Help - Can't Locate External HDD
Posted: Sun Feb 03, 2013 12:54 am
by heisenberg99
I've set my Pi up with a powered USB Hub, it seems to locate the hub but I cant find the HDD when I plug it into the hub: (this is the log without the HDD plugged in, when I then plug it in, I get the same result). Its as if its not recognising it.
tail -f /var/log/messages
Feb 3 00:55:34 raspberrypi kernel: [ 11.761054] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Feb 3 00:55:34 raspberrypi kernel: [ 12.088083] ### snd_bcm2835_alsa_probe c05c88e0 ############### PROBING FOR bcm2835 ALSA device (0):(1) ###############
Feb 3 00:55:34 raspberrypi kernel: [ 12.104034] Creating card...
Feb 3 00:55:34 raspberrypi kernel: [ 12.109626] Creating device/chip ..
Feb 3 00:55:34 raspberrypi kernel: [ 12.116109] Adding controls ..
Feb 3 00:55:34 raspberrypi kernel: [ 12.121547] Registering card ....
Feb 3 00:55:34 raspberrypi kernel: [ 12.133085] bcm2835 ALSA CARD CREATED!
Feb 3 00:55:34 raspberrypi kernel: [ 12.148374] ### BCM2835 ALSA driver init OK ###
Feb 3 00:55:34 raspberrypi kernel: [ 19.557938] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
Feb 3 00:55:36 raspberrypi kernel: [ 22.899003] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SS
Re: Help - Can't Locate External HDD
Posted: Sun Feb 03, 2013 3:09 am
by tonyhughes
What format is the partition on the hard drive?
Does it need to be something recognised by your OS to appear? I.e if it is formatted NTFS that could be why its not showing up?
Posted: Sun Feb 03, 2013 1:32 pm
by heisenberg99
I just bought a western digital external hard drive and plugged it in, did I need to do something to the drive pre-plug in?
Posted: Sun Feb 03, 2013 1:58 pm
by drgeoff
Without the HDD plugged in, boot the RPi and USB hub to a command prompt. Plug in the HDD. Issue the command 'dmesg' and report here the last 10 lines or so.
Also report here what is returned by the command 'lsusb'.
Posted: Sun Feb 03, 2013 2:48 pm
by heisenberg99
Basically the last 10 lines are exactly what I posted above. Creating card, device chip, etc....
Lsusb result :
Bus 001 device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 device 002: ID 0424:9512 Standard Microsystems Corp
Bus 001 device 003: ID 0424:ec00 Standard Microsystems Corp
Bus 001 device 004: ID 1997:1221
Bus 001 device 002: ID 1a40:0101 Terminus Technology Inc 4 port hub
Posted: Sun Feb 03, 2013 3:33 pm
by ski522
How many amps is the power supply to your hub? It's possible the drive isn't getting enough power to cycle up correctly.
Posted: Sun Feb 03, 2013 5:08 pm
by heisenberg99
How do I find that out?
Posted: Sun Feb 03, 2013 6:47 pm
by drgeoff
Can you verify that the same HDD plus same powered hub plus another computer (non-RPi) combination works?
Posted: Sun Feb 03, 2013 7:50 pm
by heisenberg99
Okay so I tried the same combo but replaced the Pi with my laptop. Confirmation that the MY PASSPORT shows up immediately once plugged into the hub and I can browse the content.
Posted: Mon Feb 04, 2013 11:35 pm
by Yamahanytro
I formatted my external drive to FAT32 for it to show up. I'm not sure what the default would be for that drive. Try formatting it?
