if anyone can help, it would b e appreciated.
After using Arduino for several months, I decided I wanted to update my IDE software version. I downloaded the Linux 32 bit cersion of arduino-1.8.13, and ran the install, here is what I get:
pi@raspberrypi:~/Arduino/arduino-1.8.13 $ sudo ./install.sh
Adding desktop shortcut, menu item and file associations for Arduino IDE...
touch: cannot touch '/root/.config/mimeapps.list': No such file or directory
/usr/bin/xdg-mime: 848: /usr/bin/xdg-mime: cannot create /root/.config/mimeapps.list.new: Directory nonexistent
done!
Well, needless to say the install was not successful. Anyone know what I can do to fix? I have uninstalled previous version, uninstalled and reinstalled both older version and new version, and rebooted several times.
Please help if you can.
Roger Ayotte
Re: trouble with Arduino IDE install on Pi-4
I remember having the same issue. IIRC, it installed successfully when I ran install.sh as pi user. (so drop the sudo)Rcayot wrote: ↑Wed Sep 16, 2020 2:12 pmI downloaded the Linux 32 bit cersion of arduino-1.8.13, and ran the install, here is what I get:
pi@raspberrypi:~/Arduino/arduino-1.8.13 $ sudo ./install.sh touch: cannot touch '/root/.config/mimeapps.list': No such file or directory /usr/bin/xdg-mime: 848: /usr/bin/xdg-mime: cannot create /root/.config/mimeapps.list.new: Directory nonexistent
BTW: you mentioned 'Linux 32 bit' version. Many users would assume you downloaded x86 32-bit. (which is not what you want, as the Pi is ARM 32-bit/armhf)
Want to run Minecraft Java on your RPi? Easiest way is with Pi-Apps - just click Install.
https://github.com/Botspot/pi-apps
Pi-Apps also includes Zoom, Visual Studio, Tor browser, Windows 10 theme, and 33 more.
Over 50,000 users!
Over 50,000 users!
Well, from what-s-he tells, -s-he already installed Arduino (and the download link is unambiguous).
I had no issue with upgrading from Arduino-xx-12 to xx-13 on a pi4, with RPIOS32
On the Raspberry Pi 4 - 4 GB, I installed the ARM Arduino 32bit file. It extracted and installed. But when I click on the Arduino Icon in the GUI, the Arduino compiler does not open. Do I reinstall ARM Arduino 32 bit ....or uninstall ARM Arduino 32 bit and install ARM Arduino 64 bit?
I
The "touch" / "mimeapps" issue has occurred with every IDE Arduino install I have ever attempted on a Pi. It has not however interfered with operation and can IMO be considered a warning rather than an error or installation failure.
The developer of the install script obviously expects '/root' to have some particular layout even when it doesn't on some distros and the script doesn't handle that very elegantly.
When I run the install as Pi user, the error I get tells me to run with sudo
"pi@raspberrypi:~/Arduino/arduino-1.8.13 $ ./install.sh
rm: cannot remove '/usr/local/bin/arduino': Permission denied
Removing symlink failed. Hope that's OK. If not then rerun as root with sudo.
ln: failed to create symbolic link '/usr/local/bin/arduino': File exists
Adding symlink failed. Hope that's OK. If not then rerun as root with sudo.
done!"
Still, when rerun with sudo, the same error as previously posted comes up and does not run when teh desktop icon is run. Neither does it runh when 'right clicked' and 'open' from file manager.
Again, any help would be appreciated. The normally helpful Arduino forums do not appear to want to deal with a Pi problem.
Roger
done!"
Roger
Running with 'sudo' generates some messages about what it couldn't do. Running without 'sudo' generates even more messages about what it couldn't do. All these are IMO non-important and don't affect the actual installation, though running without 'sudo' may not allow use of the 'arduino' command at the command line.
So ... run with 'sudo', ignore the messages of what it couldn't do.
Now ... making it work from the desktop. That can be a bit tricky because it's not clear what mess has been created.
First thing is to run 'arduino --version' from the command line to find what version is installed. You should see something like ...
Next, run an 'arduino' command from a Terminal opened from your desktop. Does that launch the Arduino 1.8.13 IDE ?
If all that works then the issue is with the Start Menu shortcut. And I'll have to get back to you on how to fix that.
pi@Pi3B:~ $ arduino --version
Picked up JAVA_TOOL_OPTIONS:
Loading configuration...
