GenVerti
Re: omxplayer fails to play music after update
Sun Feb 10, 2013 11:33 am
To come back to the reported issue:
To see your input again on the command line type:
reset
To have a working omxplayer again, you can remove the omxplayer package and
install the older working one (do as root).
apt-get remove omxplayer
then do
cd /var/cache/apt/archives/
ls omxplayer*
and install a previous version with
dpkg -i <filename>
if you do not have an old omxplayer version under /var/cache/apt/archives
you can get the previous from the repository directly
http://archive.raspberrypi.org/debian/p ... omxplayer/
HTH
rocketero
Mon Feb 11, 2013 2:31 am
I can concurr that omxplayer_0.2.4~subtitles~git20130128~f60f9019_armhf.deb does not work on my RPI, then I removed it, and installed a previous version omxplayer_0.2.1~git20120728~63312741_armhf.deb and this one does work
I was gettign the same message posted along this thread about error on a Symbol.
thanks to @GenVerti for posting the link to previous versions.
dom
Mon Feb 11, 2013 11:10 am
rocketero wrote:I can concurr that omxplayer_0.2.4~subtitles~git20130128~f60f9019_armhf.deb does not work on my RPI, then I removed it, and installed a previous version omxplayer_0.2.1~git20120728~63312741_armhf.deb and this one does work
The latest version requires the rpi-update firmware.
KenT
Mon Feb 11, 2013 12:14 pm
I did that, see post up the thread, but although omxplayer now works I got the black screen problem.
Pi Presents - A toolkit to produce multi-media interactive display applications for museums, visitor centres, and more
Download from http://pipresents.wordpress.com
dom
Mon Feb 11, 2013 8:46 pm
dom wrote:The latest version requires the rpi-update firmware.
apt-get upgrade now has latest firmware on, so rpi-update isn't necessary.
