061281] Initializing cgroup subsys blkio
[    0.061383] CPU: Testing write buffer coherency: ok
[    0.061714] hw perfevents: enabled with v6 PMU driver, 3 counters available
[    0.061864] Setting up static identity map for 0x39d3f8 - 0x39d454
[    0.063361] devtmpfs: initialized
[    0.074129] NET: Registered protocol family 16
[    0.080486] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[    0.081570] bcm2708.uart_clock = 0
[    0.082922] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.082977] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.083013] mailbox: Broadcom VideoCore Mailbox driver
[    0.083108] bcm2708_vcio: mailbox at f200b880
[    0.083211] bcm_power: Broadcom power driver
[    0.083250] bcm_power_open() -> 0
[    0.083275] bcm_power_request(0, 8)
[    0.583966] bcm_mailbox_read -> 00000080, 0
[    0.584009] bcm_power_request -> 0
[    0.584035] Serial: AMBA PL011 UART driver
[    0.584180] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[    0.907824] console [ttyAMA0] enabled
[    0.931345] bio: create slab <bio-0> at 0
[    0.936215] SCSI subsystem initialized
[    0.940306] usbcore: registered new interface driver usbfs
[    0.945885] usbcore: registered new interface driver hub
[    0.951488] usbcore: registered new device driver usb
[    0.957834] Switching to clocksource stc
[    0.962077] FS-Cache: Loaded
[    0.965220] CacheFiles: Loaded
[    0.980004] NET: Registered protocol family 2
[    0.985294] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.992641] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[    0.999221] TCP: Hash tables configured (established 8192 bind 8192)
[    1.005651] TCP: reno registered
[    1.008904] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    1.014801] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    1.021351] NET: Registered protocol family 1
[    1.026266] RPC: Registered named UNIX socket transport module.
[    1.032311] RPC: Registered udp transport module.
[    1.037034] RPC: Registered tcp transport module.
[    1.041748] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.048883] bcm2708_dma: DMA manager at f2007000
[    1.053670] bcm2708_gpio: bcm2708_gpio_probe c0515d98
[    1.059132] vc-mem: phys_addr:0x00000000 mem_base=0x0ec00000 mem_size:0x10000000(256 MiB)
[    1.068293] audit: initializing netlink socket (disabled)
[    1.073888] type=2000 audit(0.930:1): initialized
[    1.196546] VFS: Disk quotas dquot_6.5.2
[    1.200580] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.207640] FS-Cache: Netfs 'nfs' registered for caching
[    1.213400] NFS: Registering the id_resolver key type
[    1.218572] Key type id_resolver registered
[    1.222868] Key type id_legacy registered
[    1.227231] msgmni has been set to 368
[    1.232785] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    1.240492] io scheduler noop registered
[    1.244532] io scheduler deadline registered (default)
[    1.249715] io scheduler cfq registered
[    1.287447] Console: switching to colour frame buffer device 205x64
[    1.313223] kgdb: Registered I/O driver kgdboc.
[    1.318535] vc-cma: Videocore CMA driver
[    1.322641] vc-cma: vc_cma_base      = 0x00000000
[    1.327462] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    1.333010] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    1.347752] brd: module loaded
[    1.356056] loop: module loaded
[    1.359667] vchiq: vchiq_init_state: slot_zero = 0xcb000000, is_master = 0
[    1.367476] Loading iSCSI transport class v2.0-870.
