Hello M33P,
I've been running trials with several different configurations. I'm running Wheezy 2012-12-16 (3.6.11+ PREEMPT Tue Jan 1 16:33:22 GMT 2013) on a rev.2 board. Here are some logs from earlier trials - it's not running right now but I should have time tomorrow to run those commands you posted.
These are all from my first set of trials - a powered, Staples-brand (rebranded Belkin, I think) seven port hub with a Microsoft LifeCam Cinema and a D-Link DWA-160 A2 Wi-Fi adapter.
I'm using the software package 'motion' just to dump two frames per second to a CIFS mount (another RPi, actually), although I was seeing the same results when dumping to the SD card. The camera is capturing YUYV format at 960x544.
Over five separate trials with the same configuration the result was the same but the time to failure was anywhere between 60 and 747 seconds.
From syslog:
Jan 7 19:53:03 upfront kernel: [ 1190.687617] hub 1-0:1.0: port 1 disabled by hub (EMI?), re-enabling...
Jan 7 19:53:03 upfront kernel: [ 1190.687663] usb 1-1: USB disconnect, device number 2
Jan 7 19:53:03 upfront kernel: [ 1190.687679] usb 1-1.1: USB disconnect, device number 3
Jan 7 19:53:03 upfront kernel: [ 1190.688070] smsc95xx 1-1.1:1.0: eth0: unregister 'smsc95xx' usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet
Jan 7 19:53:03 upfront wpa_supplicant[1573]: wlan0: CTRL-EVENT-DISCONNECTED bssid=98:2c:be:fb:e0:79 reason=3
Jan 7 19:53:03 upfront kernel: [ 1190.699359] usb 1-1.2: USB disconnect, device number 4
Jan 7 19:53:03 upfront kernel: [ 1190.699389] usb 1-1.2.6: USB disconnect, device number 5
From messages:
Jan 7 19:53:03 upfront kernel: [ 1190.700117] wlan0: deauthenticating from 98:2c:be:fb:e0:79 by local choice (reason=3)
Jan 7 19:53:03 upfront kernel: [ 1190.710709] cfg80211: Calling CRDA to update world regulatory domain
Jan 7 19:53:03 upfront wpa_action: WPA_IFACE=wlan0 WPA_ACTION=DISCONNECTED
The kernel log and dmesg don't have anything that doesn't show up in syslog or messages.
In four out of the five trials, the Wi-Fi dongle was re-enumerated after the hiccup - only one time did it fail to come back up and had to be physically removed and reinserted, at which point it came back up and the corresponding light lit back up on the hub.
In all five trials, the camera was not re-enumerated after the hiccup, but would be found again if it was removed and reinserted, and the corresponding light came on then too.
I also found that if the RPi was just rebooted after the hiccup, it would still not find the camera again unless either power was removed from the RPi and hub or the camera was removed and reattached.
lsusb -v:
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0 Unused
bDeviceProtocol 2 TT per port
bMaxPacketSize0 64
idVendor 0x0424 Standard Microsystems Corp.
