dieteltow
2 Webcams with motion
Fri Jan 04, 2013 9:37 pm
Hi all,
I'm running successfully a Creative Live! Cam Sync on my Pi (debian-wheezy). I have a webstream and motion takes pictures when it detects motion. It works when connected to a powered usb hub and directly connected to the on board usb port. So far so good.
Now I connected a second camera of the same type. I configured Thread1.conf for dev/video0 and Thread2.conf for /dev/video1. Both cameras are connected to the onboard usb ports (I connect to the pi using ssh, so don't need mouse and keyboard connected to the pi).
$ lsusb
Bus 001 Device 004: ID 041e:406c Creative Technology, Ltd Live! Cam Sync [VF0520]
Bus 001 Device 005: ID 041e:406c Creative Technology, Ltd Live! Cam Sync [VF0520]
First camera works, I have a webstream on 8081
Second camera does not work:
[2] Retrying until successful connection with camera
[2] cap.driver: "uvcvideo"
[2] cap.card: "VF0520 Live! Cam Sync"
[2] cap.bus_info: "usb-bcm2708_usb-1.3"
[2] cap.capabilities=0x04000001
[2] - VIDEO_CAPTURE
[2] - STREAMING
[2] Unable to query input 1 VIDIOC_ENUMINPUT: Invalid argument
[2] ioctl (VIDIOCGCAP): Invalid argument
[2] Video signal lost - Adding grey image
So I switched the cameras to check if it is a problem with the second cameras itself: Same problem
Next try: Connect both cameras to a powered usb hub: Same problem.
Next try: One camera connected to board, other camera to usb hub: Same probem
Any ideas?
Brgds,
Dietmar
jors
Re: 2 Webcams with motion
Sat Feb 02, 2013 8:47 pm
I have bought the same webcam (Creative Live! Cam Sync) and I haven't managed to get it working propperly with motion :cry:
Other image capture apps (fswebcam, uvccapture) work correctly, but even if I tried several & different configuration options with motion, most of captured images are corrupt. Could you please provide your motion configuration/usage?
Cheers.
Blog @ http://enchufado.com/
jors
Sun Feb 03, 2013 9:13 am
Oh, and just for the record the webcam works perfectly with motion + same configuration on any other non-Raspberry Pi hardware. It is a little bit dissapointing since I cannot do anything to solve it because it is a hardware issue.
Cheers.
jors
Sun Feb 03, 2013 10:57 am
Ok, found a workaround on the forums (http://www.raspberrypi.org/phpBB3/viewt ... 6&p=276985 and http://www.raspberrypi.org/phpBB3/viewt ... er#p164539) that worked. In summary, you have to use motion taking the input from mjpg_streamer. Here are (more or less) the steps:
Step 1: mjpg_streamer
apt-get install subversion libv4l-dev libjpeg8-dev imagemagick checkinstall
cd /usr/src/
svn co https://mjpg-streamer.svn.sourceforge.net/svnroot/mjpg-streamer mjpg-streamer
cd mjpg-streamer/mjpg-streamer
make USE_LIBV4L2=true clean all
checkinstall # Basically this creates a Debian/Raspbian package for better handling
dpkg -l | grep mjpg # Verify it has been installed
mjpg_streamer -i "/usr/local/lib/input_uvc.so -d /dev/video0 -r 352x288 -f 5" -o "/usr/local/lib/output_http.so -p 8090 -w /var/www/mjpg_streamer" # You can avoid putting absolute paths to plugins by setting LD_LIBRARY_PATH as follows...
export LD_LIBRARY_PATH=/usr/local/lib; mjpg_streamer -i "input_uvc.so -d /dev/video0 -r 352x288 -f 5" -o "output_http.so -p 8090 -w /var/www/mjpg_streamer"
Step 2: motion
apt-get install motion
vi /etc/motion/motion.cnf
netcam_url "http://localhost:8090/?action=snapshot"
motion -n
And that's it. Hope it will be usefull to others!
Cheers.
gerorge
Wed Apr 17, 2013 6:48 pm
I had the same problem, but after launch it manually i saw that motion.conf didn't find thread files:
motion looks for :
/usr/local/etc/thread*.conf
bu my files are in:
/etc/motion/thread*.conf
after that you have to change ports, so that you'll have a different port for a different camera
regards
droidus
Wed Apr 17, 2013 9:55 pm
I have been having issues with motion as well. I am using an hp webcam, and can't get it to stream to the address defined by the netcam_url.
chriglu
Thu Apr 18, 2013 4:44 am
droidus wrote:I have been having issues with motion as well. I am using an hp webcam, and can't get it to stream to the address defined by the netcam_url.