[    1.373459] usbcore: registered new interface driver smsc95xx
[    1.379583] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.590734] Core Release: 2.80a
[    1.594078] Setting default values for core params
[    1.599025] Finished setting default values for core params
[    1.809838] Using Buffer DMA mode
[    1.813289] Periodic Transfer Interrupt Enhancement - disabled
[    1.819258] Multiprocessor Interrupt Enhancement - disabled
[    1.824984] OTG VER PARAM: 0, OTG VER FLAG: 0
[    1.829453] Dedicated Tx FIFOs mode
[    1.833893] dwc_otg: Microframe scheduler enabled
[    1.834254] dwc_otg bcm2708_usb: DWC OTG Controller
[    1.839333] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[    1.846868] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[    1.852658] Init: Port Power? op_state=1
[    1.856684] Init: Power Port (0)
[    1.860090] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.867087] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.874510] usb usb1: Product: DWC OTG Controller
[    1.879334] usb usb1: Manufacturer: Linux 3.6.11+ dwc_otg_hcd
[    1.885241] usb usb1: SerialNumber: bcm2708_usb
[    1.896226] hub 1-0:1.0: USB hub found
[    1.905624] hub 1-0:1.0: 1 port detected
[    1.915409] dwc_otg: FIQ enabled
[    1.915428] dwc_otg: NAK holdoff enabled
[    1.915450] Module dwc_common_port init
[    1.915696] Initializing USB Mass Storage driver...
[    1.926354] usbcore: registered new interface driver usb-storage
[    1.937873] USB Mass Storage support registered.
[    1.948109] usbcore: registered new interface driver libusual
[    1.959645] mousedev: PS/2 mouse device common for all mice
[    1.971577] bcm2835-cpufreq: min=700000 max=900000 cur=700000
[    1.977448] bcm2835-cpufreq: switching to governor powersavebcm2835-cpufreq: switching to governor powersave
[    1.993014] cpuidle: using governor ladder
[    2.008357] cpuidle: using governor menu
[    2.018073] sdhci: Secure Digital Host Controller Interface driver
[    2.029963] sdhci: Copyright(c) Pierre Ossman
[    2.040000] sdhci: Enable low-latency mode
[    2.092131] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[    2.105873] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[    2.119607] Indeed it is in host mode hprt0 = 00021501
[    2.130618] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.159363] usbcore: registered new interface driver usbhid
[    2.191930] usbhid: USB HID core driver
[    2.212436] TCP: cubic registered
[    2.241953] Initializing XFRM netlink socket
[    2.253713] mmc0: could read SD Status register (SSR) at the 3th attempt
[    2.271965] NET: Registered protocol family 17
[    2.292183] Key type dns_resolver registered
[    2.303768] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    2.317441] mmc0: new high speed SDHC card at address e624
[    2.329483] registered taskstats version 1
[    2.340049] mmcblk0: mmc0:e624 SU32G 29.7 GiB
[    2.355093]  mmcblk0: p1 p2
[    2.422004] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.435618] Indeed it is in host mode hprt0 = 00001101
[    2.652350] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[    2.666228] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.680183] hub 1-1:1.0: USB hub found
[    2.691212] hub 1-1:1.0: 3 ports detected
[    2.895765] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 102
[    2.896373] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 94
[    2.896597] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 93
[    2.896747] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 92
[    2.896915] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 91
[    2.897069] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 89
[    2.897244] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 88
[    2.897452] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 87
[    2.908905] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 131074
[    2.909137] EXT4-fs (mmcblk0p2): 9 orphan inodes deleted
[    2.920615] EXT4-fs (mmcblk0p2): recovery complete
[    2.982137] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    2.994937] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    3.009322] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    3.036928] devtmpfs: mounted
[    3.046449] Freeing init memory: 128K
[    3.132687] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    3.146317] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.163839] smsc95xx v1.0.4
[    3.236894] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:37:ca:7c
[    3.332200] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
[    3.446172] usb 1-1.2: New USB device found, idVendor=13ee, idProduct=0003
[    3.446186] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.446195] usb 1-1.2: Product: Optical Mouse
[    3.446204] usb 1-1.2: Manufacturer: MosArt
[    3.452276] input: MosArt Optical Mouse as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input0
[    3.471235] hid-generic 0003:13EE:0003.0001: input,hidraw0: USB HID v1.10 Mouse [MosArt Optical Mouse] on usb-bcm2708_usb-1.2/input0
[    3.592230] usb 1-1.3: new low-speed USB device number 5 using dwc_otg
[    3.707652] usb 1-1.3: New USB device found, idVendor=0e8f, idProduct=0040
[    3.723347] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.737447] usb 1-1.3: Product: USB Keyboard
[    3.748300] usb 1-1.3: Manufacturer: BIAODI
[    3.769717] input: BIAODI USB Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input1
[    3.788027] hid-generic 0003:0E8F:0040.0002: input,hidraw1: USB HID v1.10 Keyboard [BIAODI USB Keyboard] on usb-bcm2708_usb-1.3/input0
[    3.818401] input: BIAODI USB Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.1/input/input2
[    3.838869] hid-generic 0003:0E8F:0040.0003: input,hidraw2: USB HID v1.10 Device [BIAODI USB Keyboard] on usb-bcm2708_usb-1.3/input1
[    4.781417] udevd[142]: starting version 175
[    6.118994] Registered led device: led0
[   10.392437] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   10.890644] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   11.676520] bcm2835 ALSA card created!
