Dominique GEORGES
Noisy Raspberry (19300 Hz sound emission)
Mon Nov 16, 2020 6:48 pm
I have 2 Raspberry 4, using passive thermal protection.
I had headache and did not understood why.
Using a decibel meter with frequency monitoring, I discovered that both of them where generating high frequency sound (noise) signal (between 19.200 and 19.350 hz).
I taught the first one was dying, I booted the second one and .. same issue.
At boot time, signal is there +/- 40 db, which is not low.
Powering it off stops immediately the generated signal/sound.
Is that a "normal" behaviour ?
Thanks i advance.
Kr,
Dom
ejolson
Re: Noisy Raspberry (19300 Hz sound emission)
Tue Nov 17, 2020 12:57 am
Thanks i advance.
Kr,
Dom
Thanks for posting. This seems like it could be a problem, not only for people with good hearing but for various pets that might be in the house. I wonder if the Pi 400 is also affected.
Dominique GEORGES
Tue Nov 17, 2020 9:41 am
I tried without any passive thermal protection (during a few seconds ;) )
Just powering it generates immediately sound signal : 19.230 -> 19.340 Hz
What strange is, my third Raspberry 4 is not suffering of that issue.
I presume the signal frequency may help expert to pointout the source.
It starts directly at power ON.
Fortunately, I just have a cat an no dog.
But I presume my cat is also suffering from that issue.
Please help my .. cat :)
PS : These Raspberry are running HomeAssistant, and have issue
PS : All 3 are Raspberry Pi 4B 4GB
Kind regards,
Dom
jdb
Tue Nov 17, 2020 12:56 pm
Are you using the same power supply between the noisy boards and the "quiet" board?
Rockets are loud.
https://astro-pi.org
LTolledo
Tue Nov 17, 2020 1:02 pm
can you share an image of the display of that "decibel meter with frequency monitoring" showing the "suspected value"
is the data display plotted against time?
Some people be like:
Dominique GEORGES
Tue Nov 17, 2020 2:28 pm
Yes, indeed.
And, using another powersupply modifies the signal strength, and witdth !
Thus powersupply is part of the root cause.
High frequencies 19.300 Hz
Rapberry PI-B 4G - Hautes fréquences-min.jpg (194.09 KiB) Viewed 112 times
Kr,
Dom
