Vizelius
Raspi OS x64 SSD boot load problem
Sat Aug 08, 2020 6:35 pm
I'm trying to boot from SSD and can't do that.
Tried oficial instructions - https://www.raspberrypi.org/documentati ... _config.md
Also tried to just burn image (https://downloads.raspberrypi.org/raspi ... -arm64.zip) and load directly.
It always stop at the step: "Starting show plymouth boot screen"
Kendek
Re: Raspi OS x64 SSD boot load problem
Sat Aug 08, 2020 8:20 pm
You probably need to disable UAS with usb-storage.quirks=aaaa:bbbb:u kernel command line option. See this Sticky topic, first and second steps.
Vizelius
Sat Aug 08, 2020 9:10 pm
It worked! Thank you. Seems that case that I bought isn't good enough for UAS :(