[   11.699482] bcm2835 ALSA chip created!
[   11.716697] bcm2835 ALSA chip created!
[   11.731860] bcm2835 ALSA chip created!
[   11.747560] bcm2835 ALSA chip created!
[   11.761657] bcm2835 ALSA chip created!
[   11.775852] bcm2835 ALSA chip created!
[   11.789782] bcm2835 ALSA chip created!
[   16.357072] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[   16.371501] mmc0: DMA IRQ 6 ignored - results were reset
[   20.724820] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[   21.638120] bcm2835-cpufreq: switching to governor ondemand
[   21.638151] bcm2835-cpufreq: switching to governor ondemand<6>[   24.337956] Adding 102396k swap on /var/swap.  Priority:-1 extents:129 across:1754856k SS
[   26.064095] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[   26.064095]
[   26.064217] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[   26.064217]
[   26.064247] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[   26.064247]
[   26.081989] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[   26.081989]
[   26.082032] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[   26.082032]
[   26.182246] usb 1-1: USB disconnect, device number 2
[   26.182276] usb 1-1.1: USB disconnect, device number 3
[   26.182510] smsc95xx 1-1.1:1.0: eth0: unregister 'smsc95xx' usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet
[   26.192852] usb 1-1.2: USB disconnect, device number 4
[   26.195958] usb 1-1.3: USB disconnect, device number 5
[   26.372075] Indeed it is in host mode hprt0 = 00021501
[   26.772078] usb 1-1: new high-speed USB device number 6 using dwc_otg
[   26.772249] Indeed it is in host mode hprt0 = 00001101
[   27.182356] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[   27.182386] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[   27.192315] hub 1-1:1.0: USB hub found
[   27.192466] hub 1-1:1.0: 3 ports detected
[   27.472235] usb 1-1.1: new high-speed USB device number 7 using dwc_otg
[   27.572618] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[   27.572646] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[   27.576073] smsc95xx v1.0.4
[   27.638409] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:37:ca:7c
[   27.733358] usb 1-1.2: new low-speed USB device number 8 using dwc_otg
[   27.836144] usb 1-1.2: New USB device found, idVendor=13ee, idProduct=0003
[   27.836173] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   27.836187] usb 1-1.2: Product: Optical Mouse
[   27.836198] usb 1-1.2: Manufacturer: MosArt
[   27.841369] input: MosArt Optical Mouse as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input3
[   27.844828] hid-generic 0003:13EE:0003.0004: input,hidraw0: USB HID v1.10 Mouse [MosArt Optical Mouse] on usb-bcm2708_usb-1.2/input0
[   27.932298] usb 1-1.3: new low-speed USB device number 9 using dwc_otg
[   28.037529] usb 1-1.3: New USB device found, idVendor=0e8f, idProduct=0040
[   28.037559] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   28.037573] usb 1-1.3: Product: USB Keyboard
[   28.037584] usb 1-1.3: Manufacturer: BIAODI
[   28.045179] input: BIAODI USB Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input4
[   28.048942] hid-generic 0003:0E8F:0040.0005: input,hidraw1: USB HID v1.10 Keyboard [BIAODI USB Keyboard] on usb-bcm2708_usb-1.3/input0
[   28.062631] input: BIAODI USB Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.1/input/input5
[   28.073347] hid-generic 0003:0E8F:0040.0006: input,hidraw2: USB HID v1.10 Device [BIAODI USB Keyboard] on usb-bcm2708_usb-1.3/input1
[   29.782189] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[   30.294810] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[   30.294810]
[   30.294911] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[   30.294911]
[   30.294946] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[   30.294946]
[   30.311987] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[   30.311987]
