Can't get 3.5" LCD to work with Pi 4
Posted: Wed Sep 02, 2020 6:19 am
by TiiGx
Hey guys!
I am a Raspberry newbie! Got my first raspberry PI 4 4 GB. And after I installed the OS. And after I connected my raspberry to my keyboard, mouse and monitor, i wanted to activate my 3.5 LCD RPI screen.
So i do exactly as the instruction told me to do. But after i finish the commands my monitor turns black and my LCD is still only white. i tried to do it 4 times and i restarted it several times. But it still doesnt work. Help me! I pull my hair out soon!
Best Regards!
Re: Can't get 3.5" LCD to work with Pi 4
Posted: Wed Sep 02, 2020 9:49 am
by RGJ-PI
What make and model 3.5" LCD are you trying to use?
Posted: Wed Sep 02, 2020 10:02 am
by TiiGx
It says 3.5" LCD RPI on the back. i bought kit B on the link below.
https://www.ebay.com/itm/Raspberry-Pi-4 ... 2749.l2649
Posted: Fri Sep 04, 2020 4:42 am
by TiiGx
Help please! :/
Posted: Fri Sep 04, 2020 8:26 am
by PhilE
1. What instructions have you followed? Don't make us guess.
2. What is in your config.txt file?
3. What do the following commands return:
$ uname -a
$ vcgencmd version
$ sudo vcdbg log msg
$ raspi-gpio get
$ dmesg
Posted: Tue Oct 06, 2020 10:53 am
by TiiGx
I followed the instructions and wrote the commands in CMD that followed with the screen. The commands you just wrote? What are those for? I am a total beginner with raspberry PI.
Posted: Tue Oct 06, 2020 11:00 am
by PhilE
That's great for you, but I can't see the instructions so I've no idea what you've done. You should at least be able to open a Terminal window (or CMD as you call it) and type
grep -v -E "^(#|$)" /boot/config.txt
and show me the output.
The other commands I listed are my attempt to determine what state your system is in, looking for error messages and other clues.
Posted: Tue Oct 06, 2020 11:28 am
by hansotten
The ebay url has a simple instruction:
Before you use screen, you need to install a driver for the screen in your system
And that is it.
Typical ebay seller!
You could try to ask the seller for support, I hope but doubt he will be able to.
