daBee
RP4 WiFi Realtek Dongle Installation
Thu Apr 08, 2021 6:18 pm
For some reason I can't get an external WiFi dongle to be recognized. I can only see the onboard wifi solution
$ iw dev
phy#0
	Interface wlan0
		ifindex 3
		wdev 0x1
		addr dc:a6:32:68:fa:f1
		type managed
		channel 34 (5170 MHz), width: 20 MHz, center1: 5170 MHz
$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 0bda:c811 Realtek Semiconductor Corp.			## this is the WiFi dongle
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
I've installed firmware-realtek but that hasn't changed anything.
Found a driver, tried to install it, changed the Makefile for ARM install, but errors:
 git clone https://github.com/brektrou/rtl8821CU.git
cd rtl8821CU
chmod +x dkms-install.sh
sudo ./dkms-install.sh
Result:
out to run dkms install steps...
Error! DKMS tree already contains: rtl8821CU-5.4.1
You cannot add the same module/version combo more than once.
Kernel preparation unnecessary for this kernel.  Skipping...
Building module:
cleaning build area...
'make' KVER=5.10.17-v7l+.....(bad exit status: 2)
Error! Bad return status for module build on kernel: 5.10.17-v7l+ (armv7l)
Consult /var/lib/dkms/rtl8821CU/5.4.1/build/make.log for more information.
Building module:
Finished running dkms install steps.
$ cat /var/lib/dkms/rtl8821CU/5.4.1/build/make.log
DKMS make.log for rtl8821CU-5.4.1 for kernel 5.10.17-v7l+ (armv7l)
Thu 08 Apr 2021 02:14:32 PM EDT
make ARCH=armv7l CROSS_COMPILE= -C /lib/modules/5.10.17-v7l+/build M=/var/lib/dkms/rtl8821CU/5.4.1/build  modules
make[1]: Entering directory '/usr/src/linux-headers-5.10.17-v7l+'
Makefile:681: arch/armv7l/Makefile: No such file or directory
make[1]: *** No rule to make target 'arch/armv7l/Makefile'.  Stop.
make[1]: Leaving directory '/usr/src/linux-headers-5.10.17-v7l+'
make: *** [Makefile:2212: modules] Error 2
So can't get past the make. Not sure what to do at this point.
Anybody have any insight? I appreciate any notes.
Cheers
Re: RP4 WiFi Realtek Dongle Installation
Thu Apr 08, 2021 6:50 pm
Removed see next response....
Last edited by fruitoftheloom on Thu Apr 08, 2021 7:49 pm, edited 1 time in total.
My other Linux machines: ChromeBox
https://www.aliexpress.com/item/32966393971.html
& Stone Desktop Intel CoreDuo circa 2010
MrEngman
Thu Apr 08, 2021 7:33 pm
I compile several different out of tree wifi drivers and I am using one of those wifi modules on a Pi4B 8Gb using the 8821cu driver.
I have the drivers available on my web site http://downloads.fars-robotics.net/wifi-drivers and have a script that can download and install the wifi drivers. You can install the script and download and install the driver using commands
sudo wget http://downloads.fars-robotics.net/wifi-drivers/install-wifi -O /usr/bin/install-wifi
sudo chmod +x /usr/bin/install-wifi
sudo install-wifi
Details on using the script can be seen using command
sudo install-wifi -h
MrEngman
daBee
Thu Apr 08, 2021 9:54 pm
Now I'm confused. Same person posting? I followed the first instructions and it installed. Nothing came out of it though.
Ah I see what you have done. A master install. This is much better. Might want to include a suggestion for a
sudo reboot
OK, things look ok, but I was hoping for this unit to be able to monitor:
$ rfkill list
0: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: no
1: phy1: Wireless LAN
	Soft blocked: no
	Hard blocked: no
2: hci0: Bluetooth
	Soft blocked: no
	Hard blocked: no
$ iw dev
phy#1
	Interface wlx1cbfcee6a146						# dongle
		ifindex 4
		wdev 0x100000001
		addr 1c:bf:ce:e6:a1:46
		type managed
		txpower 12.00 dBm
phy#0
	Interface wlan0
		ifindex 3
		wdev 0x1
		type managed
kismet needs a monitor device. Is this possible?
daBee
Fri Apr 09, 2021 3:11 pm
Apparently monitor mode is disabled by default in Makefile. It seems you've compiled your own, so this needs to be redone.
