Fred85
Raspberry 4 + CAM LINK for Youtube Live
Tue Sep 15, 2020 11:54 am
I would like to use a CAM LINK through USB3 with Raspberry 4 to realise a Youtube Live.
After reading many topics, ffmpeg is a good idea.
But I have this message once I launch ffmpeg :
Cannot find a proper format for codec ‹ h264 › (id 27), pixel format ‹ none › (id -1)
Assertion *codec_id != AV_CODEC_ID_NONE failed at src/libavdevice/v4l2.c:811
Could you help me ?
Thank you very much !
Fred
topguy
Re: Raspberry 4 + CAM LINK for Youtube Live
Tue Sep 15, 2020 12:22 pm
Probably useful to see the whole "ffmpeg" command you are running.
So you have a camera with HDMi output that connects to the CAM-Link and then the CAM-Link is plugged into the Pi4 ?
Is the camera ON and connected to the CAM-Link when testing your command ?
Some other thread about the CAM-Link
viewtopic.php?t=259083
Fred85
Tue Sep 15, 2020 4:28 pm
Thank you for your reply.
Yes, camera was ON. I can see video on VLC (with some strange green lines).
My command is :
ffmpeg -ar 44100 -ac 2 -f alsa -i hw:2,0 -f v4l2 -codec:v h264 -framerate 30 -video_size 1920x1080 -itsoffset 0.5 -i /dev/video0 -copyinkf -codec:v copy -codec:a aac -ab 128k -g 10 -f flv rtmp://a.rtmp.youtube.com/live2/"Youtube Live key"
and the message is :
[video4linux2,v4l2 @ 0x22725b0] Cannot find a proper format for codec 'h264' (id 27), pixel format 'none' (id -1)
As mensioned on your link, I just want to do same installation as : https://hackaday.com/2019/09/27/a-raspb ... -backpack/
If you have an idea.
Thank you.
topguy
Tue Sep 15, 2020 4:52 pm
Where did you copy that ffmpeg command from ?
The -codec:v h264 is the only place there is a reference to "h264" from the error, but it also looks for "pixel format" so maybe look in the ffmpeg docs for that.
Fred85
Tue Sep 15, 2020 8:07 pm
To begin, thank you for all your replies.
I took this command here (in french) :
https://www.arrow.com/fr-fr/research-an ... with-video
I continue to find the problem and a solution.
6by9
Tue Sep 15, 2020 8:31 pm
The Pi camera module (which that article is referring to) can encode to h264 effectively natively. Your V4L2 device can't, therefore it throws an error when you try.
Use "v4l2-ctl --list-formats" to list the supported formats of your capture device and choose one of them. You should then be able to encode it using the H264 encoder on the Pi (h264_v4l2m2m most likely).
topguy
Tue Sep 15, 2020 8:55 pm
- That article is 4 years old
- I think it mentions a C920 webcam..
Run the "v4l2-ctl --all" commnand with your camera connected.
and " v4l2-ctl -d 0 --list-formats-ext".
