ejolson wrote: ↑Sat Jul 18, 2020 5:45 am
Do you have a domain line in your resolv.conf file? If you put one in, does the problem go away?
Now that is interesting, it picked up something that's gone wrong due to actions I have taken so what I thought was a bit of a success is probably not so.
I re-enabled avahi last night and initially it made no difference but a while later pinging gggg correctly reported not available, I need to undo some firewall settings on the other (server) Pi4 to fully enable multicast (even though I want multicast eradicated).
Also last night I put the router back to factory settings before re-configuring it, I isolated from some of the network because I knew its IP would be reset to 192.168.1.1 (its normally 192.168.1.222) colliding with another router. Unfortunately I left the Pi's connect to the (normally 222) router and they picked up 192.168.1.1 nameserver, when I reconnected to the rest of the local network they have retained that that IP using the other router.
So currently I have the following but hopefully a few resets should put that back to 192.168.1.222
cat /etc/resolv.conf
# Generated by resolvconf
domain lan
nameserver 192.168.1.1
Until I get that sorted I won't know if re-enabling avahi helped or not. Before resetting the router the resolv.conf was correct.
Absolutely regardless of what the Pis are doing the DNS resolver in the router should not be giving me this fixed serbian IP. I have put a whinge on the talktalk forum.