## get driver
mkdir -p ~/build
cd ~/build
## set monitor
sudo ip link set wlx1cbfcee6a146 down
sudo iw wlx1cbfcee6a146 set monitor none
sudo ip link set wlx1cbfcee6a146 up
$ iw dev
phy#1
		ifindex 4
		wdev 0x100000001
		type monitor
		txpower 12.00 dBm
phy#0
	Interface wlan0
		ifindex 3
		wdev 0x1
		type managed
MrEngman
Fri Apr 09, 2021 4:43 pm
In the source I have monitor mode is enabled by default.
In the Makefile I have
CONFIG_BR_EXT = y
CONFIG_TDLS = n
CONFIG_WIFI_MONITOR = y
CONFIG_MCC_MODE = n
CONFIG_APPEND_VENDOR_IE_ENABLE = n
MrEngman
MrEngman
Fri Apr 09, 2021 5:03 pm
I don't know how monitor mode works but I appear to be able to enable it as follows without making any changes to the driver source.
Before setting monitor mode
pi@Pi-4B-8GB:~ $ iw dev
phy#1
        Interface wlan1
                ifindex 4
                wdev 0x100000001
                addr 00:e0:32:40:23:5e
                type managed
                txpower 12.00 dBm
phy#0
        Unnamed/non-netdev interface
                wdev 0x2
                addr de:a6:32:ae:8b:91
                type P2P-device
                txpower 31.00 dBm
        Interface wlan0
                ifindex 3
                wdev 0x1
                addr dc:a6:32:ae:8b:91
                ssid MYON3
                type managed
                channel 36 (5180 MHz), width: 40 MHz, center1: 5190 MHz
                txpower 31.00 dBm
and then setting monitor mode
pi@Pi-4B-8GB:~ $ sudo ip link set wlan1 down
pi@Pi-4B-8GB:~ $ sudo iw wlan1 set monitor none
pi@Pi-4B-8GB:~ $ sudo ip link set wlan1 up
phy#1
        Interface wlan1
                ifindex 4
                wdev 0x100000001
                type monitor
                txpower 12.00 dBm
phy#0
                wdev 0x2
                type P2P-device
                txpower 31.00 dBm
        Interface wlan0
                ifindex 3
                wdev 0x1
                ssid MYON3
                type managed
                txpower 31.00 dBm
pi@Pi-4B-8GB:~ $
Can you explain how I can check it is working?
MrEngman
daBee
Fri Apr 09, 2021 8:57 pm
Ya your type is still managed. Needs to be either monitor or promiscuous.
Mine was managed until those last 3 commands:
## set monitor
Strange interface name, as well.
Just so that you know, my unit won't respond on eth0 now. So I get to turn off the interface in /etc/network/interfaces and troubleshoot. Second time now, but first after setting to monitor. I'm troubleshooting on the allow-hotplug.
MrEngman
Sat Apr 10, 2021 9:10 am
Before setting monitor mode wlan1 on my Pi it shows managed, but after using commands
it shows wlan1 is set in monitor mode
iw dev
phy#1
        Interface wlan1
                ifindex 4
                wdev 0x100000001
                type monitor
                txpower 12.00 dBm
phy#0
                wdev 0x2
                type P2P-device
                txpower 31.00 dBm
        Interface wlan0
                ifindex 3
                wdev 0x1
                ssid MYON3
                type managed
                txpower 31.00 dBm
MrEngman
MrEngman
Sat Apr 10, 2021 9:28 am
The strange network interface names are predictable names using the MAC addresses of the wifi interfaces as the names.
You can change the names using command
sudo raspi-config
and then select option
6 Advanced names
, then select option
A4 Network Interface Names Enable/disable predictable network i/f names
and then select NO.
This should change names to wlan0/1.
MrEngman
daBee
Wed Apr 14, 2021 8:46 pm
OK, can't seem to get this to work:
$ iw dev
phy#1
	Interface wlan1
		ifindex 4
		wdev 0x100000001
		type managed
		txpower 12.00 dBm
phy#0
	Interface wlan0
		ifindex 3
		wdev 0x1
		type managed
$ sudo iwconfig wlan1 mode monitor
Error for wireless request "Set Mode" (8B06) :
    SET failed on device wlan1 ; Operation not permitted.
Entered this and rebooted, and the unit wouldn't start up:
allow-hotplug wlan1
 iface wlan1 inet manual
 pre-up iw phy phy0 interface add mon1 type monitor
 pre-up iw dev wlan1 del
 pre-up ifconfig mon1 up
At this point I don't know what to do. Seems like it's stuck.