idProduct 0x9512
bcdDevice 2.00
iManufacturer 0
iProduct 0
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 41
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 2mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0 Unused
bInterfaceProtocol 1 Single TT
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0001 1x 1 bytes
bInterval 12
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 1
bNumEndpoints 1
bInterfaceProtocol 2 TT per port
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 3
wHubCharacteristic 0x000d
Per-port power switching
Compound device
Per-port overcurrent protection
TT think time 8 FS bits
bPwrOn2PwrGood 50 * 2 milli seconds
bHubContrCurrent 1 milli Ampere
DeviceRemovable 0x02
PortPwrCtrlMask 0xff
Hub Port Status:
Port 1: 0000.0503 highspeed power enable connect
Port 2: 0000.0503 highspeed power enable connect
Port 3: 0000.0100 power
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceProtocol 0 Full speed (or root) hub
bMaxPacketSize0 64
Device Status: 0x0001
Self Powered
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceProtocol 1 Single TT
bMaxPacketSize0 64
idVendor 0x1d6b Linux Foundation
idProduct 0x0002 2.0 root hub
bcdDevice 3.06
iManufacturer 3 Linux 3.6.11+ dwc_otg_hcd
iProduct 2 DWC OTG Controller
iSerial 1 bcm2708_usb
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 1
wHubCharacteristic 0x0008
Ganged power switching
bPwrOn2PwrGood 1 * 2 milli seconds
bHubContrCurrent 0 milli Ampere
DeviceRemovable 0x00
Hub Port Status:
Self Powered
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 255 Vendor Specific Class
bDeviceSubClass 0
bDeviceProtocol 1
bMaxPacketSize0 64
idProduct 0xec00
bcdDevice 2.00
iManufacturer 0
iProduct 0
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 39
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 2mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 3
bInterfaceClass 255 Vendor Specific Class
bInterfaceProtocol 255
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0010 1x 16 bytes
bInterval 4
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 1
bMaxPacketSize0 64
Self Powered
Bus 001 Device 004: ID 050d:0416 Belkin Components
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bMaxPacketSize0 64
idVendor 0x050d Belkin Components
idProduct 0x0416
bcdDevice 0.00
iManufacturer 0
iProduct 0
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 41
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 2mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 1
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 7
wHubCharacteristic 0x0000
Ganged overcurrent protection
Hub Port Status:
Port 1: 0000.0100 power
Port 2: 0000.0100 power
Port 4: 0000.0100 power
Port 5: 0000.0100 power
Port 6: 0000.0503 highspeed power enable connect
Port 7: 0000.0503 highspeed power enable connect
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceClass 9 Hub
bMaxPacketSize0 64
Self Powered
Bus 001 Device 005: ID 07d1:3a09 D-Link System DWA-160 802.11abgn Xtreme N Dual Band Adapter(rev.A2) [Atheros AR9170+AR9104]
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceSubClass 255 Vendor Specific Subclass
bDeviceProtocol 255 Vendor Specific Protocol
bMaxPacketSize0 64
idVendor 0x07d1 D-Link System
idProduct 0x3a09 DWA-160 802.11abgn Xtreme N Dual Band Adapter(rev.A2) [Atheros AR9170+AR9104]
bcdDevice 1.07
iManufacturer 16 ATHER
iProduct 32 11n adapter
iSerial 48 12345
bLength 9
bDescriptorType 2
wTotalLength 46
bNumInterfaces 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 4
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x04 EP 4 OUT
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 1
bLength 10
bDescriptorType 6
bcdUSB 2.00
bMaxPacketSize0 64
bNumConfigurations 0
Device Status: 0x0000
(Bus Powered)
Bus 001 Device 006: ID 045e:075d Microsoft Corp. LifeCam Cinema
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 239 Miscellaneous Device
bDeviceSubClass 2 ?
bDeviceProtocol 1 Interface Association
bMaxPacketSize0 64
idVendor 0x045e Microsoft Corp.