Fred85
Wed Sep 16, 2020 5:10 am
6by9, topguy,
Below my screen with these 3 commands :
ioctl: VIDIOC_ENUM_FMT
	Type: Video Capture
	[0]: 'YUYV' (YUYV 4:2:2)
	[1]: 'NV12' (Y/CbCr 4:2:0)
	[2]: 'YU12' (Planar YUV 4:2:0)
	Type: Video Capture
			Interval: Discrete 0.020s (50.000 fps)
v4l2-ctl --all
Driver Info:
	Driver name      : uvcvideo
	Card type        : Cam Link 4K: Cam Link 4K
	Bus info         : usb-0000:01:00.0-1
	Driver version   : 5.4.51
	Capabilities     : 0x84a00001
		Video Capture
		Metadata Capture
		Streaming
		Extended Pix Format
		Device Capabilities
	Device Caps      : 0x04200001
		Video Capture
		Streaming
		Extended Pix Format
Media Driver Info:
	Model            : Cam Link 4K: Cam Link 4K
	Serial           : 0002C8B612000
	Media version    : 5.4.51
	Hardware revision: 0x00000000 (0)
Interface Info:
	Type             : V4L Video
Entity Info:
	Name             : Cam Link 4K: Cam Link 4K
	Function         : V4L2 I/O
	Flags         : default
	Pad 0x01000007   : 0: Sink
	  Link 0x0200000d: from remote pad 0x100000a of entity 'Processing 2': Data, Enabled, Immutable
Priority: 2
Video input : 0 (Input 1: ok)
Format Video Capture:
	Width/Height      : 1280/720
	Pixel Format      : 'YUYV' (YUYV 4:2:2)
	Field             : None
	Bytes per Line    : 2560
	Size Image        : 1843200
	Colorspace        : sRGB
	Transfer Function : Default (maps to sRGB)
	YCbCr/HSV Encoding: Default (maps to ITU-R 601)
	Quantization      : Default (maps to Limited Range)
	Flags             :
Crop Capability Video Capture:
	Bounds      : Left 0, Top 0, Width 1280, Height 720
	Default     : Left 0, Top 0, Width 1280, Height 720
	Pixel Aspect: 1/1
Selection: crop_default, Left 0, Top 0, Width 1280, Height 720, Flags:
Selection: crop_bounds, Left 0, Top 0, Width 1280, Height 720, Flags:
Streaming Parameters Video Capture:
	Capabilities     : timeperframe
	Frames per second: 50.000 (50/1)
	Read buffers     : 0
                     brightness 0x00980900 (int)    : min=0 max=255 step=1 default=128 value=128
                       contrast 0x00980901 (int)    : min=0 max=255 step=1 default=128 value=128
                     saturation 0x00980902 (int)    : min=0 max=255 step=1 default=128 value=128
                            hue 0x00980903 (int)    : min=0 max=255 step=1 default=128 value=128
Fred85
Wed Sep 16, 2020 10:03 am
Futhermore, I have :
ffmpeg -f v4l2 -list_formats all -i /dev/video0
ffmpeg version 4.1.6-1~deb10u1+rpt1 Copyright (c) 2000-2020 the FFmpeg developers
  built with gcc 8 (Raspbian 8.3.0-6+rpi1)
  configuration: --prefix=/usr --extra-version='1~deb10u1+rpt1' --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared --libdir=/usr/lib/arm-linux-gnueabihf --cpu=arm1176jzf-s --arch=arm
  WARNING: library configuration mismatch
  avutil      configuration: --prefix=/usr --extra-version='1~deb10u1+rpt1' --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
  avcodec     configuration: --prefix=/usr --extra-version='1~deb10u1+rpt1' --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
  avformat    configuration: --prefix=/usr --extra-version='1~deb10u1+rpt1' --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
  avdevice    configuration: --prefix=/usr --extra-version='1~deb10u1+rpt1' --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
  avfilter    configuration: --prefix=/usr --extra-version='1~deb10u1+rpt1' --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
  avresample  configuration: --prefix=/usr --extra-version='1~deb10u1+rpt1' --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
  swscale     configuration: --prefix=/usr --extra-version='1~deb10u1+rpt1' --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
  swresample  configuration: --prefix=/usr --extra-version='1~deb10u1+rpt1' --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
  postproc    configuration: --prefix=/usr --extra-version='1~deb10u1+rpt1' --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
  libavutil      56. 22.100 / 56. 22.100
  libavcodec     58. 35.100 / 58. 35.100
  libavformat    58. 20.100 / 58. 20.100
  libavdevice    58.  5.100 / 58.  5.100
  libavfilter     7. 40.101 /  7. 40.101
  libavresample   4.  0.  0 /  4.  0.  0
  libswscale      5.  3.100 /  5.  3.100
  libswresample   3.  3.100 /  3.  3.100
  libpostproc    55.  3.100 / 55.  3.100
[video4linux2,v4l2 @ 0x12ac1c0] Raw       :     yuyv422 :           YUYV 4:2:2 : 1280x720
[video4linux2,v4l2 @ 0x12ac1c0] Raw       :        nv12 :         Y/CbCr 4:2:0 : 1280x720
[video4linux2,v4l2 @ 0x12ac1c0] Raw       :     yuv420p :     Planar YUV 4:2:0 : 1280x720
/dev/video0: Immediate exit requested
Why I don't have details concerning compressed format ?