Can you check if motion is listening on the defined ports with "netstat -tulpn" ?
tcp        0      0 0.0.0.0:8081            0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:8082            0.0.0.0:*               LISTEN
droidus
Sat Apr 20, 2013 12:22 am
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 2154/apache2
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 2692/sshd
tcp 0 0 127.0.0.1:3306 0.0.0.0:* LISTEN 2781/mysqld
udp 0 0 0.0.0.0:68 0.0.0.0:* 1984/dhclient
udp 0 0 10.30.211.164:123 0.0.0.0:* 2329/ntpd
udp 0 0 127.0.0.1:123 0.0.0.0:* 2329/ntpd
udp 0 0 0.0.0.0:123 0.0.0.0:* 2329/ntpd
udp 0 0 0.0.0.0:60804 0.0.0.0:* 1984/dhclient
this is all that is running when I run motion.
chriglu
Sat Apr 20, 2013 6:23 am
It seems that your motion isn't running on any ports. if you started motion, you should see a log entry /var/log/syslog when it starts listening on the ports:
pi@earlybirdpi ~ $ grep stream /var/log/syslog
Apr 20 08:06:14 earlybirdpi motion: [1] Started stream webcam server in port 8081
Apr 20 08:06:15 earlybirdpi motion: [2] Started stream webcam server in port 8082
can you check, if motion is running? maybe the startup already fails..
pi@earlybirdpi ~ $ pstree |grep motion
     |-motion---3*[{motion}]
Otherwise you need to have a look in /var/log/syslog what's happening/failing when you start it.
droidus
Sat Apr 20, 2013 12:26 pm
when I run that first command, this is what I get:
Apr 6 18:11:18 raspberrypi motion: [1] Started stream webcam server
in port 8081
Apr 6 18:43:59 raspberrypi motion: [1] Started stream webcam server
in port 8081
Apr 6 23:03:42 raspberrypi motion: [1] Started stream webcam server
in port 8081
Apr 6 23:06:27 raspberrypi motion: [1] Started stream webcam server
in port 8081
Apr 16 17:18:13 raspberrypi mysqld: Open streams: 0
Apr 19 22:50:10 raspberrypi mysqld: Open streams: 0
as for the grep motion:
| -bash---motion---{motion}
piscesmini
Tue Oct 14, 2014 2:15 pm
Hi I am new to Rasberry Pi
I was able to connect 2 USB cameras and both are working fine. I just cannot get both cameras to work because I dont know how to make new thread.conf files for both cameras.
Can you please help
Sailinghome
Fri Oct 24, 2014 3:21 am
This site is a bit old, but seems to explain how to separate the two webcams in the RPi.
http://astrobeano.blogspot.hk/2012/08/r ... bcams.html
I hope it helps.
sudo
Thu Oct 30, 2014 1:41 am
My particular error message read:
Unable to query input 5 VIDIOC_ENUMINPUT: Invalid argument
Well, turns out, my /etc/motion/motion.conf had a section that appeared as:
# The video input to be used (default: 8)
# Should normally be set to 0 or 1 for video/TV cards, and 8 for USB cameras
input 5
I changed it to input 8 and now my camera works.
In my case, I was probably the culprit. Long ago, I'd been going crazy trying insane things to make some uncooperative, ancient web cam function. Then I got some new cheap ones from ebay and tried them, running aground with this. I didn't notice this rather glaring error.
Others may stumble here as I did, hence my posting of this here.
alfox
Fri May 22, 2015 2:47 pm
Can you help me? My two webcams don't work: only one.
On this guide http://astrobeano.blogspot.hk/2012/08/r ... bcams.html
..... I went with two camera configuration files as ~/webcam/cam1.conf which is just:
videodevice /dev/video0
webcam_port 8081
What is the "cam1.conf "'s path?
How do I put my configuration files? txt e docx are't allowed
barsznica
Tue Mar 07, 2017 5:51 am
Hurrah, it works!
Uncomment the "threads" used in motion.conf and comment out any lines that will be in the "thread*.conf" files. The thread*.conf files live where motion.conf does; /etc/motion/
The tread.conf files only need to describe things that are DIFFERENT between the cameras. Therefore, videodevice and stream_port will have to be commented out in motion.conf (at the very least).
In thread2.conf I have:
videodevice /dev/video1
stream_port 8081
In thread1.conf I have:
stream_port 8082
Running apache2, in /var/www/html/index.html only contains:
<img src="http://192.168.1.5:8081"/>
<img src="http://192.168.1.5:8082"/>
pvklink
Wed Mar 08, 2017 7:43 pm
Hi can somebody help me witj my motion.conf?
I can't get motion control working in my RPI
i installed debian jessie
RPI 3 b
IP camera DAHUA IPC A35P
I just installed a DAHUA IPC A35P. and the web and app are working great! I have the app working over internet,
streams are stored on my nas and the last thing to do is domoticz integration.
I installed motion on the rpi:
sudo apt-get install motion
sudo nano /etc/default/motion
start_motion_daemon=yes and saved the file
sudo /etc/init.d/motion start
and finaly edit motion.conf with
netcam_url rtsp:// :@/cam/realmonitor?channel=1&subtype=0.
rtsp_uses_tcp off
and get errors like this: (strange because i do get a live stream in VLC with the same URL !!!! is this a Bug?
[1] [CRT] [NET] [Mar 08 19:48:27] netcam_start: Invalid netcam_url ( rtsp:// :@/cam/realmonitor?channel=1&subtype=0.)
[1] [WRN] [ALL] [Mar 08 19:48:27] motion_init: Could not fetch initial image from camera Motion continues using width and height from config file(s)
What else parameters do i have to set to get my motion control to work
Or is it that the url could be correct but other parameters are wrong?
Who can help me?, i think i am almost there....
Annihilation989
Wed Feb 14, 2018 3:44 pm
will the camera work if it already has built in software
Annihilation989
Fri Feb 16, 2018 10:29 am
