rustyshamrock
New Rpi 4 ethernet port not working
Tue Oct 20, 2020 8:31 pm
This Rpi-4 was purchased on order: 2381375-6818470952
From day one there has been a problem with the ethernet port. I've tried different cables, switch ports, etc. without luck.
ifconfig says the port is up, but no ip address.
Running 2020-08-20-raspios-buster-armhf-full.img with everything updated (sudo apt update; sudo apt full-upgrade)
pi@raspberrypi:~ $ ifconfig
eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether dc:a6:32:cd:ed:6c  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 2695  bytes 419578 (409.7 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 21  bytes 1160 (1.1 KiB)
        TX packets 21  bytes 1160 (1.1 KiB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.2.176  netmask 255.255.255.0  broadcast 192.168.2.255
        inet6 fe80::2b19:e209:89e3:3fa  prefixlen 64  scopeid 0x20<link>
        ether dc:a6:32:cd:ed:6e  txqueuelen 1000  (Ethernet)
        RX packets 14312  bytes 1745651 (1.6 MiB)
        TX packets 9216  bytes 1601050 (1.5 MiB)
dmesg shows and a couple of issues at boot time, then shows eth0 bouncing up and down every few seconds.
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.4.51-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1333 SMP Mon Aug 10 16:51:40 BST 2020
[    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] On node 0 totalpages: 504832
[    0.000000]   DMA zone: 2304 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 196608 pages, LIFO batch:63
[    0.000000]   HighMem zone: 308224 pages, LIFO batch:63
[    0.000000] percpu: Embedded 20 pages/cpu s49856 r8192 d23872 u81920
[    0.000000] pcpu-alloc: s49856 r8192 d23872 u81920 alloc=20*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 502528
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:CD:ED:6C vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=30c0f189-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x19400000-0x1d400000] (64MB)
[    0.000000] Memory: 1647812K/2019328K available (10240K kernel code, 725K rwdata, 2740K rodata, 2048K init, 853K bss, 109372K reserved, 262144K cma-reserved, 1232896K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 30051 entries in 59 pages
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] random: get_random_bytes called from start_kernel+0x340/0x518 with crng_init=0
[    0.000009] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[    0.000025] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    0.000105] bcm2835: system timer (irq = 17)
[    0.000779] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[    0.000795] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[    0.000812] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[    0.000825] Switching to timer-based delay loop, resolution 18ns
[    0.001072] Console: colour dummy device 80x30
[    0.001104] printk: console [tty1] enabled
[    0.001155] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[    0.001175] pid_max: default: 32768 minimum: 301
[    0.001493] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.001515] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.002722] Disabling memory control group subsystem
[    0.002828] CPU: Testing write buffer coherency: ok
[    0.003327] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.004173] Setting up static identity map for 0x200000 - 0x20003c
[    0.004368] rcu: Hierarchical SRCU implementation.
[    0.005005] smp: Bringing up secondary CPUs ...
[    0.006211] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.007526] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.008784] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.008930] smp: Brought up 1 node, 4 CPUs
[    0.008946] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[    0.008959] CPU: All CPU(s) started in HYP mode.
[    0.008970] CPU: Virtualization extensions available.
[    0.009780] devtmpfs: initialized
[    0.023137] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[    0.023392] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.023419] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.031423] pinctrl core: initialized pinctrl subsystem
[    0.032508] NET: Registered protocol family 16
[    0.036320] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.038074] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.038087] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.038439] Serial: AMBA PL011 UART driver
[    0.041862] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[    0.060905] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-09-02 21:13, variant start
[    0.070887] raspberrypi-firmware soc:firmware: Firmware hash is 4439d2aaa6c376a2d1ef4402f142e1cf4de37c43
[    0.123998] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[    0.128477] vgaarb: loaded
[    0.128952] SCSI subsystem initialized
[    0.129183] usbcore: registered new interface driver usbfs
[    0.129266] usbcore: registered new interface driver hub
[    0.129384] usbcore: registered new device driver usb
[    0.131037] clocksource: Switched to clocksource arch_sys_counter
[    0.883867] VFS: Disk quotas dquot_6.6.0
[    0.883969] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.884149] FS-Cache: Loaded
[    0.884352] CacheFiles: Loaded
[    0.885279] simple-framebuffer 3e3cf000.framebuffer: framebuffer at 0x3e3cf000, 0x7f8000 bytes, mapped to 0x(ptrval)
[    0.885297] simple-framebuffer 3e3cf000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[    0.885810] Console: switching to colour frame buffer device 240x67
[    0.896531] simple-framebuffer 3e3cf000.framebuffer: fb0: simplefb registered!