idProduct 0x075d LifeCam Cinema
bcdDevice 1.05
iManufacturer 1 Microsoft
iProduct 2 Microsoft® LifeCam Cinema(TM)
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 1429
bNumInterfaces 4
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionClass 14 Video
bFunctionSubClass 3 Video Interface Collection
bFunctionProtocol 0
iFunction 4 Microsoft® LifeCam Cinema(TM)
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 14 Video
bInterfaceSubClass 1 Video Control
iInterface 4 Microsoft® LifeCam Cinema(TM)
VideoControl Interface Descriptor:
bLength 13
bDescriptorType 36
bDescriptorSubtype 1 (HEADER)
bcdUVC 1.00
wTotalLength 85
dwClockFrequency 30.000000MHz
bInCollection 1
baInterfaceNr( 0) 1
bLength 18
bDescriptorType 36
bDescriptorSubtype 2 (INPUT_TERMINAL)
bTerminalID 1
wTerminalType 0x0201 Camera Sensor
bAssocTerminal 0
iTerminal 0
wObjectiveFocalLengthMin 0
wObjectiveFocalLengthMax 0
wOcularFocalLength 0
bControlSize 3
bmControls 0x00020a2a
Auto-Exposure Mode
Exposure Time (Absolute)
Focus (Absolute)
Zoom (Absolute)
PanTilt (Absolute)
Focus, Auto
bLength 9
bDescriptorType 36
bDescriptorSubtype 3 (OUTPUT_TERMINAL)
bTerminalID 2
wTerminalType 0x0101 USB Streaming
bAssocTerminal 0
bSourceID 5
iTerminal 0
bLength 7
bDescriptorType 36
bDescriptorSubtype 4 (SELECTOR_UNIT)
bUnitID 3
bNrInPins 1
baSource( 0) 1
iSelector 0
bLength 11
bDescriptorType 36
bDescriptorSubtype 5 (PROCESSING_UNIT)
Warning: Descriptor too short
bUnitID 4
bSourceID 3
wMaxMultiplier 0
bControlSize 2
bmControls 0x0000155b
Brightness
Contrast
Saturation
Sharpness
White Balance Temperature
Backlight Compensation
Power Line Frequency
White Balance Temperature, Auto
iProcessing 0
bmVideoStandards 0x1b
None
NTSC - 525/60
SECAM - 625/50
NTSC - 625/50
bLength 27
bDescriptorType 36
bDescriptorSubtype 6 (EXTENSION_UNIT)
bUnitID 5
guidExtensionCode {29a787c9-d359-6945-8467-ff0849fc19e8}
bNumControl 16
bNrPins 1
baSourceID( 0) 4
bControlSize 2
bmControls( 0) 0xff
bmControls( 1) 0xff
iExtension 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 8
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
bInterfaceSubClass 2 Video Streaming
iInterface 0
VideoStreaming Interface Descriptor:
bLength 15
bDescriptorType 36
bDescriptorSubtype 1 (INPUT_HEADER)
bNumFormats 2
wTotalLength 1075
bEndPointAddress 129
bmInfo 0
bTerminalLink 2
bStillCaptureMethod 1
bTriggerSupport 1
bTriggerUsage 0
bControlSize 1
bmaControls( 0) 27
bmaControls( 1) 27
bLength 27
bDescriptorType 36
bDescriptorSubtype 4 (FORMAT_UNCOMPRESSED)
bFormatIndex 1
bNumFrameDescriptors 12
guidFormat {59555932-0000-1000-8000-00aa00389b71}
bBitsPerPixel 16
bDefaultFrameIndex 1
bAspectRatioX 0
bAspectRatioY 0
bmInterlaceFlags 0x00
Interlaced stream or variable: No
Fields per frame: 2 fields
Field 1 first: No
Field pattern: Field 1 only
bCopyProtect 0
bLength 46
bDescriptorType 36
bDescriptorSubtype 5 (FRAME_UNCOMPRESSED)
bFrameIndex 1
bmCapabilities 0x01
Still image supported
wWidth 640
wHeight 480
dwMinBitRate 36864000
dwMaxBitRate 147456000
dwMaxVideoFrameBufferSize 614400
dwDefaultFrameInterval 333333
bFrameIntervalType 5
dwFrameInterval( 0) 333333
dwFrameInterval( 1) 500000
dwFrameInterval( 2) 666666
dwFrameInterval( 3) 1000000