Thank you.
topguy
Wed Sep 16, 2020 10:38 am
I belive that is because its not compressed, its "Raw", that is why it needs USB3.
You see your camera also just outputs 720p so no reason to use 1080p for the encoding either. ( The resolution will change based on what is plugged into the CAM-Link )
You should probably just try to build your ffmpeg command in steps.. starting with verifying that something simple works like just grabbing some video.
ffmpeg -f v4l2 -i /dev/video0 capture.mkv
Fred85
Wed Sep 16, 2020 10:44 am
Ok, thank you.
720p is perfect for me. And v4l2 change automaticaly the video format.
Someone advised me to add -pix_fmt yuyv422 :
ffmpeg -ar 44100 -ac 2 -f alsa -i hw:2,0 -f v4l2 -codec:v h264 -pix_fmt yuyv422 -framerate 30 -video_size 1920x1080 -itsoffset 0.5 -i /dev/video0 -copyinkf -codec:v copy -codec:a aac -ab 128k -g 10 -f flv rtmp://a.rtmp.youtube.com/live2/
But same result... :
//home/pi/LiveVideo/StartLive.sh
Guessed Channel Layout for Input Stream #0.0 : stereo
Input #0, alsa, from 'hw:2,0':
  Duration: N/A, start: 1600252383.090168, bitrate: 1536 kb/s
    Stream #0:0: Audio: pcm_s16le, 48000 Hz, stereo, s16, 1536 kb/s
[video4linux2,v4l2 @ 0x19c05b0] The V4L2 driver changed the video from 1920x1080 to 1280x720
[video4linux2,v4l2 @ 0x19c05b0] Cannot find a proper format for codec 'h264' (id 27), pixel format 'yuyv422' (id 1)
//home/pi/LiveVideo/StartLive.sh : ligne 1 :  3785 Abandon                 ffmpeg -ar 44100 -ac 2 -f alsa -i hw:2,0 -f v4l2 -codec:v h264 -pix_fmt yuyv422 -framerate 30 -video_size 1920x1080 -itsoffset 0.5 -i /dev/video0 -copyinkf -codec:v copy -codec:a aac -ab 128k -g 10 -f flv rtmp://a.rtmp.youtube.com/live2/"Youtube Key"
//home/pi/LiveVideo/StartLive.sh: ligne 3: fin de fichier (EOF) prématurée lors de la recherche du « " » correspondant
//home/pi/LiveVideo/StartLive.sh: ligne 11: erreur de syntaxe : fin de fichier prématurée
Do you have some idea ?
Thank you very much for your help.
topguy
Wed Sep 16, 2020 11:31 am
my "idea".
ffmpeg -ar 44100 -ac 2 -f alsa -i hw:2,0 -f v4l2 -pix_fmt yuyv422 -framerate 30 -video_size 1280x720 -itsoffset 0.5 -i /dev/video0 -copyinkf -codec:v h264 -codec:a aac -ab 128k -g 10 -f flv rtmp://a.rtmp.youtube.com/live2/
Fred85
Wed Sep 16, 2020 11:38 am
Oh, thank you !