[    0.906490] thermal_sys: Registered thermal governor 'step_wise'
[    0.906874] NET: Registered protocol family 2
[    0.907614] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.907646] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.907721] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.907797] TCP: Hash tables configured (established 8192 bind 8192)
[    0.907947] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.907981] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.908229] NET: Registered protocol family 1
[    0.908956] RPC: Registered named UNIX socket transport module.
[    0.908968] RPC: Registered udp transport module.
[    0.908979] RPC: Registered tcp transport module.
[    0.908991] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.909012] PCI: CLS 0 bytes, default 64
[    0.910884] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[    0.913106] Initialise system trusted keyrings
[    0.913333] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[    0.924182] FS-Cache: Netfs 'nfs' registered for caching
[    0.924890] NFS: Registering the id_resolver key type
[    0.924920] Key type id_resolver registered
[    0.924933] Key type id_legacy registered
[    0.924956] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.926041] Key type asymmetric registered
[    0.926057] Asymmetric key parser 'x509' registered
[    0.926222] bounce: pool size: 64 pages
[    0.926269] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.926488] io scheduler mq-deadline registered
[    0.926501] io scheduler kyber registered
[    0.930296] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[    0.930322] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[    0.930386] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x0603ffffff -> 0x00f8000000
[    0.930449] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x007fffffff -> 0x0000000000
[    0.983188] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
[    0.983502] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[    0.983520] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.983539] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[    0.983596] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[    0.983838] pci 0000:00:00.0: PME# supported from D0 D3hot
[    0.987186] PCI: bus0: Fast back to back transfers disabled
[    0.987408] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[    0.987553] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    0.987971] pci 0000:01:00.0: PME# supported from D0 D3cold
[    0.991369] PCI: bus1: Fast back to back transfers disabled
[    0.991427] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[    0.991449] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[    0.991529] pci 0000:00:00.0: PCI bridge to [bus 01]
[    0.991552] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
[    0.991853] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[    0.992088] pcieport 0000:00:00.0: PME: Signaling with IRQ 55
[    0.992483] pcieport 0000:00:00.0: AER: enabled with IRQ 55
[    0.992798] pci 0000:01:00.0: enabling device (0140 -> 0142)
[    0.999487] iproc-rng200 fe104000.rng: hwrng registered
[    0.999797] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[    1.000430] vc-sm: Videocore shared memory driver
[    1.000963] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[    1.012948] brd: module loaded
[    1.025225] loop: module loaded
[    1.026612] Loading iSCSI transport class v2.0-870.
[    1.028550] libphy: Fixed MDIO Bus: probed
[    1.029122] bcmgenet fd580000.ethernet: failed to get enet clock
[    1.029141] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[    1.029163] bcmgenet fd580000.ethernet: failed to get enet-wol clock
[    1.029183] bcmgenet fd580000.ethernet: failed to get enet-eee clock
[    1.029209] bcmgenet: Skipping UMAC reset
[    1.041087] libphy: bcmgenet MII bus: probed
[    1.121150] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[    1.122192] usbcore: registered new interface driver r8152
[    1.122272] usbcore: registered new interface driver lan78xx
[    1.122340] usbcore: registered new interface driver smsc95xx
[    1.122763] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    1.122797] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[    1.125086] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[    1.126354] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    1.126370] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.126385] usb usb1: Product: xHCI Host Controller
[    1.126400] usb usb1: Manufacturer: Linux 5.4.51-v7l+ xhci-hcd
[    1.126414] usb usb1: SerialNumber: 0000:01:00.0
[    1.127000] hub 1-0:1.0: USB hub found
[    1.127091] hub 1-0:1.0: 1 port detected
