blazessdd
hdd spin even after shutdown
Fri Oct 02, 2020 11:38 pm
I have a raspberry pi 4 which has the disk always spinning tried to put it on sleep with hdparm hdidle sdparm ecc.. but after the spin down the disk spins immediately up, i use the pi mainly as wol server so i dont need the disk for long time.
A check with iotop shows that the journal is the culprit this need further investigation.
now the problem is thaht the isk keeps spinning even after the shutdown i don't know where to search about someone could give me a hand?
Kendek
Re: hdd spin even after shutdown
Sat Oct 03, 2020 7:34 am
Two things:
1. The bootloader EEPROM configuration, power off the USB ports:
WAKE_ON_GPIO=0
POWER_OFF_ON_HALT=1
2. UDEV rule to set the 'manage_start_stop'; with value '1' the kernel will spin-down the disks at system shutdown:
/etc/udev/rules.d/01-manage_start_stop.rules
ACTION=="add|change", SUBSYSTEM=="scsi_disk", RUN+="/bin/sh -c 'echo 1 >/sys/class/scsi_disk/%k/manage_start_stop'"
LTolledo
Sat Oct 03, 2020 9:29 am
issuing the shutdown command means that you've committed yourself to turn-off (remove, cut-off, terminate) power to the setup
so the simplest solution is to turn off the power to the setup....
no power..... no spin....
Some people be like:
blazessdd
Thu Oct 08, 2020 12:48 pm
Two things:
WAKE_ON_GPIO=0
POWER_OFF_ON_HALT=1
got it thanks a lot : )
