chaicoffee_08
Re: D.Link DWA 131 WLAN/USB Adapter not working
Sun May 31, 2015 11:31 am
hey Mr. Engman
kudos and thanks a lot! i just got a new dongle and it's finally working now.
running 3.18.14.-v7
cheers! more power to you :)
jackm
Wed Jun 10, 2015 2:07 pm
Thanks for instructions as on 30 Mar. Worked like a charm! Hope drivers get included soon.
waxcomb
Mon Jul 27, 2015 10:39 am
Thank you EngMan!!!!
Martin7637
Mon Jul 27, 2015 7:35 pm
Hi. I tried to my D link dwa131E1 work but successless.
~ $ uname -a
Linux raspberrypi 3.18.11+ #781 PREEMPT Tue Apr 21 18:02:18 BST 2015 armv6l GNU/Linux
I write:
~ $ wget https://dl.dropboxusercontent.com/u/80256631/8192eu-3.18.11-781.tar.gz
~ $ tar -xzf 8192eu-3.18.11-781.tar.gz
~ $ sudo install -p -m 644 8192eu.ko /lib/modules/3.18.7+/kernel/drivers/net/wireless
and obtain:
install: impossible de créer le fichier standard « /lib/modules/3.18.7+/kernel/drivers/net/wireless »: Aucun fichier ou dossier de ce type
And with:
 ~ $ ./install.sh
sudo cp 8192eu.conf /etc/modprobe.d/.
sudo install -p -m 644 8192eu.ko /lib/modules/3.18.11+/kernel/drivers/net/wirele ss
install: impossible de créer le fichier standard « /lib/modules/3.18.11+/kernel/ drivers/net/wireless »: Aucun fichier ou dossier de ce type
sudo depmod 3.18.11+
ERROR: could not open directory /lib/modules/3.18.11+: No such file or directory
FATAL: could not search modules: No such file or directory
Reboot to run the driver.
If you have already configured your wifi it should start up and connect to your
wireless network.
If you have not configured your wifi you will need to do that to enable the wifi .
Please need help
(sorry for the english, I'm french)
redhenk
Mon Jul 27, 2015 9:23 pm
What is the result of uname -a in a terminal?
Pi B, Pi 2B, Pi zero, Pi 3B
MrEngman
Mon Jul 27, 2015 9:45 pm
Hi Martin763,
You say command uname -a shows 3.18.11+ #781, but the ./install.sh command says the install directory /lib/modules/3.18.11+/kernel/drivers/net/wireless using 3.18.11+ does not exist. Have you made any changes or deleted any directories?
Reboot your Pi then run command uname -a again and post the output.
What does the command ls -l /lib/modules show?
MrEngman
Martin7637
Wed Jul 29, 2015 5:09 am
Hi MrE :),
thank you for your quick answer.
Hum..
Linux raspberrypi 3.18.14+ #2 PREEMPT Thu May 28 18:09:28 UTC 2015 armv6l GNU/Linux
total 8
drwxr-xr-x 3 root root 4096 juil. 27 17:32 3.18.14+
drwxr-xr-x 3 root root 4096 juil. 27 17:32 3.18.14-v7+
Strange... So I tried to download from your dropbox but I think it don't exist yet.
MrEngman
Wed Jul 29, 2015 6:12 am
Martin7637 wrote:Hi MrE :),
Hum..
What OS are you running? The drivers I compile are for raspbian but the output from uname -a would indicate your kernel is not raspbian.
MrEngman
Martin7637
Wed Jul 29, 2015 6:19 pm
Yes it's raspbian from NOOBS.
MrEngman
Thu Jul 30, 2015 12:08 am
Martin7637 wrote:Yes it's raspbian from NOOBS.
Not exactly as far as I can tell. You may have installed raspbian using NOOBS but it has been updated and actually appears to be the Adafruit version which is not the same as the standard raspbian image.
However, you may be lucky as I have compiled some drivers for the Adafruit 3.18.14 versions, the 8192eu driver among them.
