DragShot
Begging for HELP!
Wed Feb 13, 2013 7:57 am
When using HDMI, my picture is color distorted. Its flashes red and blue and shakes.
Any ideas on what i could do?
The following are changes i have already made to my config file;
hdmi_safe=1
disable_overscan=1
hdmi_group=1
hdmi_mode=16
config_hdmi_boost=4
sdtv_mode=0
aspect ratio
sdtv_aspect=3
Here is what it looks like
THANKS!
malakai
Re: Begging for HELP!
Wed Feb 13, 2013 8:07 am
I would go with a bad cable there are no color settings in the config files that I am aware of. Do you have any other device that has used the HDMI cable and same connection on the monitor?
Last place would be possible bad HDMI connection on the Pi itself. Is anything else plugged into it and what version of Pi 512MB?
DragShot
Wed Feb 13, 2013 8:12 am
Thanks for the reply
I have a Cable Box connected to hdmi looks great. took the hdmi from it and connected to RPi and same issue.
I have a USB keyboard, ethernet cable and the power connected as well.
Hope its not a bad HDMI... was so excited to get this goin
DragShot
Wed Feb 13, 2013 8:26 am
P.S. The flashing improved when updating to : config_hdmi_boost=4
but still red tint. Looks normal when using Composite cable
One thing i noticed, when running the comand (tvservice -s) to show my current setting, it says:
[DVI RGB full 4:3], 640x480 @ 60hz, progressive
all attempts to change this to say hdmi or a higher resolution have failed
might this be why it looks so bad?
DragShot
Wed Feb 13, 2013 8:27 am
Raspberry Pi B
rpdom
Wed Feb 13, 2013 8:43 am
Try without the "hdmi_safe=1". I think this setting overrides many of the others, like hdmi_mode, so you only get a basic 640x480 screen.
DragShot
Wed Feb 13, 2013 8:51 am
So interesting thing happened in doing so... Right away i could tell the 16:9 kicked in, the flashing seems to have stopped, but still red all over.
When running the tvservice -s it now shows 16:9 but still as a dvi connection.
photo (2).JPG (38.91 KiB) Viewed 1755 times
texy
Wed Feb 13, 2013 12:41 pm
DragShot wrote:Thanks for the reply
This is unclear - have you actually tried 2 different HDMI cables?
Have you tried a different screen?
Texy
devnull
Wed Feb 13, 2013 12:44 pm
Looks like you are missing the blue HDMI signal, this is almost certainly a cable / connector issue and not RPI hardware related.
I have also seen similar things with a bad connector.
PeterC
> /dev/null 2>&1
drgeoff
Wed Feb 13, 2013 1:47 pm
Try values of config_hdmi_boost greater than 4. You can go up to 7.
DragShot
Wed Feb 13, 2013 6:36 pm
I have attempted going up to 7
I have attempted 2 working HDMI cables on 2 working HDMI inputs
have not been able to attempt on another screen
I am starting to think the HDMI port on the RPI might be the issue
any other ideas?
Jim JKla
Wed Feb 13, 2013 6:40 pm
No I'd say its the port either on your monitor or the Rpi and as you eliminated the monitor end with your cable box it looks like you have a wonky RPi ;)
Noob is not derogatory the noob is just the lower end of the noob--geek spectrum being a noob is just your first step towards being an uber-geek ;)
If you find a solution please post it in the wiki the forum dies too quick
paultnl
Wed Feb 13, 2013 7:20 pm
Where are you? Someone may be able tocome round with an alternate Pi to try.
I don't like Russian dolls, they are so full of themselves
DragShot
Fri Feb 15, 2013 7:59 am
Thank you all for your help. It was in fact the HDMI port on the Pi. I had the Pi replaced and vuala beautiful picture.
But...
As always with our wonderful technology, fix one problem to encounter another.
In all my attempts to get XBMC installed/activated or whatever is required on Wheezy have resulted in utter failure. Finally found a step by step that seems reliable but sure enough, i get an error saying my 8gb card has run out of space during the installation of the libraries/dependencies.
Any recommendations on how to get XBMC with the least amount of trouble would be greatly appreciated.
Thank you all again
Jim JKla
Fri Feb 15, 2013 8:31 am
It is always going to be better to start a new thread with the problem as the subject.
For no other reason that threads with zero responses get hits. ;)