Not more this *#!/% error :
//home/pi/LiveVideo/StartLive.sh: ligne 1: ffmpeg -ar 44100 -ac 2 -f alsa -i hw:2,0 -f v4l2 -codec:v h264_v4l2m2m -pix_fmt yuv720p -framerate 30 -video_size 1280x720 -i /dev/video0 -copyinkf -codec:v copy -codec:a aac -ab 128k -g 10 -f flv rtmp://a.rtmp.youtube.com/live2/pyaz-egue-hp-umju-bsv8: Aucun fichier ou dossier de ce type
  Duration: N/A, start: 1600256169.680345, bitrate: 1536 kb/s
[video4linux2,v4l2 @ 0x10e35b0] The driver changed the time per frame from 1/30 to 1/50
Input #1, video4linux2,v4l2, from '/dev/video0':
  Duration: N/A, start: 8878.561011, bitrate: 737280 kb/s
    Stream #1:0: Video: rawvideo (YUY2 / 0x32595559), yuyv422, 1280x720, 737280 kb/s, 50 fps, 50 tbr, 1000k tbn, 1000k tbc
rtmp://a.rtmp.youtube.com/live2/"Youtube Live key": Input/output error
//home/pi/LiveVideo/StartLive.sh: ligne 5: fin de fichier (EOF) prématurée lors de la recherche du « " » correspondant
//home/pi/LiveVideo/StartLive.sh: ligne 13: erreur de syntaxe : fin de fichier prématurée
I have to check where come from the web link adress / key or something else.
Thank you again.
topguy
Wed Sep 16, 2020 1:12 pm
I think you have to actually go to Youtube Studio and create a stream before you get to access the key you need to replace "Youtube Live key" with.
Fred85
Wed Sep 16, 2020 2:08 pm
I have the video on Youtube Studio !! :)
But very bad Birate : around 600 kbit/s. And Youtube recommands 2 500 kbit/s.
The result is 1 image each 10s :cry:
How can I improve this ?
Thank you
6by9
Wed Sep 16, 2020 2:18 pm
Simplify your life and stream to a local file (eg a .mkv) first instead of messing with streaming.
Same as you specify "-ab 128k" to set the audio codec bitrate, you need to set the video codec bitrate. "-b:v 2500k" would be a start, although ffmpeg is always fussy about where exactly in the command you place that.
(Memory says that -ab is deprecated and you should really be using "-b:a 128k")
Fred85
Wed Sep 16, 2020 3:45 pm
I record a .mkv file but VLC cannot open it. Sound but no video..
I screenshot what happen :
  Duration: N/A, start: 1600270983.951125, bitrate: 1536 kb/s
[video4linux2,v4l2 @ 0x1c8d5f0] The driver changed the time per frame from 1/30 to 1/50
  Duration: N/A, start: 2785.703695, bitrate: 737280 kb/s
Stream mapping:
  Stream #1:0 -> #0:0 (rawvideo (native) -> h264 (libx264))
  Stream #0:0 -> #0:1 (pcm_s16le (native) -> aac (native))
Press [q] to stop, [?] for help
[libx264 @ 0x1c913d0] using cpu capabilities: ARMv6 NEON
[libx264 @ 0x1c913d0] profile High 4:2:2, level 3.2, 4:2:2 8-bit
[libx264 @ 0x1c913d0] 264 - core 155 r2917 0a84d98 - H.264/MPEG-4 AVC codec - Copyleft 2003-2018 - http://www.videolan.org/x264.html - options: cabac=1 ref=3 deblock=1:0:0 analyse=0x3:0x113 me=hex subme=7 psy=1 psy_rd=1.00:0.00 mixed_ref=1 me_range=16 chroma_me=1 trellis=1 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=-2 threads=6 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=2 keyint=10 keyint_min=1 scenecut=40 intra_refresh=0 rc_lookahead=10 rc=abr mbtree=1 bitrate=2500 ratetol=1.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 aq=1:1.00
[alsa @ 0x1c803d0] Thread message queue blocking; consider raising the thread_queue_size option (current value: 8)
Output #0, flv, to 'rtmp://a.rtmp.youtube.com/live2/e53q-x9c7-td0m-hc9h-2m9f':
  Metadata:
    encoder         : Lavf58.20.100
    Stream #0:0: Video: h264 (libx264) ([7][0][0][0] / 0x0007), yuv422p(progressive), 1280x720, q=-1--1, 2500 kb/s, 50 fps, 1k tbn, 50 tbc
    Metadata:
      encoder         : Lavc58.35.100 libx264
    Side data:
      cpb: bitrate max/min/avg: 0/0/2500000 buffer size: 0 vbv_delay: -1
    Stream #0:1: Audio: aac (LC) ([10][0][0][0] / 0x000A), 48000 Hz, stereo, fltp, 128 kb/s
    Metadata:
      encoder         : Lavc58.35.100 aac
[video4linux2,v4l2 @ 0x1c8d5f0] Thread message queue blocking; consider raising the thread_queue_size option (current value: 8)
frame=   11 fps=0.0 q=0.0 size=       0kB time=00:00:00.00 bitrate=N/A speed=   frame=   17 fps= 15 q=0.0 size=       0kB time=00:00:00.00 bitrate=N/A speed=   frame=   21 fps= 11 q=35.0 size=       0kB time=00:00:00.46 bitrate=   7.0kbits/frame=   26 fps= 10 q=32.0 size=      52kB time=00:00:00.57 bitrate= 738.5kbits/[alsa @ 0x1c803d0] ALSA buffer xrun.
