Blank screen on SDL apps without X
Posted: Sat Feb 09, 2013 8:07 pm
by ekondis
I was trying some SDL applications (fuse-sdl, dosbox) under Raspbian without X. With an HDMI monitor they run without problems. However, when I switched to an old TV with the analog video cable whenever I run an SDL program the screen turned blank and I couldn't do anything but to connect remotely or switch the PI off. I noticed that the problem was the overscan settings I had used:
overscan_left=16
overscan_right=16
overscan_top=16
overscan_bottom=16
When I commented out all the above the problem was solved!
Does anybody knows which is the actual cause?
Re: Blank screen on SDL apps without X
Posted: Fri Sep 26, 2014 6:31 am
by meltwater
Thanks for posting this, I had the very same issue.
Must be something to do with how video is re-scaled. Wonder if there is a way to adjust the setting without rebooting (i.e. just when it is run), would make it less of a problem.
Thanks!