[    1.127637] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    1.127663] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[    1.127685] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[    1.128191] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[    1.128208] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.128224] usb usb2: Product: xHCI Host Controller
[    1.128237] usb usb2: Manufacturer: Linux 5.4.51-v7l+ xhci-hcd
[    1.128251] usb usb2: SerialNumber: 0000:01:00.0
[    1.128808] hub 2-0:1.0: USB hub found
[    1.128900] hub 2-0:1.0: 4 ports detected
[    1.130350] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.130617] dwc_otg: FIQ enabled
[    1.130629] dwc_otg: NAK holdoff enabled
[    1.130640] dwc_otg: FIQ split-transaction FSM enabled
[    1.130654] Module dwc_common_port init
[    1.131135] usbcore: registered new interface driver uas
[    1.131237] usbcore: registered new interface driver usb-storage
[    1.131438] mousedev: PS/2 mouse device common for all mice
[    1.133504] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    1.136029] sdhci: Secure Digital Host Controller Interface driver
[    1.136040] sdhci: Copyright(c) Pierre Ossman
[    1.136605] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[    1.137124] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.140894] ledtrig-cpu: registered to indicate activity on CPUs
[    1.141258] hidraw: raw HID events driver (C) Jiri Kosina
[    1.141440] usbcore: registered new interface driver usbhid
[    1.141451] usbhid: USB HID core driver
[    1.142499] vchiq: vchiq_init_state: slot_zero = (ptrval)
[    1.144472] [vc_sm_connected_init]: start
[    1.154549] [vc_sm_connected_init]: end - returning 0
[    1.156620] Initializing XFRM netlink socket
[    1.156656] NET: Registered protocol family 17
[    1.156765] Key type dns_resolver registered
[    1.157226] Registering SWP/SWPB emulation handler
[    1.157578] registered taskstats version 1
[    1.157598] Loading compiled-in X.509 certificates
[    1.158108] Key type ._fscrypt registered
[    1.158121] Key type .fscrypt registered
[    1.168274] uart-pl011 fe201000.serial: cts_event_workaround enabled
[    1.168345] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2
[    1.174352] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    1.175284] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[    1.175299] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[    1.226723] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    1.228360] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.230057] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.233122] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    1.234776] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.241084] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[    1.243881] of_cfs_init
[    1.243999] of_cfs_init: OK
[    1.245022] Waiting for root device PARTUUID=30c0f189-02...
[    1.283958] random: fast init done
[    1.305121] mmc1: new high speed SDIO card at address 0001
[    1.352884] mmc0: new ultra high speed DDR50 SDXC card at address aaaa
[    1.353846] mmcblk0: mmc0:aaaa SR64G 59.5 GiB
[    1.356029]  mmcblk0: p1 p2
[    1.372913] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.372990] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.378139] devtmpfs: mounted
[    1.386175] Freeing unused kernel memory: 2048K
[    1.411342] Run /sbin/init as init process
[    1.491097] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[    1.674011] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[    1.674030] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.674045] usb 1-1: Product: USB2.0 Hub
[    1.676172] hub 1-1:1.0: USB hub found
[    1.676462] hub 1-1:1.0: 4 ports detected
[    1.815132] systemd[1]: System time before build time, advancing clock.
[    1.915875] NET: Registered protocol family 10
[    1.917244] Segment Routing with IPv6
[    1.951595] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    1.952371] systemd[1]: Detected architecture arm.
[    1.994124] systemd[1]: Set hostname to <raspberrypi>.
[    2.654789] random: systemd: uninitialized urandom read (16 bytes read)
[    2.665506] random: systemd: uninitialized urandom read (16 bytes read)
[    2.667768] systemd[1]: Created slice User and Session Slice.
[    2.668035] random: systemd: uninitialized urandom read (16 bytes read)
[    2.668105] systemd[1]: Reached target Slices.
[    2.668294] systemd[1]: Reached target Swap.
[    2.668921] systemd[1]: Listening on fsck to fsckd communication Socket.
[    2.669470] systemd[1]: Listening on udev Kernel Socket.
[    2.670145] systemd[1]: Listening on Journal Socket (/dev/log).