dwFrameInterval( 4) 1333333
bLength 34
bDescriptorType 36
bFrameIndex 2
bmCapabilities 0x01
wWidth 1280
wHeight 720
dwMinBitRate 110592000
dwMaxVideoFrameBufferSize 1843200
dwDefaultFrameInterval 1000000
bFrameIntervalType 2
dwFrameInterval( 0) 1000000
dwFrameInterval( 1) 1333333
bLength 38
bDescriptorType 36
bFrameIndex 3
bmCapabilities 0x01
wWidth 960
wHeight 544
dwMinBitRate 62668800
dwMaxBitRate 125337600
dwMaxVideoFrameBufferSize 1044480
dwDefaultFrameInterval 666666
bFrameIntervalType 3
dwFrameInterval( 0) 666666
dwFrameInterval( 1) 1000000
dwFrameInterval( 2) 1333333
bLength 42
bDescriptorType 36
bFrameIndex 4
bmCapabilities 0x01
wWidth 800
wHeight 448
dwMinBitRate 43008000
dwMaxBitRate 114688000
dwMaxVideoFrameBufferSize 716800
dwDefaultFrameInterval 500000
bFrameIntervalType 4
dwFrameInterval( 0) 500000
dwFrameInterval( 1) 666666
dwFrameInterval( 2) 1000000
dwFrameInterval( 3) 1333333
bLength 46
bDescriptorType 36
bFrameIndex 5
bmCapabilities 0x01
wWidth 640
wHeight 360
dwMinBitRate 27648000
dwMaxBitRate 110592000
dwMaxVideoFrameBufferSize 460800
bLength 46
bDescriptorType 36
bFrameIndex 6
bmCapabilities 0x01
wWidth 424
wHeight 240
dwMinBitRate 12211200
dwMaxBitRate 48844800
dwMaxVideoFrameBufferSize 203520
bLength 46
bDescriptorType 36
bFrameIndex 7
bmCapabilities 0x01
wWidth 352
wHeight 288
dwMinBitRate 12165120
dwMaxBitRate 48660480
dwMaxVideoFrameBufferSize 202752
bLength 46
bDescriptorType 36
bFrameIndex 8
bmCapabilities 0x01
wWidth 320
wHeight 240
dwMinBitRate 9216000
dwMaxBitRate 36864000
dwMaxVideoFrameBufferSize 153600
bLength 38
bDescriptorType 36
bFrameIndex 9
bmCapabilities 0x01
wWidth 800
wHeight 600
dwMinBitRate 57600000
dwMaxBitRate 115200000
dwMaxVideoFrameBufferSize 960000
bLength 46
bDescriptorType 36
bFrameIndex 10
bmCapabilities 0x01
wWidth 176
wHeight 144
dwMinBitRate 3041280
dwMaxBitRate 12165120
dwMaxVideoFrameBufferSize 50688
bLength 46
bDescriptorType 36
bFrameIndex 11
bmCapabilities 0x01
wWidth 160
wHeight 120
dwMinBitRate 2304000
dwMaxBitRate 9216000
dwMaxVideoFrameBufferSize 38400
bLength 30
bDescriptorType 36
bFrameIndex 12
bmCapabilities 0x01
wWidth 1280
wHeight 800
dwMinBitRate 163840000
dwMaxBitRate 163840000
dwMaxVideoFrameBufferSize 2048000
bFrameIntervalType 1
bLength 6
bDescriptorType 36
bDescriptorSubtype 13 (COLORFORMAT)
bColorPrimaries 1 (BT.709,sRGB)
bTransferCharacteristics 1 (BT.709)
bMatrixCoefficients 4 (SMPTE 170M (BT.601))
bLength 11
bDescriptorType 36
bDescriptorSubtype 6 (FORMAT_MJPEG)
bFormatIndex 2
bNumFrameDescriptors 11
bFlags 0
Fixed-size samples: No
bAspectRatioX 0
bAspectRatioY 0
Fields per frame: 1 fields
Field 1 first: No
bCopyProtect 0
bLength 46
bDescriptorType 36
bDescriptorSubtype 7 (FRAME_MJPEG)
bFrameIndex 1
bmCapabilities 0x01
wWidth 640
wHeight 480
bLength 46
bDescriptorType 36
bFrameIndex 2
bmCapabilities 0x01
wWidth 1280
wHeight 720
dwMaxBitRate 442368000
bLength 46
bDescriptorType 36
bFrameIndex 3
bmCapabilities 0x01
wWidth 960
wHeight 544
dwMaxBitRate 250675200
bLength 46
bDescriptorType 36
bFrameIndex 4
bmCapabilities 0x01
wWidth 800
wHeight 448
dwMaxBitRate 172032000
bLength 46
bDescriptorType 36
bFrameIndex 5
bmCapabilities 0x01
wWidth 640
wHeight 360