You can try this
wget https://dl.dropboxusercontent.com/u/80256631/Ada-8192eu-3.18.14.tar.gz
tar xzf Ada-8192eu-3.18.14.tar.gz
./install.sh
After installing reboot and configure your wifi. I have configured mine by editing the file /etc/wpa_supplicant/wpa_supplicant.conf. Like
update_config=1
network={
        ssid="network-name"
        psk="network-password"
NOTE: I have had a problem loading wifi drivers with the Adafruit images due to a problem with a module that is included but, for some really obscure reason, does not appear to be compatible with the image and appears to stop the TFT screens from working. After installing the wifi driver reboot and if the TFT screen stops working move the files, fb_sys_fops.ko, to a different directory using the commands
cd
sudo mv /lib/modules/3.18.14+/kernel/drivers/video/fbdev/core/fb_sys_fops.ko ./fb_sys_fops.ko.b1
sudo mv /lib/modules/3.18.14-v7+/kernel/drivers/video/fbdev/core/fb_sys_fops.ko ./fb_sys_fops.ko.b2
and then reboot again. These commands will save the file for the Pi B,B+ as fb_sys_fops.ko.b1 and the file for the Pi 2B as fb_sys_fops.ko.b2 in your home directory in case you need to recover them for any reason
MrEngman
Martin7637
Thu Jul 30, 2015 5:02 am
Thank you I will try this soon. To well understand, it means that everytime I will update my pi, the dongle wifi will not work?
MrEngman
Thu Jul 30, 2015 7:34 am
Martin7637 wrote:Thank you I will try this soon. To well understand, it means that everytime I will update my pi, the dongle wifi will not work?
Yes, you will need to download a new driver, if there is one.
MrEngman
jfredsilva
Sat Aug 01, 2015 1:04 am
I'm trying to install this adapter on a Xbian.
uname-a give me
Linux xbian 4.1.2+ #14 PREEMPT Tue Jul 21 23:18:05 CEST 2015 armv6l GNU/Linux
So I write
wget https://dl.dropboxusercontent.com/u/80256631/8192eu-4.1.2-14.tar.gz
The response is
ERROR 404: Not Found.
What am I doing wrong?
MrEngman
Sat Aug 01, 2015 8:56 am
jfredsilva wrote:I'm trying to install this adapter on a Xbian.
uname-a give me
So I write
The response is
Sorry, but I don't have drivers for Xbian.
MrEngman
oneinsect
Sun Aug 02, 2015 8:26 pm
https://dl.dropboxusercontent.com/u/80256631/8192eu-4.0.9-v7-807.tar.gz
Must thank MrEngman for the above. :D
sealy_au
Fri Aug 07, 2015 2:10 pm
Hi guys,
having the same issuses with this adaptor its a dwa-131 rev e
uname -a
Linux raspmedia 4.1.4-v7+ #808 SMP PREEMPT Thu Aug 6 16:59:39 BST 2015 armv7l GNU/Linux
dmesg
[ 3.925196] usb 1-1.4: new high-speed USB device number 6 using dwc_otg
[ 4.037345] usb 1-1.4: New USB device found, idVendor=2001, idProduct=3319
[ 4.053869] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.070685] usb 1-1.4: Product: Wireless N Nano USB Adapter
[ 4.087926] usb 1-1.4: SerialNumber: 00e04c000001
MrEngman
Fri Aug 07, 2015 3:59 pm
sealy_au wrote:Hi guys,
uname -a
dmesg
Try this to download and install the driver
wget https://dl.dropboxusercontent.com/u/80256631/8192eu-4.1.4-v7-808.tar.gz
tar xzf 8192eu-4.1.4-v7-808.tar.gz
./install.sh
After installing the driver reboot and then you will need to configure your wifi to connect to your network.
MrEngman
Untoldtruth
Tue Aug 11, 2015 12:44 pm
Hey Mr Eggman.