frame=   31 fps=9.8 q=32.0 size=      57kB time=00:00:00.66 bitrate= 708.0kbits/frame=   38 fps= 10 q=34.0 size=     108kB time=00:00:03.62 bitrate= 243.4kbits/frame=   42 fps=9.6 q=33.0 size=     159kB time=00:00:03.62 bitrate= 359.9kbit[alsa @ 0x1c803d0] ALSA buffer xrun. 849kB time=00:00:03.64 bitrate=1909.1kbits/s speed=0.267x
frame=  112 fps=3.8 q=22.0 size=    2421kB time=00:00:14.45 bitrate=1372.0kbits/s speed=0.49x
Another "good idea" as previously ? ;-)
Thank you
6by9
Wed Sep 16, 2020 5:08 pm
libx264 is a software H264 encoder - it's going to be a bit slow.
I didn't think ARMv6 (the CPU on PI0&1) supported NEON, so that's an odd one.
You want to be using h264_v4l2m2m to use the hardware acceleration. Please quote your command lines as well as the output logging.
One thing with h264_v4l2m2m is that YUYV / YUY2 will give you no gain over NV12 or YU12. The codec only supports YUV420, so you're just increasing the input data rate over the USB interface for no specific gain. It'll convert it internally to YUV420 before encoding.
topguy
Wed Sep 16, 2020 6:48 pm
I'm pretty sure Fred would like an example on how to do that... ;)
6by9
Wed Sep 16, 2020 7:38 pm
He'd already done it earlier, but he hasn't posted his command line this time for us to know whether he did the same thing this time.
-c:v h264_v4l2m2m
Fred85
Thu Sep 17, 2020 9:02 am
Hello !
Your are fantastic ! Thank you for your help. :P
So, this is the command :
ffmpeg -ar 44100 -ac 2 -f alsa -i hw:2,0 -f v4l2 -pix_fmt yuyv422 -framerate 30 -video_size 1280x720 -itsoffset 0.5 -i /dev/video0 -copyinkf -codec:v h264_v4l2m2m -codec:a aac -ab 128k -b:v 2500k -g 10 -f flv rtmp://a.rtmp.youtube.com/live2/"key"
I have bad results :
1/ Video is sad :
It should be :
and this is the result :
=> Green lines + not all the screen
2/ Youtube show a message to say that the resolution 65535x65535 is not optimal. And impossible to select a better resolution up to 360p...