bLength 46
bDescriptorType 36
bFrameIndex 6
bmCapabilities 0x01
wWidth 800
wHeight 600
dwMaxBitRate 230400000
bLength 46
bDescriptorType 36
bFrameIndex 7
bmCapabilities 0x01
wWidth 416
wHeight 240
dwMinBitRate 11980800
dwMaxBitRate 47923200
dwMaxVideoFrameBufferSize 199680
bLength 46
bDescriptorType 36
bFrameIndex 8
bmCapabilities 0x01
wWidth 352
wHeight 288
bLength 46
bDescriptorType 36
bFrameIndex 9
bmCapabilities 0x01
wWidth 176
wHeight 144
bLength 46
bDescriptorType 36
bFrameIndex 10
bmCapabilities 0x01
wWidth 320
wHeight 240
bLength 46
bDescriptorType 36
bFrameIndex 11
bmCapabilities 0x01
wWidth 160
wHeight 120
bLength 6
bDescriptorType 36
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Transfer Type Isochronous
Synch Type Asynchronous
Usage Type Data
wMaxPacketSize 0x0080 1x 128 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0100 1x 256 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 3
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 4
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0400 1x 1024 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 5
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0c00 2x 1024 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 6
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x1400 3x 1024 bytes
bInterval 1
bLength 8
bDescriptorType 11
bFirstInterface 2
bInterfaceCount 2
bFunctionClass 1 Audio
bFunctionSubClass 2 Streaming
bFunctionProtocol 0
iFunction 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 1 Audio
bInterfaceSubClass 1 Control Device
iInterface 0
AudioControl Interface Descriptor:
bLength 9
bDescriptorType 36
bcdADC 1.00
wTotalLength 39
bInCollection 1
baInterfaceNr( 0) 3
bLength 12
bDescriptorType 36
bTerminalID 1
wTerminalType 0x0202 Desktop Microphone
bAssocTerminal 0
bNrChannels 1
wChannelConfig 0x0000
iChannelNames 0
iTerminal 0
bLength 9
bDescriptorType 36
bDescriptorSubtype 6 (FEATURE_UNIT)
bUnitID 5
bSourceID 1
bControlSize 1
bmaControls( 0) 0x01
Mute Control
bmaControls( 1) 0x02
Volume Control
iFeature 0
bLength 9
bDescriptorType 36
bTerminalID 3
bAssocTerminal 1
bSourceID 5
iTerminal 0
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 0
bInterfaceSubClass 2 Streaming
iInterface 0
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 1
bNumEndpoints 1
iInterface 0
AudioStreaming Interface Descriptor:
bLength 7
bDescriptorType 36
bDescriptorSubtype 1 (AS_GENERAL)
bTerminalLink 3
bDelay 1 frames
wFormatTag 1 PCM
bLength 29
bDescriptorType 36
bDescriptorSubtype 2 (FORMAT_TYPE)
bFormatType 1 (FORMAT_TYPE_I)
bNrChannels 1
bSubframeSize 2
bBitResolution 16
bSamFreqType 7 Discrete
tSamFreq[ 0] 8000
tSamFreq[ 1] 16000
tSamFreq[ 2] 22050
tSamFreq[ 3] 24000
tSamFreq[ 4] 32000
tSamFreq[ 5] 44100
tSamFreq[ 6] 48000
bLength 9
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 4
bRefresh 0
bSynchAddress 0
AudioControl Endpoint Descriptor:
bLength 7
bDescriptorType 37
bDescriptorSubtype 1 (EP_GENERAL)
bmAttributes 0x01
Sampling Frequency
bLockDelayUnits 0 Undefined
wLockDelay 0 Undefined
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 2 ?
bMaxPacketSize0 64
(Bus Powered)
I hope this helps, let me know if there's anything you'd like me to try.