[   30.312031] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[   30.312031]
[   30.312055] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[   30.312055]
[   30.432092] usb 1-1: USB disconnect, device number 6
[   30.432122] usb 1-1.1: USB disconnect, device number 7
[   30.432336] smsc95xx 1-1.1:1.0: eth0: unregister 'smsc95xx' usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet
[   30.443627] usb 1-1.2: USB disconnect, device number 8
[   30.446129] usb 1-1.3: USB disconnect, device number 9
[   30.622085] Indeed it is in host mode hprt0 = 00021501
[   30.932087] usb 1-1: new high-speed USB device number 10 using dwc_otg
[   30.932279] Indeed it is in host mode hprt0 = 00001101
[   31.422329] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[   31.422358] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[   31.433056] hub 1-1:1.0: USB hub found
[   31.433212] hub 1-1:1.0: 3 ports detected
[   31.712274] usb 1-1.1: new high-speed USB device number 11 using dwc_otg
[   31.812652] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[   31.812681] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[   31.815601] smsc95xx v1.0.4
[   31.880207] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:37:ca:7c
[   31.972311] usb 1-1.2: new low-speed USB device number 12 using dwc_otg
[   32.076173] usb 1-1.2: New USB device found, idVendor=13ee, idProduct=0003
[   32.076203] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   32.076218] usb 1-1.2: Product: Optical Mouse
[   32.076230] usb 1-1.2: Manufacturer: MosArt
[   32.081489] input: MosArt Optical Mouse as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input6
[   32.086181] hid-generic 0003:13EE:0003.0007: input,hidraw0: USB HID v1.10 Mouse [MosArt Optical Mouse] on usb-bcm2708_usb-1.2/input0
[   32.172212] usb 1-1.3: new low-speed USB device number 13 using dwc_otg
[   32.277877] usb 1-1.3: New USB device found, idVendor=0e8f, idProduct=0040
[   32.277907] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   32.277921] usb 1-1.3: Product: USB Keyboard
[   32.277933] usb 1-1.3: Manufacturer: BIAODI
[   32.285218] input: BIAODI USB Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input7
[   32.288812] hid-generic 0003:0E8F:0040.0008: input,hidraw1: USB HID v1.10 Keyboard [BIAODI USB Keyboard] on usb-bcm2708_usb-1.3/input0
[   32.302700] input: BIAODI USB Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.1/input/input8
[   32.308263] hid-generic 0003:0E8F:0040.0009: input,hidraw2: USB HID v1.10 Device [BIAODI USB Keyboard] on usb-bcm2708_usb-1.3/input1
[   34.175378] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[   47.798301] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[   47.798301]
[   47.798415] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[   47.798415]
[   47.798454] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[   47.798454]
[   47.811985] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[   47.811985]
[   47.812045] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[   47.812045]
[   47.812070] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[   47.812070]
[   47.932087] usb 1-1: USB disconnect, device number 10
[   47.932115] usb 1-1.1: USB disconnect, device number 11
[   47.932328] smsc95xx 1-1.1:1.0: eth0: unregister 'smsc95xx' usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet
[   47.943740] usb 1-1.2: USB disconnect, device number 12
[   47.946051] usb 1-1.3: USB disconnect, device number 13
[   48.112074] Indeed it is in host mode hprt0 = 00021501
[   48.542058] usb 1-1: new high-speed USB device number 14 using dwc_otg
[   48.542228] Indeed it is in host mode hprt0 = 00001101
[   48.932372] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[   48.932400] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[   48.942250] hub 1-1:1.0: USB hub found
[   48.942400] hub 1-1:1.0: 3 ports detected
