No overclock option in raspi-config
Posted: Sat Jan 12, 2013 6:04 am
by Yamahanytro
When I go to raspi-config there is no overclock feature, or update. All I see is Info, Configure_keyboard, Change_Pass, Change_Locale, Change_Timezone, SSH, Boot_Behaviour.
Im not sure whats wrong. Its running off a 80GB external HDD, With Raspbian installed. 8GB PNY premium SD card.
Not sure how to replicate it? Just started it and there is options missing from the menu. It showed up on all the other SD cards I run. I haven't done anything different on how I installed it.
Re: No overclock option in raspi-config
Posted: Sat Jan 12, 2013 11:30 pm
by BrickTopUK
Hey man, If you are still having this issue, I found that I didn't have the correct repositories listed in my /etc/apt/sources.list file. I added this to the file and then it updated fine!
deb http://archive.raspbian.org/raspbian wheezy main contrib non-free
deb-src http://archive.raspbian.org/raspbian wheezy main contrib non-free
Hope it works!
Posted: Sat Jan 12, 2013 11:43 pm
by Yamahanytro
So where is the file in the site you gave?
Posted: Sun Jan 13, 2013 1:36 am
by drgeoff
Yamahanytro wrote:So where is the file in the site you gave?
You add the two lines:
to the file /etc/apt/sources.list on your RPi.
Posted: Sun Jan 13, 2013 1:50 am
by malakai
Where did the image come from was it pre-loaded?
Have you tried
sudo apt-get update && sudo apt-get upgrade
sudo apt-get install raspi-config libraspberrypi*
reboot and see what is there.
Posted: Sun Jan 13, 2013 1:52 am
by Yamahanytro
I added those then rebooted and ran
apt-get update && apt-get upgrade
This is what I got: http://gyazo.com/1ed70c6510a3726537758d22fccdb366
by Yamahanytro
malakai wrote:Where did the image come from was it pre-loaded?
Have you tried
I installed raspbian with BerryBoot
I will try
right now.
Edit: Just tried it. Said its the latest version.
Posted: Sun Jan 13, 2013 1:56 am
by malakai
Berryboot won't have an overclock setting in raspi-config. I forget how to do it would have to read up on it. It boots differently than the main OS by itself so there is a way just not in raspi-config
Posted: Sun Jan 13, 2013 2:02 am
by Yamahanytro
malakai wrote:Berryboot won't have an overclock setting in raspi-config. I forget how to do it would have to read up on it. It boots differently than the main OS by itself so there is a way just not in raspi-config
The other SD cards I have that I installed using BerryBoot had the Raspi-Config in them, with the overclock feature.
Posted: Sun Jan 13, 2013 2:11 am
by malakai
http://www.raspberrypi.org/phpBB3/viewt ... 59#p249559
Hi, I have installed raspbian and openelec with "berryboot-20121230" but when I type sudo rasp-config there's no option to overclock, raspi-update, etc...
Max the author wrote:
Firmware has to be updated through the Berryboot GUI, not using rpi-update.
If you know what you are doing, you can set overclock settings through the Berryboot GUI (advanced settings -> config.txt tab). I would not recommend anyone to overclock though.
No need to change memory split manually anymore, Long live CMA.
I would ping him in that thread or rename this if possible as it won't possibly hit his attention. But it looks like if it was there it isn't anymore.
Posted: Sun Jan 13, 2013 2:18 am
by Yamahanytro
Would this allow me to overclock without voiding my warranty?
Posted: Sun Jan 13, 2013 2:23 am
by malakai
That's a tough question the wiki on it is here:
http://elinux.org/RPiconfig#Overclocking
Posted: Sun Jan 13, 2013 2:33 am
by Yamahanytro
malakai wrote:That's a tough question the wiki on it is here:
I want to use the Raspi-config Overclocking so it does not void the warranty. But that option is not on the config! But if I use another one of my SD cards I have Rasbian installed on The options is there. Im trying to find out how to get that option back.
Posted: Fri Jan 25, 2013 5:05 am
by dgately
Try:
sudo apt-get -y remove raspi-config
sudo apt-get -y install raspi-config
Even when apt-get stated that I had the latest version of raspi-config, it was running an older version. The remove and install seems to correct the problem for me. I also used berryboot, so this should help you...
dgately
Posted: Thu Apr 04, 2013 12:17 pm
by netninja
dgately wrote:Try:
dgately
This worked for me... Using 03/2013 berryboot and 12/2012 raspbian distro. Thanks for the tip!
Posted: Wed Apr 24, 2013 12:46 pm
by strasharo
You'll have also to mount manually your boot partition in Berryboot prior using raspi-config, so it can write to /boot/config.txt
mount -t auto /dev/mmcblk0p1 /boot