[    2.670536] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    2.772285] i2c /dev entries driver
[    3.336770] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    3.452366] systemd-journald[119]: Received request to flush runtime journal from PID 1
[    3.972055] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[    3.972545] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[    3.972982] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[    3.973403] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[    4.033863] mc: Linux media interface: v0.10
[    4.069787] videodev: Linux video capture interface: v2.00
[    4.082680] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[    4.105536] bcm2835_audio bcm2835_audio: card created with 4 channels
[    4.107966] bcm2835_audio bcm2835_audio: card created with 4 channels
[    4.111203] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    4.113937] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[    4.113975] [vc_sm_connected_init]: start
[    4.114195] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    4.115824] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    4.116477] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    4.118363] [vc_sm_connected_init]: installed successfully
[    4.123238] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    4.123650] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    4.123786] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    4.134546] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[    4.134989] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[    4.137175] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[    4.164876] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[    4.164942] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[    4.187953] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[    4.188001] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[    4.193839] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[    4.195375] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[    4.195453] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[    4.195459] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[    4.196173] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[    4.200918] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[    4.200948] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[    4.200970] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[    4.200990] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[    4.201009] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[    4.202402] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[    4.556496] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    4.637785] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[    4.689867] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    4.711580] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[    4.711604] checking generic (3e3cf000 7f8000) vs hw (0 ffffffffffffffff)
[    4.711623] fb0: switching to vc4drmfb from simple
[    4.714014] Console: switching to colour dummy device 80x30
[    4.714249] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    4.714261] [drm] No driver support for vblank timestamp query.
[    4.714273] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[    4.717651] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[    4.724919] vc4-drm gpu: HDMI-A-1: EDID is invalid:
[    4.724942] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.724955] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.724968] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.724980] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.724992] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.725005] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.725017] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.725029] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.745906] brcmfmac: F1 signature read @0x18000000=0x15264345
[    4.746634] Console: switching to colour frame buffer device 240x67
[    4.746684] vc4-drm gpu: fb0: vc4drmfb frame buffer device
[    4.760248] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    4.761610] usbcore: registered new interface driver brcmfmac
[    4.789271] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
[    5.019114] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    5.034197] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
[    6.753969] uart-pl011 fe201000.serial: no DMA platform data
[    6.908452] random: crng init done
[    6.908471] random: 7 urandom warning(s) missed due to ratelimiting
[    7.001432] 8021q: 802.1Q VLAN Support v1.8
[    7.211088] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
[    7.384177] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[    7.645974] bcmgenet: Skipping UMAC reset
[    7.647601] bcmgenet fd580000.ethernet: configuring instance for external RGMII
[    7.647796] bcmgenet fd580000.ethernet eth0: Link is Down
[    9.329015] broken atomic modeset userspace detected, disabling atomic
[   11.670655] fuse: init (API version 7.31)
[   12.871200] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   12.871227] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   13.301697] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   13.483355] Bluetooth: Core ver 2.22
[   13.483393] NET: Registered protocol family 31
[   13.483398] Bluetooth: HCI device and connection manager initialized
[   13.483412] Bluetooth: HCI socket layer initialized
[   13.483421] Bluetooth: L2CAP socket layer initialized
[   13.483434] Bluetooth: SCO socket layer initialized
[   13.490211] Bluetooth: HCI UART driver ver 2.3
[   13.490220] Bluetooth: HCI UART protocol H4 registered
[   13.490256] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   13.490381] Bluetooth: HCI UART protocol Broadcom registered