3/ After reboot, first command send the video up to 4000 kbit/s
  Duration: N/A, start: 1600329606.297148, bitrate: 1536 kb/s
[video4linux2,v4l2 @ 0x1eb05f0] The driver changed the time per frame from 1/30 to 1/50
  Duration: N/A, start: 102.224972, bitrate: 737280 kb/s
Stream mapping:
  Stream #1:0 -> #0:0 (rawvideo (native) -> h264 (h264_v4l2m2m))
[h264_v4l2m2m @ 0x1eb43c0] driver 'uvcvideo' on card 'Cam Link 4K: Cam Link 4K'
    Last message repeated 1 times
[h264_v4l2m2m @ 0x1eb43c0] driver 'bcm2835-codec' on card 'bcm2835-codec-isp'
[h264_v4l2m2m @ 0x1eb43c0] driver 'bcm2835-codec' on card 'bcm2835-codec-encode'
[h264_v4l2m2m @ 0x1eb43c0] Using device /dev/video11
[h264_v4l2m2m @ 0x1eb43c0] Failed to set number of B-frames
[h264_v4l2m2m @ 0x1eb43c0] Failed to set header mode
[h264_v4l2m2m @ 0x1eb43c0] Failed to set gop size
[h264_v4l2m2m @ 0x1eb43c0] h264 profile not found
[h264_v4l2m2m @ 0x1eb43c0] Encoder adjusted: qmin (0), qmax (51)
[h264_v4l2m2m @ 0x1eb43c0] Failed to set minimum video quantizer scale
[h264_v4l2m2m @ 0x1eb43c0] Failed to set maximum video quantizer scale
[alsa @ 0x1ea33d0] Thread message queue blocking; consider raising the thread_queue_size option (current value: 8)
  Metadata:
    Stream #0:0: Video: h264 (h264_v4l2m2m) ([7][0][0][0] / 0x0007), yuyv422(progressive), 1280x720, q=2-31, 2500 kb/s, 50 fps, 1k tbn, 50 tbc
    Metadata:
      encoder         : Lavc58.35.100 h264_v4l2m2m
    Metadata:
[video4linux2,v4l2 @ 0x1eb05f0] Thread message queue blocking; consider raising the thread_queue_size option (current value: 8)
[flv @ 0x1eb2fe0] Non-monotonous DTS in output stream 0:0; previous: 994940, current: 994920; changing to 994940. This may result in incorrect timestamps in the output file.
[flv @ 0x1eb2fe0] Non-monotonous DTS in output stream 0:0; previous: 1010640, current: 1010620; changing to 1010640. This may result in incorrect timestamps in the output file.
[flv @ 0x1eb2fe0] Non-monotonous DTS in output stream 0:0; previous: 1859840, current: 1859820; changing to 1859840. This may result in incorrect timestamps in the output file.
[flv @ 0x1eb2fe0] Non-monotonous DTS in output stream 0:0; previous: 2840500, current: 2840480; changing to 2840500. This may result in incorrect timestamps in the output file.
[flv @ 0x1eb2fe0] Non-monotonous DTS in output stream 0:0; previous: 3223780, current: 3223740; changing to 3223780. This may result in incorrect timestamps in the output file.
[flv @ 0x1eb2fe0] Non-monotonous DTS in output stream 0:0; previous: 3244280, current: 3244240; changing to 3244280. This may result in incorrect timestamps in the output file.
[flv @ 0x1eb2fe0] Non-monotonous DTS in output stream 0:0; previous: 3525020, current: 0; changing to 3525020. This may result in incorrect timestamps in the output file.
[flv @ 0x1eb2fe0] Failed to update header with correct duration.
[flv @ 0x1eb2fe0] Failed to update header with correct filesize.
frame=169787 fps= 48 q=-0.0 Lsize= 1788406kB time=00:58:45.05 bitrate=4156.1kbits/s speed=   1x
But if I stop and launch again, the rate is around 1 kbit/s
  Duration: N/A, start: 1600333158.533886, bitrate: 1536 kb/s
[video4linux2,v4l2 @ 0x69a5f0] The driver changed the time per frame from 1/30 to 1/50
[video4linux2,v4l2 @ 0x69a5f0] Dequeued v4l2 buffer contains corrupted data (0 bytes).
