smb3
Starting Kodi crashes the whole OS
Wed Sep 02, 2020 5:04 pm
So I am running Raspberry Pi OS Buster and I installed Kodi on a fresh install. I used both the
sudo apt-get kodi
and also tried getting it from the "add or remove apps" tool. When you click kodi to start it the screen simply goes blank and then shows a blinking cursor.
The only thing you can do to use the Pi again is to pull the power plug and reboot. When Kodi is installed through a RetroPie OS, it will start fine and works great! I need to run Kodi on the Raspberry OS so I can use the brightness tool since I am using the Official 7" touchscreen.
Any ideas as to why this is happening? I tried different power supplies but that did not help.
DarrenHill
Re: Starting Kodi crashes the whole OS
Thu Sep 03, 2020 7:26 am
Kodi needs more memory assigned to the GPU from what is set as standard.
Open the config app (sudo raspi-config) then go to advanced options (7) then memory split (A3) and set that to 256mb (for a Pi3 or Pi4). Then exit out of the app and reboot.
Alternatively you can use the GUI version (menu > preferences > Raspberry Pi Configuration) and there set the value on the Performance tab (GPU memory setting, the middle one on the tab), then exit and reboot.
See here for a guide on setting it up and what else may need to be done.
Thu Sep 03, 2020 8:20 am
sudo apt-get kodi
sudo apt update
sudo apt install kodi
Thinking outside the box is better than burying your head in the sand...
smb3
Thu Sep 03, 2020 11:38 pm
sudo apt update
Ummm all this does is update Kodi. How would this help someone who’s done this several times? The GPU memory reply seems a lot more plausible.
smb3
Thu Sep 03, 2020 11:42 pm
@DarrenHill it worked! Thank you so much! I was worried it wasn’t working since it showed the blinking cursor for a few seconds before loading Kodi up fine! Thank you!
DarrenHill
Fri Sep 04, 2020 8:12 pm
You're most welcome :)
Happy to help out...