[   13.700879] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   13.700893] Bluetooth: BNEP filters: protocol multicast
[   13.700915] Bluetooth: BNEP socket layer initialized
[   13.766975] Bluetooth: RFCOMM TTY layer initialized
[   13.766998] Bluetooth: RFCOMM socket layer initialized
[   13.767015] Bluetooth: RFCOMM ver 1.11
[   13.911112] bcmgenet fd580000.ethernet eth0: Link is Down
[   18.071236] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   26.391161] bcmgenet fd580000.ethernet eth0: Link is Down
[   30.551247] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   48.231166] bcmgenet fd580000.ethernet eth0: Link is Down
[   52.391244] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   56.551177] bcmgenet fd580000.ethernet eth0: Link is Down
[   60.711286] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   62.791182] bcmgenet fd580000.ethernet eth0: Link is Down
[   66.951324] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   73.191175] bcmgenet fd580000.ethernet eth0: Link is Down
[   77.351256] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   80.471174] bcmgenet fd580000.ethernet eth0: Link is Down
[   84.631279] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   88.791191] bcmgenet fd580000.ethernet eth0: Link is Down
[   91.911250] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  135.591168] bcmgenet fd580000.ethernet eth0: Link is Down
[  139.751241] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  147.031161] bcmgenet fd580000.ethernet eth0: Link is Down
[  151.191305] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  152.231180] bcmgenet fd580000.ethernet eth0: Link is Down
[  156.391236] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  157.431191] bcmgenet fd580000.ethernet eth0: Link is Down
[  160.551262] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  162.631094] bcmgenet fd580000.ethernet eth0: Link is Down
[  166.791245] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  168.871170] bcmgenet fd580000.ethernet eth0: Link is Down
[  173.031295] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  176.151178] bcmgenet fd580000.ethernet eth0: Link is Down
[  180.311268] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  183.431177] bcmgenet fd580000.ethernet eth0: Link is Down
[  187.591257] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  190.711189] bcmgenet fd580000.ethernet eth0: Link is Down
[  194.871246] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  195.911174] bcmgenet fd580000.ethernet eth0: Link is Down
[  200.071260] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  202.151183] bcmgenet fd580000.ethernet eth0: Link is Down
[  206.311257] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  210.471164] bcmgenet fd580000.ethernet eth0: Link is Down
[  214.631268] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  217.751182] bcmgenet fd580000.ethernet eth0: Link is Down
[  221.911227] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  243.751163] bcmgenet fd580000.ethernet eth0: Link is Down
[  247.911248] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  254.151166] bcmgenet fd580000.ethernet eth0: Link is Down
[  258.311242] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  266.631190] bcmgenet fd580000.ethernet eth0: Link is Down
[  269.751237] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  270.791174] bcmgenet fd580000.ethernet eth0: Link is Down
[  274.951241] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  278.071186] bcmgenet fd580000.ethernet eth0: Link is Down
[  282.231267] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  286.391168] bcmgenet fd580000.ethernet eth0: Link is Down
[  290.551282] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  293.671160] bcmgenet fd580000.ethernet eth0: Link is Down
[  297.831279] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  300.951174] bcmgenet fd580000.ethernet eth0: Link is Down
[  305.111427] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  315.511149] bcmgenet fd580000.ethernet eth0: Link is Down
[  319.671283] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  320.711173] bcmgenet fd580000.ethernet eth0: Link is Down
[  324.871289] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  326.951249] bcmgenet fd580000.ethernet eth0: Link is Down
[  331.111256] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  346.711172] bcmgenet fd580000.ethernet eth0: Link is Down
[  349.831235] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  350.871163] bcmgenet fd580000.ethernet eth0: Link is Down
[  355.031263] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  356.071212] bcmgenet fd580000.ethernet eth0: Link is Down
[  360.231233] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  362.311198] bcmgenet fd580000.ethernet eth0: Link is Down
[  366.471236] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  367.511173] bcmgenet fd580000.ethernet eth0: Link is Down
[  371.671228] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  388.311166] bcmgenet fd580000.ethernet eth0: Link is Down
[  391.431258] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  393.511172] bcmgenet fd580000.ethernet eth0: Link is Down
[  397.671243] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  399.751162] bcmgenet fd580000.ethernet eth0: Link is Down
[  403.911245] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  410.151161] bcmgenet fd580000.ethernet eth0: Link is Down
[  414.311251] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  420.551182] bcmgenet fd580000.ethernet eth0: Link is Down
[  423.671241] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  424.711248] bcmgenet fd580000.ethernet eth0: Link is Down
[  427.831240] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  428.871186] bcmgenet fd580000.ethernet eth0: Link is Down