Initialising packages...
Preparing boards...
Arduino: 1.8.13
pi@Pi3B:~ $ arduino
Set log4j store directory /home/pi/.arduino15
... Arduino IDE should pop-up over desktop
It's been a while. Though I do recall running install.sh first as Pi user, then again as root user. After doing those two passes it worked for me.Rcayot wrote: ↑Wed Sep 16, 2020 5:17 pmStill, when rerun with sudo, the same error as previously posted comes up and does not run when teh desktop icon is run.Code: Select all
"pi@raspberrypi:~/Arduino/arduino-1.8.13 $ ./install.sh ln: failed to create symbolic link '/usr/local/bin/arduino': File exists Adding symlink failed. Hope that's OK. If not then rerun as root with sudo. done!"
Over 50,000 users!
Over 50,000 users!
some additional information:
This appears to be part of the problem:
"touch: cannot touch '/root/.config/mimeapps.list': No such file or directory
/usr/bin/xdg-mime: 848: /usr/bin/xdg-mime: cannot create /root/.config/mimeapps.list.new: Directory nonexistent"
Well, there is no "/root/.config/mimeapps.list"
But there IS:
/home/pi/.config/mimeapps.list
How do I get this corrected? I do not think I can just move the file.
Roger
But there IS:
Roger
I think that the 'arduino' script does not work. The desktop icon 'properties' 'desktop entry' indicates the file to run is "/home/pi/Arduino/arduino-1.8.13/arduino"
and when I run 'arduino' from that directory, the app does not start.
and here is what happens if I run from teh command line:
"pi@raspberrypi:~/Arduino/arduino-1.8.13 $ arduino --version
/usr/local/bin/arduino: line 35: /home/pi/Arduino/arduino-1.8.13/java/bin/java: cannot execute binary file: Exec format error"
are we making progress?
Roger
Roger
Did you download the correct version from the Arduino website, i.e. “Linux ARM 32 bits", not “Linux 32 bits”?
OK I went ahead and booted a fresh RaspiOS image using my Vdesktop VM software.
This sequence of commands installs Arduino on the VM successfully:
wget https://downloads.arduino.cc/arduino-1.8.13-linuxarm.tar.xz
xz -d /home/pi/arduino-1.8.13-linuxarm.tar.xz
tar -xf /home/pi/arduino-1.8.13-linuxarm.tar
/home/pi/arduino-1.8.13/install.sh
sudo /home/pi/arduino-1.8.13/install.sh
Over 50,000 users!
Over 50,000 users!
I downbloaded linus32.tar not linuxarm.tar.
Going to uninstall, then install 1.8.12
Roger
Roger
Just ignore it.Rcayot wrote: ↑Wed Sep 16, 2020 5:38 pmThis appears to be part of the problem:
But there IS:
You will very likely get the same message when you install the correct package but AIUI it isn't actually problematic, won't prevent installation, won't prevent the Arduino IDE running, has no discernible consequences I have seen.
Suggestions to improve the installation scripts should be directed at the Arduino IDE developers.
OK that is a common mistake.
Let us know if it is working now...
Greetings, on my RPi 4 ,I uninstalled Arduino 1.8.13 using rm -RF arduino-1.8.13-linuxaarch64.tar.xz . From arduino.cc I downloaded Linux ARM 32 bit.
2) I right clicked on the zipped icon and selected "Extract Here"
3) waited several minutes ...there was no prompts on the screen... then another extracted was displayed Downloads directory.
4) went to terminal
cd Downloads
ls -all
pi@raspberry:~/Downloads$ cd arduino-1-8.13
pi@raspberry:~/Downloads/ arduino-1-8.13 $ ls -all
pi@raspberry:~/Downloads/ arduino-1-8.13 $ sudo ./install.sh
couple of minutes later it says done.
The icon appears under Programming and runs the Arduino UNO using dev USB...... not dev TTY .
These instructions worked on both the 3B+ and RPi 4 using the Linux ARM 32 bit download. It did NOT work with the Linux ARM 64 bit download.
Blessings..
4) went to terminal
cd Downloads
ls -all
Blessings..
downloading the correct version worked perfectly.
I did not heed early suggestions to check if it was the correct version. Learned valuable lesson!
Thanks to all!
Roger
Thanks to all!
Roger
I am glad it is now working for you.