I'm trying to get a hold of your drivers for the DWA-131 E1 and i'm running into 404 errors. is there any alternative way i could download them?
much appreciated.
MrEngman
Wed Aug 12, 2015 7:25 am
Untoldtruth wrote:Hey Mr Eggman.
much appreciated.
The download from dropbox is OK for me but you could try this instead
wget http://www.fars-robotics.net/8192eu-4.1.4-v7-808.tar.gz
./install.sh
MrEngman
Librentez
Mon Aug 17, 2015 3:23 pm
MrEngman,
Your compiled driver is working on my Pi, but I'm not able to compile and I would like to understand why.
- Can you give us the source that you use to compile ?
- Which version of GCC are you using ?
My Kernel (Minibian) :
Linux raspberrypi 3.18.7+ #755 PREEMPT Thu Feb 12 17:14:31 GMT 2015 armv6l GNU/Linux
What I do :
mkdir src
cd src
FIRMWARE_HASH=$(zgrep "* firmware as of" /usr/share/doc/raspberrypi-bootloader/changelog.Debian.gz | head -1 | awk '{ print $5 }')
KERNEL_HASH=$(wget https://raw.github.com/raspberrypi/firmware/$FIRMWARE_HASH/extra/git_hash -O -)
wget https://github.com/raspberrypi/linux/archive/$KERNEL_HASH.tar.gz
tar -xvzf $KERNEL_HASH.tar.gz
mv linux-$KERNEL_HASH/ linux/
ln -s /root/src/linux/ /lib/modules/$(uname -r)/build
ln -s /root/src/linux/arch/arm /root/src/linux/arch/armv6l
cd linux/
make mrproper
make bcmrpi_defconfig
make modules_prepare
wget https://raw.githubusercontent.com/raspberrypi/firmware/8aca5762f984f6decbeda294cee8418966c3d8d3/extra/Module.symvers
Everything go smooth !
So far I tested 2 drivers :
- rtl8192EU_linux_v4.2.2_7585.20130524 :
- Compile : [Error]
- rtl8192EU_linux_v4.3.1.1_11320.20140505
- Compile : [Ok]
- Loading : Crash
rtl8192EU_linux_v4.2.2_7585.20130524 compilation error :
CC [M]  /root/src/rtl8192EU_linux_v4.2.2_7585.20130524/os_dep/linux/os_intfs.o
/root/src/rtl8192EU_linux_v4.2.2_7585.20130524/os_dep/linux/os_intfs.c: In function ‘rtw_proc_init_one’:
/root/src/rtl8192EU_linux_v4.2.2_7585.20130524/os_dep/linux/os_intfs.c:355:3: error: implicit declaration of function ‘create_proc_entry’ [-Werror=implicit-function-declaration]
create_proc_entry is deprecated since 3.10 I think, any idea ? My idea is that i don't have the right driver source :).
Thanks !
Ronan
MrEngman
Mon Aug 17, 2015 6:12 pm
Librentez wrote:MrEngman,
What I do :
mkdir src
cd src
cd linux/
make mrproper
- Compile : [Error]
- Compile : [Ok]
- Loading : Crash
Thanks !
Ronan
I normally cross-compile my drivers on a PC running Ubuntu 14.0.2, however I have previously compiled on the RPi. Compiling on the Pi I found one of the drivers crashed the kernel when it booted which did not happen when I cross-compiled on the PC. I never worked out why the driver crashed. I have not seen the 8192eu driver causing any problems.