[   49.222385] usb 1-1.1: new high-speed USB device number 15 using dwc_otg
[   49.322553] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[   49.322582] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[   49.325502] smsc95xx v1.0.4
[   49.386736] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:37:ca:7c
[   49.482214] usb 1-1.2: new low-speed USB device number 16 using dwc_otg
[   49.586071] usb 1-1.2: New USB device found, idVendor=13ee, idProduct=0003
[   49.586102] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   49.586115] usb 1-1.2: Product: Optical Mouse
[   49.586127] usb 1-1.2: Manufacturer: MosArt
[   49.591317] input: MosArt Optical Mouse as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input9
[   49.601056] hid-generic 0003:13EE:0003.000A: input,hidraw0: USB HID v1.10 Mouse [MosArt Optical Mouse] on usb-bcm2708_usb-1.2/input0
[   49.692245] usb 1-1.3: new low-speed USB device number 17 using dwc_otg
[   49.797592] usb 1-1.3: New USB device found, idVendor=0e8f, idProduct=0040
[   49.797623] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   49.797637] usb 1-1.3: Product: USB Keyboard
[   49.797649] usb 1-1.3: Manufacturer: BIAODI
[   49.805204] input: BIAODI USB Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input10
[   49.808987] hid-generic 0003:0E8F:0040.000B: input,hidraw1: USB HID v1.10 Keyboard [BIAODI USB Keyboard] on usb-bcm2708_usb-1.3/input0
[   49.822579] input: BIAODI USB Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.1/input/input11
[   49.833220] hid-generic 0003:0E8F:0040.000C: input,hidraw2: USB HID v1.10 Device [BIAODI USB Keyboard] on usb-bcm2708_usb-1.3/input1
[   51.602257] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[  128.311136] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[  128.311136]
[  128.311260] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[  128.311260]
[  128.311295] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[  128.311295]
[  128.321995] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[  128.321995]
[  128.322044] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[  128.322044]
[  128.322073] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[  128.322073]
[  128.432012] usb 1-1: USB disconnect, device number 14
[  128.432042] usb 1-1.1: USB disconnect, device number 15
[  128.432292] smsc95xx 1-1.1:1.0: eth0: unregister 'smsc95xx' usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet
[  128.443847] usb 1-1.2: USB disconnect, device number 16
[  128.446428] usb 1-1.3: USB disconnect, device number 17
[  128.632087] Indeed it is in host mode hprt0 = 00021501
[  128.912065] usb 1-1: new high-speed USB device number 18 using dwc_otg
[  128.912247] Indeed it is in host mode hprt0 = 00001101
[  129.132207] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[  129.132235] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[  129.143751] hub 1-1:1.0: USB hub found
[  129.143887] hub 1-1:1.0: 3 ports detected
[  129.422128] usb 1-1.1: new high-speed USB device number 19 using dwc_otg
[  129.522528] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[  129.522573] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[  129.525813] smsc95xx v1.0.4
[  129.587768] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:37:ca:7c
[  129.682184] usb 1-1.2: new low-speed USB device number 20 using dwc_otg
[  129.786418] usb 1-1.2: New USB device found, idVendor=13ee, idProduct=0003
[  129.786466] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  129.786486] usb 1-1.2: Product: Optical Mouse
[  129.786501] usb 1-1.2: Manufacturer: MosArt
[  129.794227] input: MosArt Optical Mouse as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input12
[  129.798074] hid-generic 0003:13EE:0003.000D: input,hidraw0: USB HID v1.10 Mouse [MosArt Optical Mouse] on usb-bcm2708_usb-1.2/input0
[  129.892369] usb 1-1.3: new low-speed USB device number 21 using dwc_otg
