Ian3
USB Keyboard with Model A Raspi (solved)
Fri Jan 11, 2013 10:35 am
I'm trying to use my Model A Raspberry Pi but I can't log in using my USB keyboard, which is only a small one, which works fine with my Model B Raspberry Pi. I'm using the same Debian SD card in both Pis.
I do see a message during booting up saying 'Unable to enumerate USB device on port 1' whch I assume has something to do with the problem.
Any suggestions?
mahjongg
Re: USB Keyboard with Model A Raspi
Fri Jan 11, 2013 11:36 am
Model A? They are not out yet!
RaTTuS
Contact: Twitter YouTube
Fri Jan 11, 2013 11:47 am
post a picture of this model A
I take it you cannot ssh into it as it has no ethernet
Covfefe
Ian3
Fri Jan 11, 2013 12:10 pm
Here's how I got hold of a Model A Raspi: http://www.raspberrypi.org/archives/2828
and here's a picture:
The power supply I'm using has a DC output of 5V 1000mA +/- 5%
Wamwung
Fri Jan 11, 2013 12:44 pm
I'm having the same problem but my RP is model B.
I've already tried two different keyboards and the problem I've got the same message.
Did you solve the problem?
Ian3
Fri Jan 11, 2013 3:18 pm
PROBLEM SOLVED
It would seem that you can't simply take the SD used on a Raspberry Pi B Model and plug it into a Model A. The keyboard now works after creating a new image on a new SD card.
drgeoff
Fri Jan 11, 2013 4:00 pm
Ian3 wrote:PROBLEM SOLVED
Where did you get the new image file to write to the SD card?
RaTTuS
Fri Jan 11, 2013 4:05 pm
Awesome Ian...
was it just a later image with updated firmware or something else ?
Wamwung - post a new thread this is for a model A which there are only 20 ? in existence
Covfefe
Ian3
Fri Jan 11, 2013 4:16 pm
I used the latest Raspbian “wheezy” to create the new image for the Model A. The Debian image I was using with the Model B is quite old now.
RaTTuS
Fri Jan 11, 2013 4:24 pm
Ian3 wrote:I used the latest Raspbian “wheezy” to create the new image for the Model A. The Debian image I was using with the Model B is quite old now.
it was probably a firmware upgrade that did it then ;-p
Covfefe