The 8192eu driver I use I got from here https://sites.google.com/site/easylinux ... /reserve-7. I believe it is an updated version of the Maxxter driver with patches to handle the error you see. It may also require an additional patch
diff -Naur 8192eu/os_dep/linux/rtw_android.c rtl8192eus/os_dep/linux/rtw_android.c
--- 8192eu/os_dep/linux/rtw_android.c   2015-05-10 14:14:00.286604282 +0100
+++ rtl8192eus/os_dep/linux/rtw_android.c       2015-06-21 21:21:21.017365835 +0100
@@ -224,7 +224,7 @@
        int cmd_num;
        for(cmd_num=0 ; cmd_num<ANDROID_WIFI_CMD_MAX; cmd_num++)
-               if(0 == strnicmp(cmdstr , android_wifi_cmd_str[cmd_num], strlen(android_wifi_cmd_str[cmd_num])) )
+               if(0 == strncasecmp(cmdstr , android_wifi_cmd_str[cmd_num], strlen(android_wifi_cmd_str[cmd_num])) )
                        break;
        return cmd_num;
Regarding gcc I believe ideally it should be compiled with the same compiler version used to compile the kernel. The compiler available as standard on the RPi is a rather older version, 4.6. On the Pi I have updated the compiler using this https://somewideopenspace.wordpress.com ... pi-wheezy/. It is possible to update to a gcc-4.8 version using apt-get but I think that compiler version is an older version of gcc-4.8 and has a problem.
MrEngman
d4vidb
Tue Aug 25, 2015 12:04 pm
MrEngman wrote:
puddle wrote:hello
i also have the e1 version i'm trying to use with my pi2 b+. I rolled back from 3.18.10-v7+ to use mr engmans driver but the links are expired. anyone willing to provide a working driver with our device id or possibly a little guide on how to modify/compile it ourselves so to be able to update freely until it is included?
There is a linux driver for this model on the Australian website http://support.dlink.com.au/Download/do ... pe=Drivers
I've tried to install it but it fails on the "make"command. Any advice would be appreciated.
tia
I have drivers available for all 3.18 versions of raspbian. The name of the driver is defined using the kernel version and build number. Use command uname -a to check your kernel version and build and the file to download will be 8192eu-kernel-build.tar.gz.
As an example my Pi B 2 uname -a shows
Linux Pi-B-2 3.18.10-v7+ #774 SMP PREEMPT Wed Mar 25 14:10:30 GMT 2015 armv7l GNU/Linux
so the driver to download for my Pi B 2 would be 8192eu-3.18.10-v7-774.tar.gz.
Another example my Pi A uname -a shows
Linux pi-A 3.18.9+ #768 PREEMPT Sun Mar 15 18:59:03 GMT 2015 armv6l GNU/Linux
so the driver to download for my Pi A would be 8192eu-3.18.9-768.tar.gz.
To download and install use the commands
wget https://dl.dropboxusercontent.com/u/80256631/8192eu-kernel-build.tar.gz
tar xzf 8192eu-kernel-build.tar.gz
./install.sh
substituting the kernel and build values from your uname -a command in the filename for the wget and tar commands.
Hopefully this is not too confusing and you can download the driver and get your wifi up and running.
MrEngman
Hello, can you get me driver for 4.1.6+? Thank
MrEngman
Tue Aug 25, 2015 3:19 pm
d4vidb wrote:
MrEngman wrote:
puddle wrote:hello
tia
./install.sh
MrEngman
Just use the info in the post to get the driver filename to download and install the driver.
What does command uname -a show?
MrEngman
d4vidb
Tue Aug 25, 2015 5:50 pm
This uname -a prints:
Linux smart-home 4.1.6+ #810 PREEMPT Tue Aug 18 15:19:58 BST 2015 armv6l GNU/Linux
And lsusb:
root@smart-home:~# lsusb
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 004: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
Bus 001 Device 005: ID 2001:3319 D-Link Corp.
MrEngman
Tue Aug 25, 2015 7:15 pm
d4vidb wrote:This uname -a prints:
And lsusb:
So kernel version is 4.1.6+ and build is #810 so to download and install use commands
wget https://dl.dropboxusercontent.com/u/80256631/8192eu-4.1.6-810.tar.gz
tar xzf 8192eu-4.1.6-810.tar.gz
./install.sh
and after running the ./install.sh command, reboot to bring up the driver.
MrEngman