[  129.999288] usb 1-1.3: New USB device found, idVendor=0e8f, idProduct=0040
[  129.999320] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  129.999338] usb 1-1.3: Product: USB Keyboard
[  129.999368] usb 1-1.3: Manufacturer: BIAODI
[  130.007071] input: BIAODI USB Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input13
[  130.011318] hid-generic 0003:0E8F:0040.000E: input,hidraw1: USB HID v1.10 Keyboard [BIAODI USB Keyboard] on usb-bcm2708_usb-1.3/input0
[  130.022793] input: BIAODI USB Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.1/input/input14
[  130.023540] hid-generic 0003:0E8F:0040.000F: input,hidraw2: USB HID v1.10 Device [BIAODI USB Keyboard] on usb-bcm2708_usb-1.3/input1
[  131.329704] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[  135.060483] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[  135.060483]
[  135.060572] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[  135.060572]
[  135.060598] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[  135.060598]
[  135.071984] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[  135.071984]
[  135.072029] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[  135.072029]
[  135.072054] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[  135.072054]
[  135.182067] usb 1-1: USB disconnect, device number 18
[  135.182097] usb 1-1.1: USB disconnect, device number 19
[  135.182314] smsc95xx 1-1.1:1.0: eth0: unregister 'smsc95xx' usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet
[  135.193673] usb 1-1.2: USB disconnect, device number 20
[  135.233460] usb 1-1.3: USB disconnect, device number 21
[  135.402058] Indeed it is in host mode hprt0 = 00021501
[  135.812156] usb 1-1: new high-speed USB device number 22 using dwc_otg
[  135.812326] Indeed it is in host mode hprt0 = 00001101
[  136.172209] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[  136.172237] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[  136.180582] hub 1-1:1.0: USB hub found
[  136.180738] hub 1-1:1.0: 3 ports detected
[  136.452166] usb 1-1.1: new high-speed USB device number 23 using dwc_otg
[  136.552556] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[  136.552584] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[  136.565010] smsc95xx v1.0.4
[  136.627452] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:37:ca:7c
[  136.722167] usb 1-1.2: new low-speed USB device number 24 using dwc_otg
[  136.826560] usb 1-1.2: New USB device found, idVendor=13ee, idProduct=0003
[  136.826608] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  136.826627] usb 1-1.2: Product: Optical Mouse
[  136.826641] usb 1-1.2: Manufacturer: MosArt
[  136.834227] input: MosArt Optical Mouse as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input15
[  136.838146] hid-generic 0003:13EE:0003.0010: input,hidraw0: USB HID v1.10 Mouse [MosArt Optical Mouse] on usb-bcm2708_usb-1.2/input0
[  136.932404] usb 1-1.3: new low-speed USB device number 25 using dwc_otg
[  137.039029] usb 1-1.3: New USB device found, idVendor=0e8f, idProduct=0040
[  137.039059] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  137.039074] usb 1-1.3: Product: USB Keyboard
[  137.039087] usb 1-1.3: Manufacturer: BIAODI
[  137.046466] input: BIAODI USB Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input16
[  137.050042] hid-generic 0003:0E8F:0040.0011: input,hidraw1: USB HID v1.10 Keyboard [BIAODI USB Keyboard] on usb-bcm2708_usb-1.3/input0
[  137.058924] input: BIAODI USB Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.1/input/input17
[  137.059590] hid-generic 0003:0E8F:0040.0012: input,hidraw2: USB HID v1.10 Device [BIAODI USB Keyboard] on usb-bcm2708_usb-1.3/input1
[  138.409333] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[  318.861373] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[  318.861373]