MrEngman
Wed Apr 14, 2021 9:17 pm
To turn on monitor mode I use the commands
sudo ip link set wlan1 down   # turn off wlan1 wifi
sudo iw wlan1 set monitor none   # set monitor mode
sudo ip link set wlan1 up   # turn on wlan1 wifi
as I show in my previous post. If I try and set monitor mode just using command
without first stopping wlan1 wifi I also get an error similar to the one you show in your previous post.
So it looks like you need to stop the wifi before setting monitor mode. I am not familiar with the commands you are using to set monitor mode.
MrEngman
daBee
Fri Apr 16, 2021 10:10 am
OK, this is what I have and it's hanging the startup, trying to launch a network interface. When commented out, it starts up fine:
allow-hotplug wlan1
 pre-up iw phy phy1 interface add mon1 type monitor
Been reading some confusing notes on this /etc/network/interfaces file. From some time back actually. viewtopic.php?t=251021
I need this to be active when I unplug the unit and plug it back in. I can't enter anything as the unit is headless. I'm rebooting and finding wlan1 moving back to managed:
 pre-up ifconfig wlan1 down
 pre-up ifconfig wlan1 up
 post-down ifconfig wlan1 down
MrEngman
Fri Apr 16, 2021 10:44 am
OK, i also see the wlan1 wifi is in managed mode when I reboot.
However I found a way to get it to boot with the wifi in monitor mode. I edited file /etc/rc.local and added to following lines to the end of the file before the line exit 0
Then when I reboot wlan1 wifi is in monitor mode.
MrEngman
daBee
Fri Apr 16, 2021 2:26 pm
Excellent. Looks like it's working. /etc/network/interfaces:
/etc/rc.local:
$ iw dev
phy#1
	Interface wlan1
		ifindex 4
		wdev 0x100000001
		type monitor
		txpower 12.00 dBm
phy#0
	Interface wlan0
		ifindex 3
		wdev 0x1
		type managed
daBee
Sat Apr 17, 2021 5:10 am
OK, got things semi-working. The GPS unit, using gpsmon through gpsd, is getting signal, but has no Az or El.:
Screen Shot 2021-04-17 at 1.05.16 AM.png (28.21 KiB) Viewed 385 times
Screen Shot 2021-04-17 at 1.05.08 AM.png (44.08 KiB) Viewed 385 times
daBee
Sun Apr 18, 2021 5:09 pm
Fixed with a GPS configuration and moving closer to the window...not sure what did it.
MrEngman
Sun Apr 18, 2021 6:09 pm
OK, makes sense. I remember seeing various posts that recommend using a Pi with GPS outdoors because of GPS signal loss if used indoors.
MrEngman
daBee
Mon Apr 19, 2021 12:58 am
Thing is, I use a GPS indoors for the past 10 years or more. I also changed something by asking it not to return confusing messages. But all of a sudden all data appeared. Heh.
daBee
Wed Apr 28, 2021 6:05 pm
OK, more problems.
First, eth0 stopped working. I was told that /etc/network/interfaces should be replaced with /etc/dhcpcd.conf should be used. So I shoved the interface directives over there and she worked fine.
Now I am starting kismet and I'm getting no recognition from the WiFi dongle monitor. Should I put the wlan1 directives in that same file?
I just got it going with your last directives:
Let's see if she sticks.
Update: wlan1 goes back to managed instead of monitor. I looked at /etc/rc.local and it had the proper entry:
## wlan1 stuff for monitoring
Not sure why it's not sticking. Any idea?
$ iw dev
phy#1
	Interface wlan1
		ifindex 4
		wdev 0x100000001
		type managed
		txpower 12.00 dBm
phy#0
		wdev 0x2
		addr de:a6:32:68:fa:f1
		type P2P-device
		txpower 31.00 dBm
	Interface wlan0
		ifindex 3
		wdev 0x1
		type managed
		txpower 31.00 dBm
daBee
Fri Apr 30, 2021 3:51 pm
Ya it's not working anymore. /etc/network/interfaces was replaced with /etc/dhcpcd.conf as per previous post: 16 Apr 2021, 10:26
On reboot:
$ iw dev
phy#1
	Interface wlan1
		ifindex 4
		wdev 0x100000001
		type managed
		txpower 12.00 dBm
phy#0
		wdev 0x2
		type P2P-device
		txpower 31.00 dBm
	Interface wlan0
		ifindex 3
		wdev 0x1
		type managed
		txpower 31.00 dBm
Not sure why it switched back to managed. Any idea why it has done that?
Update: This is the proper entry. if and iw are similar but not functionally the same:
sudo iw dev wlan1 set type monitor