  Duration: N/A, start: 0.000000, bitrate: 737280 kb/s
Stream mapping:
    Last message repeated 30 times
[h264_v4l2m2m @ 0x69e3c0] driver 'uvcvideo' on card 'Cam Link 4K: Cam Link 4K'
[h264_v4l2m2m @ 0x69e3c0] driver 'bcm2835-codec' on card 'bcm2835-codec-isp'
[h264_v4l2m2m @ 0x69e3c0] driver 'bcm2835-codec' on card 'bcm2835-codec-encode'
[h264_v4l2m2m @ 0x69e3c0] Using device /dev/video11
[h264_v4l2m2m @ 0x69e3c0] Failed to set number of B-frames
[h264_v4l2m2m @ 0x69e3c0] Failed to set header mode
[h264_v4l2m2m @ 0x69e3c0] Failed to set gop size
[h264_v4l2m2m @ 0x69e3c0] h264 profile not found
[h264_v4l2m2m @ 0x69e3c0] Encoder adjusted: qmin (0), qmax (51)
[h264_v4l2m2m @ 0x69e3c0] Failed to set minimum video quantizer scale
[h264_v4l2m2m @ 0x69e3c0] Failed to set maximum video quantizer scale
[alsa @ 0x68d3d0] Thread message queue blocking; consider raising the thread_queue_size option (current value: 8)
  Metadata:
    Metadata:
    Metadata:
[video4linux2,v4l2 @ 0x69a5f0] Thread message queue blocking; consider raising the thread_queue_size option (current value: 8)
[flv @ 0x69cfe0] Non-monotonous DTS in output stream 0:0; previous: 3655460, current: 0; changing to 3655460. This may result in incorrect timestamps in the output file.
[flv @ 0x69cfe0] Failed to update header with correct duration.
[flv @ 0x69cfe0] Failed to update header with correct filesize.
frame=    3 fps=0.2 q=-0.0 Lsize=     530kB time=01:00:55.46 bitrate=   1.2kbits/s speed= 223x
video:262kB audio:255kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 2.546771%
For your information, to have up to 4000 kbit/s, the reason could be that I'm at work now, not at home.
I'm looking for a solution but your help is welcome !
Thank you :)
Fred85
Thu Sep 17, 2020 2:26 pm
I found a solution to have the real picture : no green, all the screen. I use codec libx264 instead of h264_v4l2m2m.
But have same problem : big lag : 1 picture and freeze to download others pictures... Don't know why. :(
6by9
Thu Sep 17, 2020 3:28 pm
Already stated libx264 is software only and will be slow.
You've gone back to streaming to Youtube. Saving to a local file is far easier to debug.
You've also ignored my comment about there being no point in using YUY2 over YU12/NV12.
Your stream is also at 50fps, so trying to force the framerate to 30fps is flawed.
If something thinks that something is at 65535x65535 then probably the output resolution has been misconfigured. Normally this matches the input resolution, so I don't know what FFmpeg is playing at.
Fred85
Fri Sep 18, 2020 3:07 pm
Thank you 6by9.
The command line is at 30 fps, not 50 fps : "-framerate 30" ? Am I wrong ?
When I write "-pix_fmt yuv420" instead of "-pix_fmt yuyv422", I have this message :
[video4linux2,v4l2 @ 0x1dab5f0] No such input format: yuv420.
/dev/video0: Invalid argument
This command let me crazy :?
For the moment, the ffmpeg is at this state :
ffmpeg -ar 44100 -ac 2 -f alsa -i hw:2,0 -f v4l2 -pix_fmt yuyv422 -framerate 30 -video_size 1280x720 -itsoffset 0.5 -i /dev/video0 -copyinkf -codec:v h264_v4l2m2m -codec:a aac -ab 128k -b:v 4000k -g 10 -f flv rtmp://a.rtmp.youtube.com/live2/
Looking for a solution... :geek:
Thank you very much !!
6by9
Fri Sep 18, 2020 4:23 pm
The frame rate is whatever the source says it is. There is no way in the hardware to interpolate frames to give you a choice over the frame rate.
FFmpeg is giving you an error saying
so it has most likely corrected your error, but always safer to avoid the potential.
Fred85 wrote:When I write "-pix_fmt yuv420" instead of "-pix_fmt yuyv422", I have this message :
Check the ffmpeg docs and you'd see that it uses the pixel format name "yuv420p".
