Rcayot
help with disappearing serial port
Sun Oct 25, 2020 12:38 am
Every once in a while, my Raspberry Pi 4B when running Arduino IDE will lose the port the board is connected to. I usually reboot and the correct serial port appears in the Arduino IDE.
for example, the board is always attached to the /dev/ttyACM1. When I get into trouble the IDE does not 'see' any port but the /dev/ttyACM0 port.
How can I check the status of the serial ports? Can I reset them from the shell?
Any help would be appreciated. A link to a good serial (really usb) Debian resource for basic troubleshooting would be helpful as well.
Roger
Re: help with disappearing serial port
Sun Oct 25, 2020 12:47 am
They're assigned when the kernel detects the device. The only way to change a device is to disconnect (so the kernel forgets it) and re-attach it. Or if the device isn't powered from the USB connection to power cycle it.
There are no controls for this that you can use to get the kernel to forget a device unless you can for the kernel to unload the active device driver (with sudo rmmod ...; sudo modprobe ...).
cleverca22
Sun Oct 25, 2020 12:49 am
udevadm info -a -p /sys/class/tty/ttyUSB0 | less
if you run this on a given serial port, you can see exactly which device it is, and what driver is powering it
in my case:
    ATTRS{interface}=="FT232R USB UART"
Rcayot
Sun Oct 25, 2020 12:15 pm
I ran the command:
udevadm info -a -p /sys/class/tty/ttyACM1 | less
and it said no such device,
I ran:
udevadm info -a -p /sys/class/tty/ttyACM0 | less
and it gave me a long report. Why has ACM1 disappeared? This was run after a fresh reboot.
Roger
cleverca22
Sun Oct 25, 2020 6:36 pm
linux assigns ports starting at number 0
if 0 is still in-use when you plug the device in, then it becomes 1 instead