[  318.861501] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[  318.861501]
[  318.861547] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[  318.861547]
[  318.871968] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[  318.871968]
[  318.872014] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[  318.872014]
[  318.872039] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[  318.872039]
[  318.892036] usb 1-1: USB disconnect, device number 22
[  318.892066] usb 1-1.1: USB disconnect, device number 23
[  318.892284] smsc95xx 1-1.1:1.0: eth0: unregister 'smsc95xx' usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet
[  319.162549] usb 1-1.2: USB disconnect, device number 24
[  319.206972] usb 1-1.3: USB disconnect, device number 25
[  319.492041] Indeed it is in host mode hprt0 = 00021501
[  319.672420] usb 1-1: new high-speed USB device number 26 using dwc_otg
[  319.672590] Indeed it is in host mode hprt0 = 00001101
[  319.873069] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[  319.873103] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[  319.883465] hub 1-1:1.0: USB hub found
[  319.883590] hub 1-1:1.0: 3 ports detected
[  320.162115] usb 1-1.1: new high-speed USB device number 27 using dwc_otg
[  320.262551] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[  320.262584] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[  320.265799] smsc95xx v1.0.4
[  320.327071] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:37:ca:7c
[  320.422194] usb 1-1.2: new low-speed USB device number 28 using dwc_otg
[  320.526038] usb 1-1.2: New USB device found, idVendor=13ee, idProduct=0003
[  320.526086] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  320.526104] usb 1-1.2: Product: Optical Mouse
[  320.526119] usb 1-1.2: Manufacturer: MosArt
[  320.533946] input: MosArt Optical Mouse as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input18
[  320.536624] hid-generic 0003:13EE:0003.0013: input,hidraw0: USB HID v1.10 Mouse [MosArt Optical Mouse] on usb-bcm2708_usb-1.2/input0
[  320.622216] usb 1-1.3: new low-speed USB device number 29 using dwc_otg
[  320.728874] usb 1-1.3: New USB device found, idVendor=0e8f, idProduct=0040
[  320.728908] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  320.728925] usb 1-1.3: Product: USB Keyboard
[  320.728939] usb 1-1.3: Manufacturer: BIAODI
[  320.736553] input: BIAODI USB Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input19
[  320.741447] hid-generic 0003:0E8F:0040.0014: input,hidraw1: USB HID v1.10 Keyboard [BIAODI USB Keyboard] on usb-bcm2708_usb-1.3/input0
[  320.752730] input: BIAODI USB Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.1/input/input20
[  320.753483] hid-generic 0003:0E8F:0040.0015: input,hidraw2: USB HID v1.10 Device [BIAODI USB Keyboard] on usb-bcm2708_usb-1.3/input1
[  322.033291] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Re: RPI loose its IP address, not reason given.
Posted: Fri Feb 15, 2013 8:18 am
by pluggy
Power supply. Check the voltage across TP1 and TP2. The Ethernet likes something close to 5v to work reliably. What it says on the PSU label doesn't mean much, measuring the voltage also checks out the lead to the Pi and the F3 polyfuse which can be a pain. If you've got close to 5v (> 4.8v ideally) then its likely to be a returns job.
Overheating is almost totally a non issue on the Pi. It doesn't burn enough juice. The chips are good to 85C (if it were big enough you could cook an egg on it). If you can't its likely one that was short-changed in the reflow oven.
Posted: Fri Feb 15, 2013 10:10 am
by jojopi
dmesg is only the logs from the kernel. The kernel will not remove the address from an interface unless something tells it to. Check the files in /var/log, perhaps starting with /var/log/daemon.log, which is where dhclient messages go.
On the other hand, the lack of kernel logs rules out problems with power to the lan chip I think.