[  436.151222] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  467.351181] bcmgenet fd580000.ethernet eth0: Link is Down
[  470.471234] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  494.391156] bcmgenet fd580000.ethernet eth0: Link is Down
[  498.551245] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  502.711186] bcmgenet fd580000.ethernet eth0: Link is Down
[  506.871253] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  507.911173] bcmgenet fd580000.ethernet eth0: Link is Down
[  511.031242] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  513.111167] bcmgenet fd580000.ethernet eth0: Link is Down
[  517.271236] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  525.591161] bcmgenet fd580000.ethernet eth0: Link is Down
[  529.751242] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  547.431164] bcmgenet fd580000.ethernet eth0: Link is Down
[  559.911245] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  572.391158] bcmgenet fd580000.ethernet eth0: Link is Down
[  575.511239] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  581.751169] bcmgenet fd580000.ethernet eth0: Link is Down
[  590.071241] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  604.631163] bcmgenet fd580000.ethernet eth0: Link is Down
[  608.791265] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  615.031163] bcmgenet fd580000.ethernet eth0: Link is Down
[  618.151310] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  675.351145] bcmgenet fd580000.ethernet eth0: Link is Down
[  679.511281] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  682.631164] bcmgenet fd580000.ethernet eth0: Link is Down
[  686.791236] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  691.991170] bcmgenet fd580000.ethernet eth0: Link is Down
[  696.151233] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  705.511161] bcmgenet fd580000.ethernet eth0: Link is Down
[  709.671247] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  712.791172] bcmgenet fd580000.ethernet eth0: Link is Down
[  715.911238] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  724.231164] bcmgenet fd580000.ethernet eth0: Link is Down
[  728.391288] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  738.791189] bcmgenet fd580000.ethernet eth0: Link is Down
[  742.951276] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  743.991210] bcmgenet fd580000.ethernet eth0: Link is Down
[  747.111255] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  751.271181] bcmgenet fd580000.ethernet eth0: Link is Down
[  755.431247] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  777.271162] bcmgenet fd580000.ethernet eth0: Link is Down
[  781.431228] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  787.671166] bcmgenet fd580000.ethernet eth0: Link is Down
[  791.831252] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  806.391206] bcmgenet fd580000.ethernet eth0: Link is Down
[  814.711265] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  817.831182] bcmgenet fd580000.ethernet eth0: Link is Down
[  820.951238] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  823.031174] bcmgenet fd580000.ethernet eth0: Link is Down
[  827.191233] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  830.311167] bcmgenet fd580000.ethernet eth0: Link is Down
[  834.471246] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  845.911159] bcmgenet fd580000.ethernet eth0: Link is Down
[  849.031247] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  852.151163] bcmgenet fd580000.ethernet eth0: Link is Down
[  855.271240] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  865.671155] bcmgenet fd580000.ethernet eth0: Link is Down
[  868.791231] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  871.911182] bcmgenet fd580000.ethernet eth0: Link is Down
[  876.071237] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  880.231167] bcmgenet fd580000.ethernet eth0: Link is Down
[  884.391238] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  890.631172] bcmgenet fd580000.ethernet eth0: Link is Down
[  897.911260] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  906.231168] bcmgenet fd580000.ethernet eth0: Link is Down
[  910.391268] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  951.991167] bcmgenet fd580000.ethernet eth0: Link is Down
[  956.151257] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  961.351180] bcmgenet fd580000.ethernet eth0: Link is Down
[  965.511246] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  968.631193] bcmgenet fd580000.ethernet eth0: Link is Down
[  972.791229] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  976.951239] bcmgenet fd580000.ethernet eth0: Link is Down
[  981.111234] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  989.431168] bcmgenet fd580000.ethernet eth0: Link is Down
[  993.591240] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ 1013.351159] bcmgenet fd580000.ethernet eth0: Link is Down
[ 1017.511228] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ 1019.591173] bcmgenet fd580000.ethernet eth0: Link is Down
[ 1023.751245] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
Looks like a bad board to me. Let me know if there is anything else needed.
epoch1970
Re: New Rpi 4 ethernet port not working
Tue Oct 20, 2020 10:14 pm
Apparently it tries to work...
I’d bring the Pi to another network. Use their cables.
rustyshamrock
Tue Oct 20, 2020 10:35 pm
I suspect it is trying unsuccessfully to get an IP address. I removed the ethernet cable from a different (and functioning) pi-4 and plugged it into this unit. The other unit is now reconnected to that cable and functioning normally. I also tried other cables and ports on the switch, to no avail.
trejan
Tue Oct 20, 2020 10:54 pm
It is unlikely but try swapping the power supply + cable as well. If that doesn't help then it does look like the Pi is faulty and you need to contact whoever sold it to you for a replacement.
