effemmeffe
My raspberry hangs too often to be usable
Tue Jan 22, 2013 10:32 am
I'm using the Xbian distro on my Raspberry.
XBMC plays 1080p movies without any problem, but often the Raspberry hangs at the end of the movie.
I control XBMC via Yatse on my Android phone using wifi connection.
When it freeze I try to connect via ssh and nothing happen. The only way to recover is to abruptly remove power. Yesterday night I tryied to let it rest for all the night and this morning it was still freezed.
I measured the voltage on TP1 and TP2 and it's oscillating between 4.80 and 4.90 volts.
The movies are on an external powered HD, the fixed network is disconnected and the wifi is provided by a zd1211rw compatible dongle.
What can I check to solve the problem?
Re: My raspberry hangs too often to be usable
Tue Jan 22, 2013 10:43 am
Have you tried with a fixed network? Or with the WiFi disconnected?
effemmeffe
Tue Jan 22, 2013 10:52 am
I don't have fixed network near my TV screen and if I disconnect the wifi how do I control XBMC?
MAA1612
Tue Jan 22, 2013 12:00 pm
effemmeffe wrote:if I disconnect the wifi how do I control XBMC?
If your TV supports CEC, you should be able to control XBMC via your TV remote control. Doesn't that work?
effemmeffe
Tue Jan 22, 2013 12:30 pm
My TV is a Samsung LED series 5, but I don't know what CEC is. I'll search on the forum.
Tue Jan 22, 2013 12:53 pm
effemmeffe wrote:I don't have fixed network near my TV screen and if I disconnect the wifi how do I control XBMC?
Well, we are trying to diagnose the problem, which may require trying out stuff outside the normal. Can you move the Raspi closer to your hub for testing purposes?
obcd
Tue Jan 22, 2013 12:55 pm
CEC is a protocol on the hdmi standard. It makes it possible to control some devices with the remote from others. Your Samsung should have it, but maybe not on all it's hdmi connectors. I am also not sure if every hdmi cable has the wires connected that make CEC possible.
effemmeffe
Tue Jan 22, 2013 1:00 pm
Yes, I can. And I did it before to configure teh wifi dongle or some other stuff.
But then how do I know what XBMC is doing?
Anyway, once I have my RPi on the fixed network what test do you suggest?
effemmeffe
Tue Jan 22, 2013 1:05 pm
obcd wrote:CEC is a protocol on the hdmi standard. It makes it possible to control some devices with the remote from others. Your Samsung should have it, but maybe not on all it's hdmi connectors. I am also not sure if every hdmi cable has the wires connected that make CEC possible.
I did a quick search on the forum and find this amazing feature, thanks.
I'll try as soon as possible, hoping that my HDMI cable supports CEC. It's an AmazonBasics High-Speed cable, this is the cable on the Italian store: http://goo.gl/cRG56
I suppose it's this one on the UK store: http://goo.gl/7L8hx
Tue Jan 22, 2013 1:50 pm
Leaving it running for longer than the usual hang time - you can SSH in to it from another device to see if it's still working.
effemmeffe
Tue Jan 22, 2013 1:58 pm
jamesh wrote:
effemmeffe wrote: Anyway, once I have my RPi on the fixed network what test do you suggest?
I already tried that: if I leave the raspberry run without doing anything it runs for a long time with no problem. I had it running for a day and a night and connected via ssh I can check its status.
The hangs happens while running XBMC or transferring data via samba from my macbook to the external powered USB disk connected to the Raspberry while it's on the wireless network.
redhawk
Tue Jan 22, 2013 2:03 pm
Coming from experience I find XBMC does have a tendency to hang sometimes so I don't think this has anything to do with your Pi.
Many XBMC distros come with overclocking settings enabled you could try removing these values and see if it improves stability.
Richard S.
effemmeffe
Tue Jan 22, 2013 2:07 pm
redhawk wrote:Coming from experience I find XBMC does have a tendency to hang sometimes so I don't think this has anything to do with your Pi.
Richard S.
My Pi is not overclocked.
MAA1612
Tue Jan 22, 2013 8:39 pm
effemmeffe wrote:I did a quick search on the forum and find this amazing feature, thanks.
It worked out of the box with my Sony TV and the current raspbmc image. No need to configure anything. I am using the HDMI cable offered by RS components for use with the RPi.
effemmeffe
Tue Jan 22, 2013 8:46 pm
Can't figure out if my samsung supports cec or not. no sign of that on the specs on the website and on the net I found some specs indicating cec not supported and some indicating cec supported.
I have cec enabled on xbmc, but if I press the arrow on my samsung remote nothing happen on xbmc...
bspi
Tue Jan 22, 2013 10:26 pm
effemmeffe wrote:Can't figure out if my samsung supports cec or not. no sign of that on the specs on the website and on the net I found some specs indicating cec not supported and some indicating cec supported.
What distro are you using (Openelec, raspbmc..)?
If your HDTV was made in 2007 and onwards, it probably supports hdmi-cec. When your raspberry pi is powered on and connected through hdmi to your tv, press the "Source" key in your remote. Now you should be able to see all connected devices, including the pi.
RobHenry
Tue Jan 22, 2013 11:34 pm
CEC is called Anynet+ on my Samsung TV - does yours mention that?
effemmeffe
Wed Jan 23, 2013 7:56 am
bspi wrote: What distro are you using (Openelec, raspbmc..)?
I'm using xbian.
And I can see xbmc or the console con my tv via hdmi.
I just can't control it via CEC.
effemmeffe
Wed Jan 23, 2013 7:57 am
Yep, I saw on the web.
But I can't see any reference to Anynet+ on my remote.
Which Samsung do you have? How do you enable CEC on it?
RaTTuS
Contact: Twitter YouTube
Wed Jan 23, 2013 8:03 am
what model is you samsung?
Covfefe
RobHenry
Wed Jan 23, 2013 8:13 am
Don't know the model off the top of my head, but it's a few years old and should be a standard feature I would have thought. It can be activated by pressing the tools button and then selecting Anynet+ device list. Not sure if I had to activate it anywhere in the settings first I'm afraid.
Nr90
Wed Jan 23, 2013 10:30 am
CEC works out of the box with my samsung TV. No configuration necessary.
